clock2audio2clock [2018/05/25 03:06] phatline |
clock2audio2clock [2021/01/03 01:41] phatline |
Line 6: | Line 6: | ||
{{:phatline:Clk2aClk.jpg?1000|}}\\ | {{:phatline:Clk2aClk.jpg?1000|}}\\ | ||
{{youtube>qjcWe_V-kEI}} | {{youtube>qjcWe_V-kEI}} | ||
+ | {{youtube>YXOqIRc4XmM}} | ||
{{:phatline:Clk2aClk-test-setup.jpg?1000|}}\\ | {{:phatline:Clk2aClk-test-setup.jpg?1000|}}\\ | ||
- | i fell in love with a zoom livetrack-l12, a multitrack-audio-recorder, in a compact design, severell submixes, parametric eqs, compressor, efx and a extra master-track-recording, and that for a good price...\\ | + | i use a zoom livetrack-l12, a multitrack-audio-recorder: compact design, severell submixes, parametric eqs, compressor, efx and a master-track-recording, a good price...\\ |
- | but it doesnt have midi... in specially it does not have a midiclock.\\ | + | AND it doesnt have midi... it does not do midiclock.\\ |
so when i have to make a track new, or i want to overdub a track, a track that is Midiclock-Driven a sequencer track for example...\\ | so when i have to make a track new, or i want to overdub a track, a track that is Midiclock-Driven a sequencer track for example...\\ | ||
Line 30: | Line 30: | ||
* 3x Midi-Cables\\ | * 3x Midi-Cables\\ | ||
+ | ====== Shematic ====== | ||
+ | {{:phatline:clk2a2clk-shematic.png?500|}}\\ | ||
+ | ====== Building FABRICATED PCB ====== | ||
+ | for DIY on Protoboard - see below "Building DIY"\\ | ||
+ | The Design is optimized for Pick and Place most SMD Parts are on the Back-PCB\\ | ||
+ | i ordered 5 PCBs from JLCPCP with almost all SMD Parts (except Thruholes and the PTC) presoldered\\ | ||
+ | now waiting for Presoldered PCBs LOL - for 8€ a Piece!\\ | ||
+ | {{:phatline:clk2a2clk-3D-top.png?500|}}\\ | ||
+ | {{:phatline:clk2a2clk-3D-back.png?500|}}\\ | ||
+ | ===== BOM ===== | ||
+ | ^Value^Designator^Footprint^LCSC Part Number^Library-Type^Mouser^ | ||
+ | |47uF|C1,C2,C3,C4|midibox:1206-C|C96123|basic| | ||
+ | |100nF|C5,C6,C7|midibox:1206-C|C24497|basic| | ||
+ | |220nF|C8|midibox:1206-C|C1857|basic| | ||
+ | |1N4148W|D1|midibox:SOD123-DIODE|C81598|basic| | ||
+ | |LED-Yellow|D2,D3|midibox:0603-LED|C72038|basic| | ||
+ | |BootLoad|J1|midibox:Header-1x2| | ||
+ | |Debug|J2|midibox:Header-1x2| | ||
+ | |Int.Sw|J3|midibox:Header-1x2| | ||
+ | |Header-1x3|J4|midibox:Header-1x3| | ||
+ | |Midi-DIN-5-Socket_RX|J5|midibox:Midi-DIN5-MAB5SH|||806-KCDX-5S-S2 | | ||
+ | |Midi-DIN-5-Socket_TX|J6,J7|midibox:Midi-DIN5-MAB5SH|||806-KCDX-5S-S2 | | ||
+ | |3.5Jack|J8,J9,J10|midibox:35JACK-CUI_SJ1-3535NG-PI|||490-SJ1-3535NG | | ||
+ | |CV1|JAUT1|midibox:Header-1x2| | ||
+ | |Mounting-Hole|M0,M1,M2,M3,M4|midibox:Mounting-Hole-M3| | ||
+ | |PTC|PTC1|midibox:1206-R|C126818|extended|576-1206L150THWR| | ||
+ | |4K7|Rb1,R1,R2,R3|midibox:1206-R|C17936|basic|| | ||
+ | |1K|R4|midibox:1206-R|C4410|basic|| | ||
+ | |220|R7,R8,R9,R10,R11,R12,R13,R14|midibox:1206-R|C17958|basic| | ||
+ | |10K|Ra1,Ra2,R5,R6|midibox:1206-R|C17902|basic|| | ||
+ | |100K|Rf1,Rf15|midibox:1206-R|C17900|basic|| | ||
+ | |DIPCOREF4_52P|U1|dipcore-V2C:dipCoreF4_v2c-52p-DIP-40-CMPNT_CORE_52P| | ||
+ | |6N138|U2|midibox:DIP-8|||512-6N138M | | ||
+ | |MCP6002|U3|midibox:SOP-8_SOIC-8|C7377|basic| | ||
+ | |mouse-cut|cut1,cut2,cut3|midibox:mouse-cut| | ||
+ | ====== Building DIY ====== | ||
{{:phatline:Clk2aClk-midibox.jpg?1000|}}\\ | {{:phatline:Clk2aClk-midibox.jpg?1000|}}\\ | ||
**Midibox:**\\ | **Midibox:**\\ | ||
Line 49: | Line 90: | ||
* 2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks) | * 2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks) | ||
- | ====== on Protoboard ====== | + | ===== on Protoboard ===== |
here i have made it all on protoboard:\\ | here i have made it all on protoboard:\\ | ||
{{youtube>9m22V8tvMXs}}\\ | {{youtube>9m22V8tvMXs}}\\ | ||
Line 56: | Line 97: | ||
{{:phatline:clk2a2clk-proto-shematic.jpg?1000|}}\\ | {{:phatline:clk2a2clk-proto-shematic.jpg?1000|}}\\ | ||
- | + | ====== Firmware ===== | |
- | ==== Frontpanels ==== | + | |
- | ==== MBHP ==== | + | |
- | ====== Software ====== | + | |
- | ===== Firmware ==== | + | |
V1.2017{{:phatline:clk2a2clk.zip|}} | V1.2017{{:phatline:clk2a2clk.zip|}} | ||
hardcodet no menue, no nothing, stripped down to max performance\\ | hardcodet no menue, no nothing, stripped down to max performance\\ |
