ain_4
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
Next revisionBoth sides next revision
ain_4 [2016/08/10 20:25] – [Capacitors] latigid_onain_4 [2016/08/13 17:35] – [Schematic] latigid_on
Line 10: Line 10:
 For bipolar operation, a +5V reference may be switched in. The output of the first stage is interrupted by a pot in order to attenuate the signal. The second stage has variable gain from -1 to -0.5 by way of a switched resistor. Hence one can easily select between 0-5V, 0-10V and +/- 5V input ranges to optimise the signal amplitude reaching the ADC. Because the second op amp is powered at the same voltage as the MCU (ideally the same rail), its inputs are protected from over- and under-voltages. For bipolar operation, a +5V reference may be switched in. The output of the first stage is interrupted by a pot in order to attenuate the signal. The second stage has variable gain from -1 to -0.5 by way of a switched resistor. Hence one can easily select between 0-5V, 0-10V and +/- 5V input ranges to optimise the signal amplitude reaching the ADC. Because the second op amp is powered at the same voltage as the MCU (ideally the same rail), its inputs are protected from over- and under-voltages.
 +Note the gain calculation, and be aware the top of the signal may clip (harmlessly) if around 3.0V peak is exceeded on the second op amp stage.
Line 17: Line 19:
 ^Type     ^Qty ^Value ^Package ^Parts^Notes^ ^Type     ^Qty ^Value ^Package ^Parts^Notes^
 ^resistors^  ^resistors^
-|         |20   |49k9   |0204/7|R1, R2, R4, R5, R6, R7, R8, R10, R11, R12, R13, R14, R16, R17, R18, R19, R20, R22, R23, R24| +|         |20   |49k9 1% or better   |0204/7|R1, R2, R4, R5, R6, R7, R8, R10, R11, R12, R13, R14, R16, R17, R18, R19, R20, R22, R23, R24|It's best to match pairs or go for 0.1% tolerance parts
-|         |4    |30k    |0204/7|R3, R9, R15, R21|nominal gain can be adjusted e.g. (22k/49.9k)*5V = 2.2V| +|         |4    |30k 1%   |0204/7|R3, R9, R15, R21|nominal gain can be adjusted e.g. (22k/49.9k)*5V = 2.2V|
 ^capacitors^  ^capacitors^
-| |4|10p|025X050|C1, C3, C5, C7|+| |4|10p|025X050|C1, C3, C5, C7|20% (?)
 | |9|100n|025X050|C10, C12, C13, C14, C15, C16, C17, C18, C20|remove 1 if powering from Core| | |9|100n|025X050|C10, C12, C13, C14, C15, C16, C17, C18, C20|remove 1 if powering from Core|
 | |3|10u|electrolytic 2,5-6|C9, C11, C19|remove 1 if powering from Core| | |3|10u|electrolytic 2,5-6|C9, C11, C19|remove 1 if powering from Core|
Line 101: Line 103:
   * with a 100k pot facing you, solder the left leg to 0V(ground)   * with a 100k pot facing you, solder the left leg to 0V(ground)
 +  * with the pot turned anticlockwise, the TL072 output is shorted to ground. While shorts are permitted in the datasheet, it's advisable to connect a small value resistor (e.g. 10-100R) between the left leg and ground.
   * centre to WIPER   * centre to WIPER
   * right to LEG   * right to LEG
ain_4.txt · Last modified: 2016/08/18 09:36 by latigid_on
