cv1
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
cv1 [2021/01/02 02:17] – [BOM] phatline | cv1 [2021/03/10 13:34] (current) – phatline | ||
Line 3: | Line 3: | ||
Control Voltage Recorder, Looper, and Generator - for a own Eurorack-Line... more in Future!\\ | Control Voltage Recorder, Looper, and Generator - for a own Eurorack-Line... more in Future!\\ | ||
- | --this picture is the first prototype - pre-Eurorack :-D | + | --this picture is the first prototype - pre-Eurorack :-D\\ |
+ | [[https:// | ||
===== Features ===== | ===== Features ===== | ||
* A Envelope which can be Recored from an AIN-Source, it can be Editet on Startpoint, | * A Envelope which can be Recored from an AIN-Source, it can be Editet on Startpoint, | ||
Line 11: | Line 13: | ||
* Copy, Paste, Clear: to Transfair the CV Sequence to other CV1 Instances\\ | * Copy, Paste, Clear: to Transfair the CV Sequence to other CV1 Instances\\ | ||
* ProgramChange Load and Store on microSD-Card, | * ProgramChange Load and Store on microSD-Card, | ||
- | * The Sequencer can be set to Tact Systems: 3/4 4/4 5/4 7/4 9/4 11/4 13/4 | + | * The Sequencer can be set to Tact Systems: 3/4 4/4 5/4 7/4 9/4 11/4 13/4\\ |
+ | --First Prototyp with a fiew modifications\\ | ||
====== Hardware Requirements ====== | ====== Hardware Requirements ====== | ||
Line 43: | Line 50: | ||
====== Building ====== | ====== Building ====== | ||
+ | The Design is optimized for Pick and Place most SMD Parts are on the Top-PCB\\ | ||
+ | i ordered 5 PCBs from JLCPCP with almost all SMD Parts (except 10pF µSD and 4x100nF) presoldered\\ | ||
+ | now waiting for Presoldered PCBs LOL - for 15€ a Piece!\\ | ||
+ | The Resistors for the LEDs are under the top LCD, so test your LED brightnes before soldering the Top-LCD\\ | ||
+ | You can remove | ||
==== Frontpanel ==== | ==== Frontpanel ==== | ||
Line 54: | Line 65: | ||
===== BOM ===== | ===== BOM ===== | ||
- | ^Designator^Footprint^LCSC Part Number^Library Type^Mouser | + | FIXME the 22R Resistors should be 220, the Green LEDs are still to bright even with 440 Ohm Resistors...\\ |
- | |100nF|C110|1206|C24497|basic|| | + | ^Value^Designator^Footprint^LCSC Part Number^Library-Type^Mouser^ |
+ | |100nF|C110|1206|C24497|basic| | ||
|10uF|C1116, | |10uF|C1116, | ||
- | |10pF|C17, | + | |10pF|C17, |
|1N4148W|D1, | |1N4148W|D1, | ||
|ENC|ENC1-ENC5|ENC-PEC11R|||652-PEC11R-4015F-S24| | |ENC|ENC1-ENC5|ENC-PEC11R|||652-PEC11R-4015F-S24| | ||
- | |5x2-AOUT|J19|Header-2x5|||| | + | |5x2-AOUT|J19|Header-2x5| |
- | |BootLoad|J2|Header-1x2|||| | + | |BootLoad|J2|Header-1x2| |
- | |DinDout|J89|Header-2x5|||| | + | |DinDout|J89|Header-2x5| |
- | |HEADER_3|JAIN1|Header-1x3|||| | + | |HEADER_3|JAIN1|Header-1x3| |
- | |Header-1x4|JAIN2|Header-1x4-female|||| | + | |Header-1x4|JAIN2|Header-1x4-female| |
