dipcoref4 [2018/09/04 16:58] antichambre [PCB] |
dipcoref4 [2018/09/27 11:07] antichambre [Features] |
Line 10: | Line 10: | ||
* Same internal hardware as Disco or wCore (speed, memory, peripherals, etc...) . | * Same internal hardware as Disco or wCore (speed, memory, peripherals, etc...) . | ||
* Board pinout and package compatible with a MIOS8 PIC 8-) | * Board pinout and package compatible with a MIOS8 PIC 8-) | ||
- | * USB connector onboard. | + | * USB connector onboard. 2 OTG are available, second(new) USB is Host only. |
* 5V power input and led. | * 5V power input and led. | ||
* 3.3V regulator and led on board. | * 3.3V regulator and led on board. | ||
Line 16: | Line 16: | ||
* User and Reset buttons. | * User and Reset buttons. | ||
* 2 user leds. | * 2 user leds. | ||
- | * 8 extra pins for USB, buttons and leds. | + | * 12 extra pins for USB, buttons and leds. |
* Your favorite Core is now a current component easy to integrate. | * Your favorite Core is now a current component easy to integrate. | ||
All commons MIOS32 ports are available except: | All commons MIOS32 ports are available except: | ||
* General purpose J10x ports were removed. | * General purpose J10x ports were removed. | ||
- | * LCD port was reduced to a serial one, no more pins J15.D0-D7 | + | * LCD port was reduced to a serial one, no more pins J15.D0-D7 , no back-light power supply. |
* 2 UART only(2 MIDI In/2Out). | * 2 UART only(2 MIDI In/2Out). | ||
* 2 AIN channels only(e.g. pedal inputs) | * 2 AIN channels only(e.g. pedal inputs) | ||
Line 27: | Line 27: | ||
+ | ===== Download ===== | ||
+ | dipCoreF4 eagle lib for easy integration in your design. <wrap download> | ||
+ | {{ :antichambre:dipcoref4_beta.zip |}} | ||
+ | </wrap> | ||
Line 73: | Line 77: | ||
{{ :antichambre:pinout_compare_chart.png?120 |}} | {{ :antichambre:pinout_compare_chart.png?120 |}} | ||
<wrap download> | <wrap download> | ||
- | [[https://www.dropbox.com/s/eo3klb33xpp7law/1808_dipCore32_PinoutsAndFunctions.xls?dl=1|xls chart]] | + | [[https://www.dropbox.com/s/5jc3smxbg7hxno0/1809_dipCoref4_PinoutsAndFunctions.xls?dl=1|xls chart]] |
</wrap> | </wrap> | ||
</WRAP> | </WRAP> |
