aout_module [2008/11/24 05:58] this |
aout_module [2016/08/04 23:50] psykhaze [Introduction] |
Line 1: | Line 1: | ||
- | AOUT modules generate analog voltages (and gate signals) controlled by Midibox. Usually these are used to drive Analog Synthesizers. | + | ====== AOUT Module ====== |
- | The following modules are available: | + | {{ :neonking:mbhp_aout_3.jpg?400 |}} |
- | [[http://www.ucapps.de/mbhp_aout.html|AOUT Module]] <sup>uCApps</sup>\\ | + | =====Introduction===== |
- | [[http://www.ucapps.de/mbhp_aout_lc.html|AOUT_LC Module]] (low cost AOUT Module)<sup>uCApps</sup>\\ | + | |
- | [[aout_ng|AOUT_NG Module]] (new AOUT Module)\\ | + | AOUT modules generate **Analog (Control) Voltages (and gate signals)** *. It provides 8 control voltage (CV) outputs with **12 bit resolution** and 2 gate outputs. It is used by various MIDIbox projects to control analog synthesizers and/or FX gear. |
+ | The MAX525 DACs feature better performance than the one used on the [[AOUT_NG]]. **So for perfectionists wanting to drive analog VCOs with maximum tuning precision, the AOUT is the right choice**. Bipolar operation is possible but needs some external parts. Althought, MAX525 is quite expensive and has limited availability. | ||
+ | =====Parts / Schematic===== | ||
+ | see [[aout_board_parts_list|AOUT Parts List]] | ||
+ | * {{http://ucapps.de/mbhp/mbhp_aout.pdf|Schematic}}<sup>UCapps</sup> | ||
+ | Replacement for MAX6007B : **LM4040A20** [[http://www.ti.com/lit/gpn/LM4040A20|(datasheet)]].\\ | ||
- | The SHX8 module is used to extend the number of AOUT outputs using Sample and Hold chips | ||
- | [[http://www.ucapps.de/mbhp_shx8.html|SHX8 Module]] (expands AOUT Module < 64 CV Outputs) <sup>uCApps</sup>\\ | ||
- | (expired, S&H chips are discontinued/obsolete)\\ |