- | |Header-1x4|JAIN3|Header-1x4|||| | + | |Header-1x4|JAIN3|Header-1x4| |
- | |CV1|JAUT1, | + | |CV1|JAUT1, |
- | |CV-OUT1|JAUT3|Header-1x2|||| | + | |CV-OUT1|JAUT3|Header-1x2| |
- | |BiOff|JG1|Header-1x2|||| | + | |BiOff|JG1|Header-1x2| |
- | |Gain|JG2, | + | |Gain|JG2, |
- | |Disconnect|JG4|Header-1x2|||| | + | |Disconnect|JG4|Header-1x2| |
- | |Offset|JG5|Header-1x2|||| | + | |Offset|JG5|Header-1x2| |
- | |Foot|JG6|Header-1x2|||| | + | |Foot|JG6|Header-1x2| |
- | |Gates|JGate1|Header-2x3|||| | + | |Gates|JGate1|Header-2x3| |
- | |OLED3-6|JLCD1|Header-2x7|||| | + | |OLED3-6|JLCD1|Header-2x7| |
- | |Midi|JMidi1|Header-2x3|||| | + | |Midi|JMidi1|Header-2x3| |
- | |Header-2x8-eurorack|Jpsu1|Header-2x8|||| | + | |Header-2x8-eurorack|Jpsu1|Header-2x8| |
- | |DIPCOREF4_52P|M1|dipCoreF4_v2c-52p-DIP-40MPNT_CORE_52P|||| | + | |DIPCOREF4_52P|M1|dipCoreF4_v2c-52p-DIP-40MPNT_CORE_52P|||Antichambre| |
- | |uSD_DM3ATDM3AT|M2|uSD-DM3AT-SF-PEJM5|||798-DM3AT-SF-PEJM5 | | + | |uSD_DM3ATDM3AT|M2|uSD-DM3AT-SF-PEJM5|||798-DM3AT-SF-PEJM5| |
- | |6N138|M3|DIP-8|||512-6N138M | | + | |6N138|M3|DIP-8|||512-6N138M| |
- | |LED-Green|Menue-1, | + | |LED-Green|Menue-1, |
- | |OLED|OLED1, | + | |OLED|OLED1, |
- | |PTC|PTC1|1206|C126818|extended|| | + | |PTC|PTC1|1206|C126818|extended| |
- | |10K|R28, | + | |10K|R28, |
- | |49K9|R30-R40, | + | |49K9|R30-R40, |
- | |30K|R41, | + | |30K|R41, |
- | |130K|R59|1206|C17893|extended|| | + | |130K|R59|1206|C17893|extended| |
- | |100K|R60|1206|C17900|basic|| | + | |100K|R60|1206|C17900|basic| |
- | |1K|R1-R7|1206|C4410|basic|| | + | |1K|R1-R7|1206|C4410|basic| |
- | |4K7|R8|1206|C17936|basic|| | + | |4K7|R8|1206|C17936|basic| |
- | |220|R9-R27, | + | |220|R9-R27, |
- | |Trim-3224W-1-104E|RV1, | + | |Trim-3224W-1-104E|RV1, |
- | |Trim-3214W-1-253E|RV3|Trimmer-3214W_Vertical|||652-3214W-1-253E | | + | |Trim-3214W-1-253E|RV3|Trimmer-3214W_Vertical|||652-3214W-1-253E| |
- | |74HC595|S1-S3|SOP-16_SOIC-16|C5947|basic|| | + | |74HC595|S1-S3|SOP-16_SOIC-16|C5947|basic| |
- | |74HC165|S4, | + | |74HC165|S4, |
- | |TL072|U2, | + | |TL072|U2, |
- | |MCP6002|U6|SOP-8_SOIC-8|C7377|basic|| | + | |MCP6002|U6|SOP-8_SOIC-8|C7377|basic| |
+ | ===== Shematic ===== | ||
===== To Do ===== | ===== To Do ===== | ||
a housing/ | a housing/ | ||
Line 103: | Line 119: | ||
====== Community users working on it ====== | ====== Community users working on it ====== | ||
- | * **[[Phatline]]** = Programming, | + | * **[[Phatline]]** = |
Just let a Private message on the forum to user already involved.\\ | Just let a Private message on the forum to user already involved.\\ | ||
I have ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage\\ | I have ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage\\ |
cv1.txt · Last modified: 2021/03/10 13:34 by phatline
