cv1 [2021/01/04 20:26] phatline [BOM] |
cv1 [2021/03/10 13:33] phatline |
Line 2: | Line 2: | ||
CV-Recorder/Looper & CV-Generator\\ | CV-Recorder/Looper & CV-Generator\\ | ||
Control Voltage Recorder, Looper, and Generator - for a own Eurorack-Line... more in Future!\\ | Control Voltage Recorder, Looper, and Generator - for a own Eurorack-Line... more in Future!\\ | ||
+ | {{:phatline:CV1-Proto-Front.jpg?700|}}\\ | ||
+ | --First Prototyp with a fiew modifications\\ | ||
{{:phatline:CV1-Case-Proto0.jpeg?500|}}\\ | {{:phatline:CV1-Case-Proto0.jpeg?500|}}\\ | ||
--this picture is the first prototype - pre-Eurorack :-D | --this picture is the first prototype - pre-Eurorack :-D | ||
+ | [[https://youtu.be/pwgeu4ws50o|very-early-version...k]] | ||
===== Features ===== | ===== Features ===== | ||
* A Envelope which can be Recored from an AIN-Source, it can be Editet on Startpoint,ATK-Playbackrate, Decay-Playbackrate\\ | * A Envelope which can be Recored from an AIN-Source, it can be Editet on Startpoint,ATK-Playbackrate, Decay-Playbackrate\\ | ||
Line 48: | Line 52: | ||
{{:phatline:CV1-PCB-3D-Front.png?500|}}\\ | {{:phatline:CV1-PCB-3D-Front.png?500|}}\\ | ||
{{:phatline:CV1-PCB-3D-Back.png?500|}}\\ | {{:phatline:CV1-PCB-3D-Back.png?500|}}\\ | ||
+ | The Resistors for the LEDs are under the top LCD, so test your LED brightnes before soldering the Top-LCD\\ | ||
+ | You can remove LCD later but, it is hard! and you may damage the LCD or the PCB...\\ | ||
==== Frontpanel ==== | ==== Frontpanel ==== | ||
Line 57: | Line 62: | ||
===== BOM ===== | ===== BOM ===== | ||
+ | FIXME the 22R Resistors should be 220, the Green LEDs are still to bright even with 440 Ohm Resistors...\\ | ||
^Value^Designator^Footprint^LCSC Part Number^Library-Type^Mouser^ | ^Value^Designator^Footprint^LCSC Part Number^Library-Type^Mouser^ | ||
|100nF|C110|1206|C24497|basic| | |100nF|C110|1206|C24497|basic| | ||
Line 102: | Line 108: | ||
===== Shematic ===== | ===== Shematic ===== | ||
- | {{ :phatline:cv1-shematic.png?800|}} | + | {{:phatline:cv1-shematic.png?800|}}\\ |
===== To Do ===== | ===== To Do ===== | ||
a housing/case or frontplate\\ | a housing/case or frontplate\\ | ||
Line 109: | Line 116: | ||
====== Community users working on it ====== | ====== Community users working on it ====== | ||
- | * **[[Phatline]]** = Programming, Documentation...\\ | + | * **[[Phatline]]** = Prototype, Shematic, PCB, Programming, Documentation, all...\\ |
Just let a Private message on the forum to user already involved.\\ | Just let a Private message on the forum to user already involved.\\ | ||
I have ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage\\ | I have ProtoBoards here - i test one, and if it works, i can share them for Beta Testing-if you pay the postage\\ |
