book_reviews
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
book_reviews [2006/02/04 15:08] – smashtv | book_reviews [2012/10/04 15:44] (current) – old revision restored (spam kill) smashtv | ||
Line 1: | Line 1: | ||
- | =======PIC Programming======= | + | ====== |
- | ====PIC Your Personal Introductory Course==== | + | |
+ | ===== PIC Programming ===== | ||
+ | === PIC Your Personal Introductory Course === | ||
by John Morton\\ | by John Morton\\ | ||
ISBN 0 7506 5038 9\\ | ISBN 0 7506 5038 9\\ | ||
- | Purchased from [Amazon|http:// | + | Purchased from [[http:// |
+ | This is an introductory book for the beginner. | ||
- | This is an introductory book for the beginner. | ||
- | Unfortunately the book does not cover some of the instruction set of the [PIC18F452]. | + | === Embedded Design with the PIC18F452 Microcontroller === |
- | ===Embedded Design with the PIC18F452 Microcontroller=== | + | |
by John B. Peatman\\ | by John B. Peatman\\ | ||
ISBN 0 13 046213-6\\ | ISBN 0 13 046213-6\\ | ||
- | + | As you can see above this is not a cheap book. However, as I progress with trying to understand | |
- | As you can see above this is not a cheap book. However, as I progress with trying to understand [MIOS] I am finding that I refer to it more and more. As you can see from its title, it is written specifically for the [PIC18F452] that is the current [microprocessor] used in MIOS. | + | |
- | The main advantage of this book is that it covers in detail the following topics relating to the [PIC18F452] under the chapter headings: | + | |
- CPU Architecture\\ | - CPU Architecture\\ | ||
- Instruction Set\\ | - Instruction Set\\ | ||
Line 26: | Line 23: | ||
- I/O Pin Considerations\\ | - I/O Pin Considerations\\ | ||
- Serial Interfacing\\ | - Serial Interfacing\\ | ||
This is not a beginners book! A beginner will need a gentler introduction such as the first book. | This is not a beginners book! A beginner will need a gentler introduction such as the first book. | ||
+ | ====== German ====== | ||
+ | ===== C Programming ===== | ||
+ | === C von A bis Z (German) === | ||
+ | von Jürgen Wolf, Galileo Computing\\ | ||
+ | ISBN 3-89842-643-2\\ | ||
+ | [[OpenBook]] (!) oder gebundene Ausgabe: 39,90 €\\ | ||
+ | Ein sehr gutes, plattformübergreifendes (!) und übersichtlich aufgebautes OpenBook. | ||
+ | Kann man online ansehen, als zip herunterladen (html) oder gebunden bestellen, was will man mehr? :) | ||
+ | http:// | ||
+ | === C Programmieren von Anfang an (German) === | ||
+ | von Helmut Erlenkötter, | ||
+ | ISBN: 3-499-60074-9\\ | ||
+ | Taschenbuch, | ||
+ | What I like about it (besides the price) is that it's very clear structured and contains line-by-line explained examples for every entry; that makes it a valueable book not only to learn but also to look up things later. | ||
+ | http:// | ||
book_reviews.txt · Last modified: 2012/10/04 15:44 by smashtv
