dout_module_digital_output [2006/05/01 15:17] moebius |
dout_module_digital_output [2007/11/18 15:27] audiocommander Added connection to core module pic, reformatted |
Line 1: | Line 1: | ||
- | * [[http://www.ucapps.de/mbhp_dout.html|DOUT Module]] <sup>uCApps</sup>\\ | + | ====== General Informations ====== |
- | * [[DIN & DOUT Pintable]] | + | |
+ | A DOUT module is a digital output module, usually used to drive LEDs with a Midibox. | ||
+ | * [[http://www.ucapps.de/mbhp_dout.html|DOUT Module]] <sup>uCApps</sup>\\ | ||
+ | * [[DIN & DOUT Pintable]] | ||
+ | ====== Connection to Core Module ====== | ||
+ | Check the version of your Boards; if you’re using SmashTV’s Core that’s equipped with double rows, you can build a split-cable to connect J8/J9 to a DIN and a DOUT: | ||
+ | {{http://www.audiocommander.de/picBrowser/galleries/070707_ACSensorizer/CORE_DIN_DOUT_J8J9_Cable.png}} | ||
