envelope-follower-bissel-based [2021/01/05 22:38] phatline [Resources] |
envelope-follower-bissel-based [2021/01/05 22:59] phatline [To Do] |
Line 85: | Line 85: | ||
===== To Do ===== | ===== To Do ===== | ||
- | experiment with the Smooting CAP, i already implimented a Jumper which add a second Capacitor to "double" the capacity... i took 220+220nF, but maybe it is better to use 100+220nF?\\ | + | frontplate\\ |
- | experiment with the Frequency Pot which is a lin10K + 2K Serial Resistor which gives a range of 2K-12K - really dont know what value spectrum we need here!\\ | + | Debugging First Version\\ |
- | adding some Jumpers to break the circuit for debugging or measurement\\ | + | **experiment with the Smooting CAP:** a Header is connected paralell to a integrated 100nF Cap, connect there a CAP to encrease the smoothing\\ |
- | frontplate, Debugging First Version\\ | + | experiment with the Frequency Pot which is a lin10K + 1K Serial Resistor which gives a range of 1K-12K - i also made a Header here, which you can bridge then you have 1-12K, or you put a resistor there for example a 5K, then you will get a range from 6-16K... \\ |
+ | I addet some Jumpers to break the circuit for debugging or measurement\\ | ||
- | In order to Debug and Test and finetune the board i placed some **Headers/Jumpers:**\\ | + | Modding **Headers/Jumpers:**\\ |
{{:phatline:ENV-Follower-3D-top.png?800|}}\\ | {{:phatline:ENV-Follower-3D-top.png?800|}}\\ | ||
===== Resources ===== | ===== Resources ===== |
