book_reviews
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
book_reviews [2006/02/04 15:15] – smashtv | book_reviews [2011/06/06 07:06] – rafaelcarter | ||
Line 1: | Line 1: | ||
+ | ====== English ====== | ||
- | =======PIC Programming======= | + | |
- | ======PIC Your Personal Introductory Course====== | + | ===== PIC Programming ===== |
+ | === PIC Your Personal Introductory Course === | ||
by John Morton\\ | by John Morton\\ | ||
ISBN 0 7506 5038 9\\ | ISBN 0 7506 5038 9\\ | ||
- | Purchased from [Amazon|http:// | + | Purchased from [[http:// |
- | ======Embedded Design with the PIC18F452 Microcontroller====== | + | This is an introductory book for the beginner. |
+ | === Embedded Design with the PIC18F452 Microcontroller === | ||
by John B. Peatman\\ | by John B. Peatman\\ | ||
ISBN 0 13 046213-6\\ | ISBN 0 13 046213-6\\ | ||
- | As you can see above this is not a cheap book. However, as I progress with trying to understand [[MIOS]] I am finding that I refer to it more and more. As you can see from its title, it is written specifically for the [PIC18F452] that is the current [[microprocessor]] used in MIOS.The main advantage of this book is that it covers in detail the following topics relating to the [[PIC18F452]] under the chapter headings: | + | As you can see above this is not a cheap book. However, as I progress with trying to understand [[MIOS]] I am finding that I refer to it more and more. As you can see from its title, it is written specifically for the [[PIC18F452]] that is the current [[microprocessor]] used in MIOS.The main advantage of this book is that it covers in detail the following topics relating to the [[PIC18F452]] under the chapter headings: |
- CPU Architecture\\ | - CPU Architecture\\ | ||
- Instruction Set\\ | - Instruction Set\\ | ||
Line 18: | Line 24: | ||
- Serial Interfacing\\ | - Serial Interfacing\\ | ||
This is not a beginners book! A beginner will need a gentler introduction such as the first book. | This is not a beginners book! A beginner will need a gentler introduction such as the first book. | ||
+ | ====== German ====== | ||
+ | ===== C Programming ===== | ||
+ | === C von A bis Z (German) === | ||
+ | von Jürgen Wolf, Galileo Computing\\ | ||
+ | ISBN 3-89842-643-2\\ | ||
+ | [[OpenBook]] (!) oder gebundene Ausgabe: 39,90 €\\ | ||
+ | Ein sehr gutes, plattformübergreifendes (!) und übersichtlich aufgebautes OpenBook. | ||
+ | Kann man online ansehen, als zip herunterladen (html) oder gebunden bestellen, was will man mehr? :) | ||
+ | http:// | ||
+ | === C Programmieren von Anfang an (German) === | ||
+ | von Helmut Erlenkötter, | ||
+ | ISBN: 3-499-60074-9\\ | ||
+ | Taschenbuch, | ||
+ | What I like about it (besides the price) is that it's very clear structured and contains line-by-line explained examples for every entry; that makes it a valueable book not only to learn but also to look up things later. | ||
+ | http:// | ||
+ | [[http:// | ||
book_reviews.txt · Last modified: 2012/10/04 15:44 by smashtv
