dipcoref4 [2018/09/06 13:36] antichambre [Features] |
dipcoref4 [2018/10/03 13:29] antichambre [PCB] |
Line 10: | Line 10: | ||
* Same internal hardware as Disco or wCore (speed, memory, peripherals, etc...) . | * Same internal hardware as Disco or wCore (speed, memory, peripherals, etc...) . | ||
* Board pinout and package compatible with a MIOS8 PIC 8-) | * Board pinout and package compatible with a MIOS8 PIC 8-) | ||
- | * USB connector onboard. | + | * USB connector onboard. 2 OTG are available, second(new) USB is Host only. |
* 5V power input and led. | * 5V power input and led. | ||
* 3.3V regulator and led on board. | * 3.3V regulator and led on board. | ||
Line 16: | Line 16: | ||
* User and Reset buttons. | * User and Reset buttons. | ||
* 2 user leds. | * 2 user leds. | ||
- | * 8 extra pins for USB, buttons and leds. | + | * 12 extra pins for USB, buttons and leds. |
* Your favorite Core is now a current component easy to integrate. | * Your favorite Core is now a current component easy to integrate. | ||
Line 63: | Line 63: | ||
</WRAP>\\ | </WRAP>\\ | ||
+ | ===== BOM v1.0 ===== | ||
+ | ^Type ^Qty ^Value ^Package ^Parts^Mouser^Reichelt^Conrad^Other^Notes^ | ||
+ | ^Resistors^^^^^^^^^^ | ||
+ | | |6 |100-220R 5% |THT |R1-6 | | | | | | | ||
+ | ^Resistor network^^^^^^^^^^ | ||
+ | | |1 |10k |SOM16 |RN1 |4816P-T02-103LF | | | | | | ||
+ | ^Capacitors^^^^^^^^^^ | ||
+ | | |3 |100n |1206 |C1-3 | | | | | | | ||
+ | ^Diodes^^^^^^^^^^ | ||
+ | | |19 |1N4148 |THT | | | | | | | | ||
+ | ^LEDs^^^^^^^^^^ | ||
+ | | |18 |various |3mm | | | | | |insert into switches | | ||
+ | ^ICs^^^^^^^^^^ | ||
+ | | |1 |74HC165|SOIC16 |IC2 |595-SN74HC165DR | | | | | | ||
+ | | |2 |74HC595|SOIC16 |IC1, IC3 | | | | | | | ||
+ | ^Encoder^^^^^^^^^^ | ||
+ | | |1 |STEC12| | | |STEC12E08 | | | | | ||
+ | ^Switches^^^^^^^^^^ | ||
+ | | |18 |MEC/APEM |3FTH9 |SW1-18 |642-3FTH9 |TASTER 3FTH9 |705276 - 62 | | | | ||
+ | ^Headers^^^^^^^^^^ | ||
+ | | |1 |1*3 | male | | | | | | | | ||
+ | | |2 |2*5 | male | | | | | | | | ||
+ | ^Hardware^^^^^^^^^^ | ||
+ | | |6 |M3 spacer |TBD | | | | | | | | ||
+ | | |1 |datawheel |DK-38? | | | | | | | | ||
+ | | |0 |switchcaps |22.5mm | |642-1S11-22.5 | |1S11-22.5 | |original parts, when using taller jogwheel. See next line | | ||
+ | | |18 |switchcaps |19mm | |642-1S11-19.0 | |1S11-19.0 | |waiting on case, but probably the 19mm caps will be used here too | | ||
Line 77: | Line 104: | ||
{{ :antichambre:pinout_compare_chart.png?120 |}} | {{ :antichambre:pinout_compare_chart.png?120 |}} | ||
<wrap download> | <wrap download> | ||
- | [[https://www.dropbox.com/s/eo3klb33xpp7law/1808_dipCore32_PinoutsAndFunctions.xls?dl=1|xls chart]] | + | [[https://www.dropbox.com/s/5jc3smxbg7hxno0/1809_dipCoref4_PinoutsAndFunctions.xls?dl=1|xls chart]] |
</wrap> | </wrap> | ||
</WRAP> | </WRAP> |
