Next revision | Previous revision | ||
blm16x16v2 [2022/12/18 22:07] phatline created |
blm16x16v2 [2023/02/10 15:47] phatline |
Line 1: | Line 1: | ||
====== BLM16x16+X V2 - Board ====== | ====== BLM16x16+X V2 - Board ====== | ||
+ | {{:phatline:blm16x16X-V2-Bild.jpg?600|}}\\ | ||
{{:phatline:BLM16x16-PCB-3D-Front.jpg?600|}}\\ | {{:phatline:BLM16x16-PCB-3D-Front.jpg?600|}}\\ | ||
{{:phatline:BLM16x16-PCB-3D-Back.jpg?600|}}\\ | {{:phatline:BLM16x16-PCB-3D-Back.jpg?600|}}\\ | ||
- | Since i need need a BLM16x16+X for my [[triggermatrix5]] | + | for [[TriggerMatrix4 ]] i used Latigid ONs PCB: [[mididocs:seq:blm16x16_build_guide]], but i had only 2 PCBs, one for me, and one finally got Maxim Anokhin (Limewax), in order to get more Triggermatrices into the world I made my own Version for the upcoming [[triggermatrix5]] |
- | And since Latigid ONs BLM is sold out [[blm16x16_build_guide]]... (and those 1N4148 Thruholes nightmare..) | + | |
- | I made this new Version, based on Latigids Shematical Improvements. | + | |
====== Shematic ====== | ====== Shematic ====== | ||
{{:phatline:BLM16x16-Shematic.pdf?400|}}\\ | {{:phatline:BLM16x16-Shematic.pdf?400|}}\\ | ||
====== Building and BOM====== | ====== Building and BOM====== | ||
- | The Values are printet on the PCB. | + | The Values are printet on the PCB.\\ |
- | {{:phatline:DAW-Encoder-Display-PCB.png?400|}}\\ | + | {{:phatline:BLM16x16-PCB-Back.pdf?400|}}\\ |
+ | {{:phatline:BLM16x16-PCB-Front.pdf?400|}}\\ | ||
- | **Following Quantity is for 1 PCB, Mouser:**\\ | + | ===== Order-List ===== |
- | open following link: [[https://www.mouser.com/tools/part-list-import.aspx]]\\ | + | copy following list into this [[https://www.mouser.com/tools/part-list-import.aspx|mouser.com-Link]] |
- | + | <WRAP center round box 60%> | |
- | **& copy past follwong list:**\\ | + | 595-SN74LVC1G17DBVR|12\\ |
- | + | 80-C0805C104M5R|32\\ | |
- | 187-CL21B104KBFWPJE|7\\ | + | 710-860010273011|1\\ |
- | 187-CL21A106KPFNNNE|4\\ | + | 863-BAT54LT1G|34\\ |
- | 81-GRM219R60J476ME4D|4\\ | + | 595-SN74HC595DR|15\\ |
- | 652-PEC11R-4015F-S24|9\\ | + | 595-SN74HC165DT|5\\ |
- | 710-61201021621|3\\ | + | 710-61201021621|2\\ |
- | 667-ERJ-P06F1001V|6\\ | + | 863-BC818-40LT1G|34\\ |
- | 660-RK73H2ATTD1002F|27\\ | + | 660-RK73B2ATTD102J|34\\ |
- | 660-RK73H2ATTD1002F|3\\ | + | 660-RK73B2ATTD103J|75\\ |
- | FIXME the 3x hc165 are missing\\ | + | 603-RC0805JR-13220RL|40\\ |
+ | 660-RK73H2ATTD56R0F|40\\ | ||
+ | 604-APTR3216ZGC|300\\ | ||
+ | 604-APTR3216QBC/D|300\\ | ||
+ | 621-1N4148WS-F|150\\ | ||
+ | </WRAP> | ||
- | You may change the how many times you want to order this project\\ | + | **Order from Reichelt:**\\ |
- | aka you need it 10 times, then do this after importing the list into mouser...\\ | + | 2x [[https://www.reichelt.de/at/de/pfostenbuchse-10-polig-mit-zugentlastung-pfl-10-p14571.html?&trstct=pos_0&nbc=1|PinHeader 2x5Pin Female]]\\ |
- | if you need it 10 times it cost around 199€\\ | + | |
- | **6 Displays which you get from Ali:**\\ | + | **Order from Adadruit:**\\ |
- | [[https://de.aliexpress.com/item/32638662748.html|SSD1306-128x64 7pin White]] | + | 19x [[https://www.adafruit.com/product/1611|Silicone Elastomer 4x4]]\\ |
====== To Do ====== | ====== To Do ====== | ||
- | make a Frontpanel.\\ | + | waiting for the Prototype to come, then solder hundrets off components\\ |
====== Community users working on it ====== | ====== Community users working on it ====== | ||
Line 46: | Line 46: | ||
Just let a Private message on the forum to user already involved.\\ | Just let a Private message on the forum to user already involved.\\ | ||
- | or join the forum: [[http://midibox.org/forums/topic/24791-daw-controller-ableton/|daw-controller-ableton]]\\ | + | or join the forum: [[http://midibox.org/forums/topic/28777-triggermatrix-5/|Triggermatrix 5]]\\ |
