cc-looper
Differences
cc-looper [2018/10/10 00:47] – phatline | cc-looper [2020/03/31 14:04] – [Building] phatline | ||
Line 41: | Line 41: | ||
====== Building ====== | ====== Building ====== | ||
==== Frontpanel ==== | ==== Frontpanel ==== | ||
FIXME - a clear Acrylic Frontplate, with NO Engravings, UI-Labeling is viewable from PCB\\ | FIXME - a clear Acrylic Frontplate, with NO Engravings, UI-Labeling is viewable from PCB\\ | ||
Line 47: | Line 60: | ||
- | ===== BOM ===== | + | ===== BOM ===== |
+ | ^Ref ^Qty ^Value ^Footprint ^MouserPart ^Link | ||
+ | |C1 – C7 |7 |100nF |0603 Capacitor |81-GRM33C71C104ME14D |[[https:// | ||
+ | |Rec--1 – Rec—4, UI--5 UI—4, led1, -1 -2 -3 -4 |11 |REC, LED, beat, CC-IN, | ||
+ | |1-16 (LED-BAR) |64 |bar |0603 LED |755-SMLEN3WBC8W1 |[[https:// | ||
+ | |D64 D65 |2 |1N-4148 |1206 Diode |833-1N4148W-TP |[[https:// | ||
+ | |PTC1 |1 |Thermistor_PTC |1206 Resistor |576-1206L150THWR |[[https:// | ||
+ | |R1, R2, R19 – R34 |18 |10K |1206 Resistor |603-AC0603FR-0710KL |[[https:// | ||
+ | |R3 R5 R6 R7 R8 |5 |47 |1206 Resistor |603-RC0603FR-0747RL |[[https:// | ||
+ | |R9-R14, R36, R37 |8 |220 |1206 Resistor |603-RC0603FR-07220RL |[[https:// | ||
+ | |R15 R16 |2 |1K |1206 Resistor |603-RC0603JR-071KL | ||
+ | |R17 R18 |2 |4K7 |1206 Resistor |603-RC0603FR-074K7L |[[https:// | ||
+ | |OUT1 |1 |Midi |DIN-8-SDF-80J |490-SDF-80J |[[https:// | ||
+ | |M1 |1 |DIPCORE32_CMPNT_48P|517-929870-01-20-RA |DIP-40 |[[https:// | ||
+ | |S8 |1 |Shift |DT6 |611-D6R00F1LFS |[[https:// | ||
+ | |S1 – S4 |1 |Part1 |611-SERWHAUOA |DTL2-1-LED |[[https:// | ||
+ | |S5 – S7, S9 – S10 |6 |X, | ||
+ | |ENC1 |1 |ENC_BOURNS_PEC11 |ENC_BOURNS_PEC11+SW |652-PEC11R-4215F-S24 |[[https:// | ||
+ | |IN1 IN2 |2 |Midi |Midi-Socket-MAB5SH-DIN-5|566-MAB5SH |[[https:// | ||
+ | |Foot1 |1 |Pin |PINHEAD-1x02_2.54mm | ||
+ | |J2 |1 |BootLoad |PINHEAD-1x02_2.54mm | ||
+ | |AIN1 |1 |PIN |PINHEAD-2x03_2.54mm | ||
+ | |U1 U2 |2 |6N136 |SMDIP-8_W11.48mm |782-6N136-X009 |[[https:// | ||
+ | |-595 |3 |74HC595 |SO-16-N |621-74AHC595S16-13 |[[https:// | ||
+ | |U3 U4 |2 |74LS165 |SO-16-N |595-SN74LS165ADR |[[https:// | ||
+ | |M2 |1 |µSD_DM3ATDM3AT |ΜSD_DM3AT |798-DM3AT-SF-PEJM5 |[[https:// | ||
===== To Do ===== | ===== To Do ===== | ||
Line 54: | Line 91: | ||
===== Resources ===== | ===== Resources ===== | ||
+ | KiCad-Data{{: | ||
its based on a mixture off: | its based on a mixture off: | ||
* [[http:// | * [[http:// |
cc-looper.txt · Last modified: 2020/12/24 14:14 by phatline
