audio_synthesis_integrated_circuit [2016/06/08 12:28] psykhaze [Introduction] |
audio_synthesis_integrated_circuit [2016/06/14 19:37] psykhaze [Reference Datasheets] |
Line 2: | Line 2: | ||
{{ ::neonking:pdip_40_t.jpg?direct&200 |}} | {{ ::neonking:pdip_40_t.jpg?direct&200 |}} | ||
- | ===== Introduction ===== | ||
Most of the audio synthesis integrated circuits used in MIDIbox project are some Programmable Sound Generators. This means that you send binary data as input to have analog audio output | Most of the audio synthesis integrated circuits used in MIDIbox project are some Programmable Sound Generators. This means that you send binary data as input to have analog audio output | ||
- | ===== MIDIbox related ===== | + | ===== Reference Datasheets / Programming Manuals ===== |
+ | * [[https://drive.google.com/open?id=0BzLvNo6FQZJscFJYaHFzLU15OUk|MOS6581]] | ||
+ | * [[http://www.6502.org/documents/datasheets/mos/mos_6582_sid.pdf|MOS6582]] | ||
+ | * [[http://map.grauw.nl/resources/sound/yamaha_ymf262.pdf|YMF262]] | ||
+ | * [[http://www.fit.vutbr.cz/~arnost/opl/opl3.html|YMF262 Programming Manual]] | ||
+ | * [[https://drive.google.com/open?id=0BzLvNo6FQZJsWk9MX21oS095a2c|YAC512]] | ||
+ | * [[http://www.smspower.org/maxim/Documents/YM2612|YM2612]] | ||
+ | * [[http://www.suzushoweb.com/pdf_file/4644200529e19.pdf|SN76489]] | ||
+ | * [[http://wiki.midibox.org/lib/exe/fetch.php?media=stella_tia.pdf|TIA Programmer Manual]] | ||
+ | * [[http://magnevation.com/SpeakJet.swf|SpeakJet]] | ||
+ | * [[http://www.ym2149.com/ay8910.pdf|AY-3-8910]] | ||
+ | * [[http://www.ym2149.com/ym2149.pdf|YM2149]] | ||
- | * MOS6581 | ||
- | * MOS6582 | ||
- | * YMF262 | ||
- | * YM2149F | ||
- | * YM2612 | ||
- | * YM3438 | ||
- | * SN76489 |
