Both sides previous revisionPrevious revisionNext revision | Previous revisionNext revisionBoth sides next revision |
eagle3d_midibox_user_pack [2009/01/23 18:03] – Jack | eagle3d_midibox_user_pack [2009/02/22 23:16] – Jack |
~~NOTOC~~ | |
====== Eagle3D MIDIBox User Pack ====== | ====== Eagle3D MIDIBox User Pack ====== |
===== 3dusrpac.dat ===== | ===== 3dusrpac.dat ===== |
| Just copy the code below to your 3dusrpac.dat and user.inc. |
| ==== known packages (not assigned in the 3dpack.dat): ==== |
| <code> |
| HEADER1X2:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:PH_1X2(:Stiftleiste 2,54mm Raster 2Pin 1Reihe (pinhead.lib):Header 2,54mm Grid 2Pin 1Row (jumper.lib) |
| HEADER1X3:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:PH_1X3(:Stiftleiste 2,54mm Raster 3Pin 1Reihe (pinhead.lib):Header 2,54mm Grid 3Pin 1Row (jumper.lib) |
| HEADER1X4:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:PH_1X4(:Stiftleiste 2,54mm Raster 4Pin 1Reihe (pinhead.lib):Header 2,54mm Grid 4Pin 1Row (jumper.lib) |
| HEADER2X5-NO:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:PH_2X5(:Stiftleiste 2,54mm Raster 5Pin 2Reihen (pinhead.lib):Header 2,54mm Grid 5Pin 2Row (jumper.lib) |
| HEADER2X5:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:CON_DIS_WS10G(:Wannenstecker 10Pin:Shrouded Header 10Pin |
| HEADER2X8:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:CON_DIS_WS16G(:Wannenstecker 16Pin:Shrouded Header 16Pin |
| HEADER2X10:0:0:0:0:0:0:0:0:0:0:0:0:0:-90:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:CON_DIS_WS20G(:Wannenstecker 20Pin:Shrouded Header 20Pin |
| CA6V:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:RES_DIS_TRIM_PT10_H_10(:PT10:PT10 |
| </code> |
| ==== new packages: ==== |
<code> | <code> |
DT6:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_DT6(:Taster Switch-MISC:Tactile Switch-MISC | DT6:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_DT6(:Taster Switch-MISC:Tactile Switch-MISC |
STEC16:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_STEC16(:STEC16 Encoder:STEC16 Encoder | STEC16:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_STEC16(:STEC16 Encoder:STEC16 Encoder |
3310LCD:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_3310LCD(:3310LCD Midibox:3310LCD Midibox | 3310LCD:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_3310LCD(:3310LCD Midibox:3310LCD Midibox |
| LED_RING:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:USER_LED_RING(: |
</code> | </code> |
===== user.inc ===== | ===== user.inc ===== |
==== DT6 ==== | ==== DT6 ==== |
| {{:dt6.png|}} |
<code c#> | <code c#> |
==== ALPS STEC16B03-04 ==== | ==== ALPS STEC16B03-04 ==== |
| {{:enc_alps_stec16.png|}} |
#end | #end |
</code> | </code> |
| ==== LEDRING TEST ==== |
| <code c#> |
| //LED_RING_TEST |
| //Jack from forum.midibox.org |
| #macro USER_LED_RING() |
| union{ |
| #declare X = 0.1; //littlemore |
| #declare H0 = 0; //Body startpoint |
| #declare H1 = 1.5; //Body Height |
| #declare H20 = H1+X; //Glas startpoint |
| #declare H2 = H20+0.5; //Glas Height |
| #declare H10 = H1-0.25; //Glas Height |
| #declare DF = 0.9; //Diffuse |
| #declare P1 = 0.5; //Phong |
| #declare C1 = Grey; //Color (Grey) |
| #declare R1 = 17.78; //R.0700 outer radius |
| #declare R2 = 10.16; //R0.400 inner radius |
| #declare R3 = 13.97; //R.550 center radius |
| #declare LW = 0.75; //LED hole width / 2 (1,27) |
| #declare LL = 2.00; //LED hole length /2 (2,54) |
| #declare AS = 15; //angle steps |
| #declare A0 = 0; //angle 0 |
| #declare A1 = 75; //start angle 1 |
| #declare A2 = A1+AS; //angle 2 |
| #declare A3 = A2+AS; //angle 3 |
| #declare A4 = A3+AS; //angle 4 |
| #declare A5 = A4+AS; //angle 5 |
| #declare A6 = A5+AS; //angle 6 |
| #declare A7 = A6+AS; //angle 7 |
| #declare A8 = A7+AS; //angle 8 |
| #declare A9 = A8+AS; //angle 9 |
| #declare A10 = A9+AS; //angle 10 |
| #declare A11 = A10+AS; //angle 11 |
| #declare A12 = A11+AS; //angle 12 |
| #declare A13 = A12+AS; //angle 13 |
| #declare A14 = A13+AS; //angle 14 |
| #declare A15 = A14+AS; //angle 15 |
| difference{ |
| union{ |
| cylinder {<0,H0,0>,<0,H1,0>, R1 texture{pigment{color Black}finish {diffuse DF phong P1}}} |
| union{ |
| cylinder {<0,H0-X>,<0,H1+X>, R2} |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A0,0>} //1 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A1,0>} //2 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A2,0>} //3 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A3,0>} //4 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A4,0>} //5 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A5,0>} //6 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A6,0>} //7 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A7,0>} //8 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A8,0>} //9 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A9,0>} //10 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A10,0>} //11 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A11,0>} //12 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A12,0>} //13 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A13,0>} //14 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A14,0>} //15 |
| box {<-LW,H0-X,-LL>,<+LW,H1+X,LL> translate< 0,0,R3> rotate<0,A15,0>} //16 |
| /* difference{ |
| cylinder {<0,H20,0>,<0,H2,0>, R1 texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} |
| cylinder {<0,H20-X,0>,<0,H2+X>, R2} |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A0,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //1 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A1,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //2 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A2,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //3 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A3,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //4 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A4,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //5 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A5,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //6 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A6,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //7 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A7,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //8 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A8,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //9 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A9,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //10 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A10,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //11 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A11,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //12 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A12,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //13 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A13,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //14 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A14,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //15 |
| box {<-LW,H10,-LL>,<+LW,H1,LL> translate< 0,0,R3> rotate<0,A15,0> texture{pigment{color C1 transmit 0.5} finish {diffuse DF phong P1}}} //16 |
| rotate<0,180,0> |
| #end |
| </code> |
| ===== POV-Ray tweaks ===== |
| For better image quality, change the file "quickres.ini" in "<POV-RAY directory>/renderer": |
| <code> |
| [1280x1024, AA 20x0.3] |
| Width=1280 |
| Height=1024 |
| Antialias=on |
| Antialias_Threshold=0.1 |
| Antialias_Depth=20 |
| </code> |
| ===== Wish List ===== |
| * MEC switch 3FTL6 |
| * MEC cap 1U |
