arkade
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
arkade [2008/12/31 10:22] – goule | arkade [2016/07/04 01:53] – [Features] psykhaze | ||
Line 1: | Line 1: | ||
- | ====== Arkade | + | ====== |
- | ===== What Arkade is ===== | + | |
- | <box 350px right round> | + | |
- | {{: | + | ===== Introduction ===== |
- | \\ | + | **Arkade is a MIDI controller that embeds pairs of everything** :-o : |
- | Arkade is a MIDI controller that embeds pairs of everything :-o : | + | |
* A pair of analog joysticks coming from a canibalized PS2 gamepad ^_^. They center when you release them (+ they' | * A pair of analog joysticks coming from a canibalized PS2 gamepad ^_^. They center when you release them (+ they' | ||
Line 14: | Line 13: | ||
* A pair of knobs | * A pair of knobs | ||
* Midi In / Out + sustain / expression / switch pedal | * Midi In / Out + sustain / expression / switch pedal | ||
- | <box 350px right round> | + | {{: |
- | Sustain, expression, and switch pedal inputs | + | Sustain, expression, and switch pedal inputs; MIDI In/Out, power |
- | </box> | + | |
- | \\ | + | ===== Original Design Ideas ===== |
- | The ideas I had at the beginnig of designing the Arkade were : | + | |
* Unusual sensor types (sliders forbidden :-X - knobs tolerated ;-)) | * Unusual sensor types (sliders forbidden :-X - knobs tolerated ;-)) | ||
Line 28: | Line 26: | ||
* Able to send program changes and even note on/off easily | * Able to send program changes and even note on/off easily | ||
* Two persons may play it live (2nd pair of joysticks) without bothering each other | * Two persons may play it live (2nd pair of joysticks) without bothering each other | ||
- | * ... anything that cood be missing on any midi controler, like a simple MIDI-gating button (labeled " | + | * ... anything that could be missing on any midi controler, like a simple MIDI-gating button (labeled " |
- | ===== What Arkade does ===== | ||
+ | ===== Features ===== | ||
- | * for __all the sensors__, you can set : | + | * for **__all the sensors__**, you can set : |
* the midi channel | * the midi channel | ||
* the controller n° | * the controller n° | ||
Line 41: | Line 37: | ||
* the direction (normal/ | * the direction (normal/ | ||
* a name (that will appear automatically when touched) | * a name (that will appear automatically when touched) | ||
- | * for __the two ribbon controllers__, | + | * for **__the two ribbon controllers__**, you have two extra settings : |
* mode (CC/note = will behave like a synth keyboard, generating notes on/off instead of continuous controller values) | * mode (CC/note = will behave like a synth keyboard, generating notes on/off instead of continuous controller values) | ||
* release (keep = last value kept after release / RTZ = return to zero after release) | * release (keep = last value kept after release / RTZ = return to zero after release) | ||
* Arkade embeds a full bankstick module so that you can store 128 presets | * Arkade embeds a full bankstick module so that you can store 128 presets | ||
* A single preset is a full set of parameters for the entire panel controllers (all the parameters described upper x nb of sensors) | * A single preset is a full set of parameters for the entire panel controllers (all the parameters described upper x nb of sensors) | ||
* By using your two hands on the joysticks + one expression foot pedal, you act on 5 simultaneous values in realtime, with natural control | * By using your two hands on the joysticks + one expression foot pedal, you act on 5 simultaneous values in realtime, with natural control | ||
* Arkade has a dedicated wheel for sending program changes to the outside world, to try the same preset over different sounds | * Arkade has a dedicated wheel for sending program changes to the outside world, to try the same preset over different sounds | ||
- | * By setting a ribbon in keyboard mode (remember | + | * By setting a ribbon in keyboard mode, Arkade can not only modulate the signal but also trigger it. Remember : you can set min/max range for each : here, it's the min/max keys of a piano-like keyboard; touching the ribbon plays notes |
* There' | * There' | ||
* You can enable/ | * You can enable/ | ||
- | ===== What Arkade requires | + | |
+ | ===== Assembly | ||
* 1x core, 1x AIN, 1x DIN, 2x DOUT (one is 100% dedicated to the joystick' | * 1x core, 1x AIN, 1x DIN, 2x DOUT (one is 100% dedicated to the joystick' | ||
Line 76: | Line 71: | ||
===== Videos ===== | ===== Videos ===== | ||
+ | In this section I briefly show the Arkade in use. | ||
+ | \\ More videos to come ! | ||
{{youtube> | {{youtube> | ||
===== Remarks ===== | ===== Remarks ===== | ||
* Soldering the bargraphs was a piece of a Hell ... so many cables, so few space ! | * Soldering the bargraphs was a piece of a Hell ... so many cables, so few space ! | ||
- | * Adapting some of the sensors to the MBHP platform needed some conditionning (use of caps, resistors, many values were tried to find the right ones). The response curve of Sharp' | + | * Adapting some of the sensors to the MBHP platform needed some conditionning (use of caps, resistors, many values were tried to find the right ones). The response curve of Sharp' |
* The ability to update the OS on the machine in a single click (thanks to MIOS Studio) just rocked | * The ability to update the OS on the machine in a single click (thanks to MIOS Studio) just rocked | ||
* Special thank to my friend who could directly put my Autocad file in his drilling machine at his work to build the frontpanel | * Special thank to my friend who could directly put my Autocad file in his drilling machine at his work to build the frontpanel | ||
Line 99: | Line 98: | ||
\\ Olivier | \\ Olivier | ||
- | \\ | + | {{arkade: |
- | \\ | + | \\ [[http:// |
- | [[http:// | + | \\ [[http:// |
arkade.txt · Last modified: 2016/07/04 01:54 by psykhaze
