dipboardf4 [2018/10/05 18:47] antichambre [BOM] |
dipboardf4 [2018/11/03 01:49] phatline [BOM] |
Line 9: | Line 9: | ||
* The [[dipcoref4|dipCoreF4]] can be installed on the two side. | * The [[dipcoref4|dipCoreF4]] can be installed on the two side. | ||
* Provides all the most important features and ports for regular mbhp. | * Provides all the most important features and ports for regular mbhp. | ||
- | * Compatible with latigid on's [[wcore_usb|USB]] and [[wcore_res-sd|RES-SD]] modules. | + | |
==== Dimension ==== | ==== Dimension ==== | ||
Line 43: | Line 43: | ||
version 1. | version 1. | ||
Mouser BOM:<wrap round todo 7%>toDo</wrap> | Mouser BOM:<wrap round todo 7%>toDo</wrap> | ||
- | ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ | + | ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^LCSC^Notes^ |
^Resistors^^^^^^^^^ | ^Resistors^^^^^^^^^ | ||
- | |2 |680R 5% |0603 |R1, R2 | | | | |Depends on Leds | | + | |2 |680R 5% |0603 |R1, R2 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V |
- | |4 |1K 5% |0603 |R3, R4, R5, R6 | | | | |R3 if you use CAN without transceiver| | + | ]] | | |[[https://lcsc.com/product-detail/Chip-Resistor-Surface-Mount_680R-681-5_C103784.html|C103784]] |Depends on Leds | |
+ | |4 |1K 5% |0603 |R3, R4, R5, R6 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ102?qs=%2fha2pyFadujPfy170iHVGEtMFtzogPGwOHcYAAOLl%2f9T6PIvTHXpgQ%3d%3d|755-ESR03EZPJ102 ]] | | |[[https://lcsc.com/product-detail/Others_ROHM-Semicon_ESR03EZPJ102_ROHM-Semicon-ESR03EZPJ102_C253329.html|C253329 ]] |R3 if you use CAN without transceiver| | ||
^PTC fuses, resettable thermistors^^^^^^^^^ | ^PTC fuses, resettable thermistors^^^^^^^^^ | ||
- | |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | | + | |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | |[[https://lcsc.com/product-detail/PTC-Resettable-Fuses_TLC-Electronic-TLC-NSMD150_C261956.html| |
+ | C261956]] | | | ||
^Capacitors^^^^^^^^^ | ^Capacitors^^^^^^^^^ | ||
- | |1 |100n |0603|C2 | | | | | | | + | |1 |100n |0603|C2 |[[https://www.mouser.fr/ProductDetail/KEMET/C0603C104Z3VACTU?qs=sGAEpiMZZMs0AnBnWHyRQFqPnX0Olvco%252bYoiWDWTaEY%3d| 80-C0603C104Z3V |
- | |1 |47u |SMC_B|C1 | | | | | | | + | ]] | | | [[https://lcsc.com/product-detail/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT_SAMSUNG_CL10F104ZB8NNNC_100nF-104-80-20-50V_C1688.html| |
+ | C1688]] | | | ||
+ | |1 |47u Tantalum |SMC_B(1210)|C1 |[[https://www.mouser.fr/ProductDetail/Vishay-Sprague/TMCMB1C476MTRF?qs=sGAEpiMZZMuEN2agSAc2pqyLMxN%252bdaSr1ZUobrj8juKxspNLmKYGKA%3d%3d| | ||
+ | 74-TMCMB1C476MTRF ]] | | | [[https://lcsc.com/product-detail/Tantalum-Capacitors_47uF-476-10-16V_C112105.html|C112105]] | | | ||
^Diode^^^^^^^^^ | ^Diode^^^^^^^^^ | ||
- | |1 |1N4148WS|SOD323-W|D1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | | |Only if you use CAN without transceiver | | + | |1 |1N4148WS|SOD323-W|D1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | |[[https://lcsc.com/product-detail/Switching-Diode_1N4148WS_C108805.html| |
+ | C108805]] |Only if you use CAN without transceiver | | ||
^LEDs^^^^^^^^^ | ^LEDs^^^^^^^^^ | ||
- | |2 |--|0805 |5V, 3V3 | | | | | | | + | |2 |--|0805 |5V, 3V3 |[[https://www.mouser.fr/ProductDetail/755-SML-H12U8TT86C|755-SML-H12U8TT86C]] | | |[[https://lcsc.com/product-detail/Light-Emitting-Diodes-LED_0805-Red-LED-Iv-61mcd-Typ-atIF-20mA_C72037.html|C72037]] | | |
