book_reviews
Differences
Next revision | Previous revisionLast revisionBoth sides next revision | ||
book_reviews [2006/02/04 15:00] – created smashtv | book_reviews [2011/06/06 07:06] – rafaelcarter | ||
Line 1: | Line 1: | ||
- | !!*PIC Programming | + | ====== English ====== |
- | !PIC Your Personal Introductory Course | ||
- | by John Morton< | ||
- | ISBN 0 7506 5038 9<br> | ||
- | Purchased from [Amazon|http:// | ||
- | This is an introductory book for the beginner. | + | ===== PIC Programming ===== |
- | Unfortunately the book does not cover some of the instruction set of the [PIC18F452]. | + | === PIC Your Personal Introductory Course === |
- | < | + | by John Morton\\ |
- | ----- | + | ISBN 0 7506 5038 9\\ |
- | < | + | Purchased from [[http:// |
- | !Embedded Design with the PIC18F452 Microcontroller | + | This is an introductory book for the beginner. |
- | by John B. Peatman< | + | |
- | ISBN 0 13 046213-6< | + | |
- | Purchased from [Amazon|http:// | + | |
- | As you can see above this is not a cheap book. However, as I progress with trying to understand [MIOS] I am finding that I refer to it more and more. As you can see from its title, it is written specifically for the [PIC18F452] that is the current [microprocessor] used in MIOS. | ||
- | The main advantage of this book is that it covers in detail the following topics relating to the [PIC18F452] under the chapter headings:< | ||
- | - CPU Architecture<br> | + | === Embedded Design with the PIC18F452 Microcontroller === |
- | - Instruction Set<br> | + | by John B. Peatman\\ |
- | - LCD Displays<br> | + | ISBN 0 13 046213-6\\ |
- | - Interrupts and Interrupt Timing<br> | + | Purchased from [[http:// |
- | - Analog to Digital Conversion<br> | + | As you can see above this is not a cheap book. However, as I progress with trying to understand [[MIOS]] I am finding that I refer to it more and more. As you can see from its title, it is written specifically for the [[PIC18F452]] that is the current [[microprocessor]] used in MIOS.The main advantage of this book is that it covers in detail the following topics relating to the [[PIC18F452]] under the chapter headings:\\ |
- | - I/O Pin Considerations<br> | + | - CPU Architecture\\ |
- | - Serial Interfacing<br> | + | - Instruction Set\\ |
+ | - LCD Displays\\ | ||
+ | - Interrupts and Interrupt Timing\\ | ||
+ | - Analog to Digital Conversion\\ | ||
+ | - I/O Pin Considerations\\ | ||
+ | - Serial Interfacing\\ | ||
+ | This is not a beginners book! A beginner will need a gentler introduction such as the first book. | ||
+ | ====== German ====== | ||
+ | ===== C Programming ===== | ||
+ | === C von A bis Z (German) === | ||
+ | von Jürgen Wolf, Galileo Computing\\ | ||
+ | ISBN 3-89842-643-2\\ | ||
+ | [[OpenBook]] (!) oder gebundene Ausgabe: 39,90 €\\ | ||
+ | Ein sehr gutes, plattformübergreifendes (!) und übersichtlich aufgebautes OpenBook. | ||
+ | Kann man online ansehen, als zip herunterladen (html) oder gebunden bestellen, was will man mehr? :) | ||
+ | http:// | ||
+ | === C Programmieren von Anfang an (German) === | ||
+ | von Helmut Erlenkötter, | ||
+ | ISBN: 3-499-60074-9\\ | ||
+ | Taschenbuch, | ||
+ | What I like about it (besides the price) is that it's very clear structured and contains line-by-line explained examples for every entry; that makes it a valueable book not only to learn but also to look up things later. | ||
+ | http:// | ||
+ | [[http:// | ||
- | This is not a beginners book! A beginner will need a gentler introduction such as the first boo | ||
book_reviews.txt · Last modified: 2012/10/04 15:44 by smashtv
