Differences
Both sides previous revisionPrevious revision | Next revisionBoth sides next revision |
eclipse [2012/07/16 23:46] – duggle | eclipse [2012/07/16 23:54] – duggle |
The following is used in this section:\\ | The following is used in this section:\\ |
**core:**................STM32\\ | **core:**................STM32\\ |
**OS:**..................windows 7 x64\\ | **OS:**..................windows 7 x64 //WinXP should work the same use with OpenOCD 0.5.0 (non x64)//\\ |
**toolchain:**......mios32_toolchain (mentioned in the wiki). //Ensure that workspace environment PATH includes e.g C:\mios32_toolchain\bin//\\ | **toolchain:**......mios32_toolchain (mentioned in the wiki). //Ensure that workspace environment PATH includes e.g C:\mios32_toolchain\bin//\\ |
**IDE:**.................Eclipse (Indigo)\\ | **IDE:**.................Eclipse (Indigo) //later versions will probably not work at this point//\\ |
**OpenOCD:**.......0.5.0 x64 [[http://www.freddiechopin.info/en/download/category/4-openocd|Download]]\\ | **OpenOCD:**.......0.5.0 x64 [[http://www.freddiechopin.info/en/download/category/4-openocd|Download]]\\ |
**GDB:**.................Yagarto (gdb version 7.3.1)\\ | **GDB:**.................Yagarto (gdb version 7.3.1)//later versions should work//[[http://http://www.yagarto.de/#download|download]] \\ |
**JTAG:**................Amontec JTAGkey-tiny\\ | **JTAG:**................Amontec JTAGkey-tiny //many other brands and types of JTAG interface are supported by OpenOCD//\\ |
===== OpenOCD ===== | ===== OpenOCD ===== |