^dipCoreF4 socket^^^^^^^^^ | ^dipCoreF4 socket^^^^^^^^^ | ||
- | |2 |1x20 |low profile female| |[[https://www.mouser.fr/ProductDetail/517-929870-01-20-RA| 517-929870-01-20-RA]] | | | |for pads 1 to 40| | + | |2 |1x20 |low profile female| |[[https://www.mouser.fr/ProductDetail/517-929870-01-20-RA| 517-929870-01-20-RA]] | |[[https://lcsc.com/product-detail/Female-Header_2-54mm-1-40P-round-Female-header_C9811.html|C9811]] | |for pads 1 to 40| |
- | |2 |1x5 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-05-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudfRsikv%252bK%252bu4%3d|517-929870-01-05-RA ]] | | | |for pads 41 to 50| | + | |2 |1x5 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-05-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudfRsikv%252bK%252bu4%3d|517-929870-01-05-RA ]] | | |no need |for pads 41 to 50| |
- | |1 |1x2 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-02-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudnrpQb%2fhOxhg%3d|517-929870-01-02-RA ]] | | | |for pads 51 to 52| | + | |1 |1x2 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-02-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudnrpQb%2fhOxhg%3d|517-929870-01-02-RA ]] | | |[[https://lcsc.com/product-detail/Female-Header_2-54mm-1-40P-round-Female-header_C9811.html|C9811]] |for pads 51 to 52| |
^Connector^^^^^^^^^ | ^Connector^^^^^^^^^ | ||
|1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | |Place on top | | |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | |Place on top | | ||
Line 74: | Line 80: | ||
^Option 3 - Micro-Match Paddle Board for low profile connector^^^^^^^^^ | ^Option 3 - Micro-Match Paddle Board for low profile connector^^^^^^^^^ | ||
|3 |2x3 |IDC|J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215570-6?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgk4IYNQOS%252bLA%3d|571-7-215570-6 ]] | | | |Place on top| | |3 |2x3 |IDC|J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215570-6?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgk4IYNQOS%252bLA%3d|571-7-215570-6 ]] | | | |Place on top| | ||
- | |4 |2x5 |IDC|J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-0?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg0iDJ6yhwCXo%3d|571-8-215570-0 ]] | | | |Place on top| | + | |4 |2x5 |IDC|J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/1-215570-0?qs=%2fha2pyFadugJp%2f0oQpeWgQoBAIcoVeLwPA9Q24%252b5JCu6XAik%252bX4WtA==|571-1-215570-0 ]] | | | |Place on top| |
|1 |2x7 |IDC|J16E |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg2wTWzyi6GTY%3d| | |1 |2x7 |IDC|J16E |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215570-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg2wTWzyi6GTY%3d| | ||
571-8-215570-4 ]] | | | |Place on top| | 571-8-215570-4 ]] | | | |Place on top| | ||
Line 87: | Line 93: | ||
===== Compatible/stack-able boards options ===== | ===== Compatible/stack-able boards options ===== | ||
+ | * All [[http://ucapps.de/|uCapps]] mbhp modules are compatibles. | ||
+ | * [[dipboardf4_modules|USB, SD-Card, External Power and MCAN modules]] are available. | ||
* [[m16|M16 Interface]], stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO 8-) | * [[m16|M16 Interface]], stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO 8-) | ||
- | <wrap todo>toDo</wrap> | + | |
+ | For any questions, informations or observations do not hesitate to contact me (Forum).\\ | ||
+ | [[antichambre|Antichambre.]]\\ |
