fadercore_-_vlr-8enc [2014/07/26 13:46] novski |
fadercore_-_vlr-8enc [2014/07/27 09:18] novski |
Line 8: | Line 8: | ||
A PCB to add 8 Encoders with LED ring for each. | A PCB to add 8 Encoders with LED ring for each. | ||
+ | {{:fadercore_vlr-8enc_top_bestueckt.png?800|}} | ||
+ | Eagle Files: [[https://github.com/novski/Midibox/tree/master/VLR-8Enc]] | ||
- | Eagle Files: [[https://github.com/novski/Midibox/tree/master/VLR-8Disp]] | + | {{:fadercore_8enc_schematic_page_1.png?400|}} {{:fadercore_8enc_schematic_page_2.png?400|}} |
- | {{:fadercore_8odisp_schematic.png?800|}} | + | {{:fadercore_8enc_dimensions.png?800|}} |
- | {{:fadercore_8disp_measures.png?800|}} | + | |
==== BOM ==== | ==== BOM ==== | ||
- | BIll of Material | + | BIll of Material |
Allways look for the cheapest seller, the Price may vary heavy!!! | Allways look for the cheapest seller, the Price may vary heavy!!! | ||
- | And look for Local dealers preferred. | + | And look for Local dealers preferred. [[http://www.midibox.org/dokuwiki/doku.php?id=where_to_order_components]] |
- | == The OLEDs == | + | == The Encoders == |
- | I got those displays from this dealer: http://www.aliexpress.com/snapshot/207517549.html | + | I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. |
+ | Its not the cheapest but i sell them for a reasonable price. | ||
+ | **And its still possible to use a non Illuminated Encoder.** | ||
== The other Materials: Mouser == | == The other Materials: Mouser == | ||
- | * 2x10pin Header, 517-30310-6002 | + | * 2x10pin Header, 517-30310-6002 |
- | * 1x16pin Header, 517-30316-6002 | + | * 2xULN2803, 595-ULN2803ADWR |
- | * 2x8Pin DIP, 571-1-390261-4 | + | * 9x100nF,594-K104K15X7RF53K2 |
- | * 1xResistor Array 220Ohm, 652-4116R-1LF-220 | + | * 6x10k, 774-77061103P |
- | * 1x74HC595, 595-SN74HC595N | + | * 4x220, 652-4816P-T1LF-220 |
- | * 2x100nF, 505-MKS2.1/63/5 | + | * 3x220, 660-MF1/2LCT52R221J |
- | * 1x100uF, 667-ECE-A1EKA100 | + | * 3x74HC165D, 771-HC165D652 |
- | * 1x1kOhm, 660-MF1/4DCT52A1001F | + | * 3x74HC595D, 771-74HC595D |
- | * 8xFemale Header, 649-66953-008 | + | * 3xTPIC6B595, because the MOQ is 250 i deliver them for you with the PCB. |
+ | * 88xLED RED, 604-WP3A8HD | ||
+ | * 88xLED holder 6mm Height, 749-ELM-5-6MM | ||
- | Project Order Basket on Mouser: [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=0c73d90bd5]] | + | Project Order Basket on Mouser: [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=a6dbae9ab7]] |
- | The PCB is available under: [[https://vlrlab.com/pcb/10-8-odisplay.html]] | + | The PCB is available under: [[http://vlrlab.com/lang/17-8enc.html]] |
- | ==== How to get Started ==== | + | * 8 Encoder, 652-PEL12T4226FS1024 **not on Projectlist because i deliver cheaper and with cap included..** |
+ | The Encoder on VLRlabs.com [[https://www.vlrlab.com/encoder/13-bourns-rgb-led-encoder.html]] | ||
- | You will need to set the Connection of the Display. | ||
- | {{:fadercore_vlr8odisp_oled1.jpg?200|}} {{:fadercore_vlr8odisp_oled2.jpg?200|}} {{:fadercore_vlr8odisp_oled3.jpg?200|}} | + | ==== How to get Started ==== |
- | So all 3 Code Resistors need to be on the Left side... | + | If its your first SMD soldering you can follow this on t1:58 : http://www.youtube.com/watch?v=5uiroWBkdFY |
- | + | I recommend to not buy solder paste, instead buy some flux-paste like this on Mouser: 590-8341-10ML | |
- | If you don't like the LED on top you can de-solder it now. | + | |
==== Prepare the PCB ==== | ==== Prepare the PCB ==== | ||
+ | Start with the SMD parts and then go on the the conventional parts also on the Bottom side. Don't forget the R11,12,13. | ||
+ | Then go on with the Topside and the LEDs before soldering the Encoder as last. | ||
+ | Check the Connections with a Lens. | ||
- | The first PCB gets its Selection Lines from the Display Connection J15A on the Core PCB. So you will need to solder the 16Pin Header at this Panel. Here you can leave out the 10pin Headers and the IC Socket for the Shift register, if you like. | + | ==== Prepare the Connection ==== |
- | The Second PCB for Display 9-16 gets its Selection lines from the Shift register and doesn't need the 16pin Header so you have to solder J1 and J2 but you can leave out J0. | + | Connect the core on J8/9 to J1 of the VLR-8Enc board. |
- | For both use cases you need to stuff the Resistor array so its best to solder a 16pin IC-Socket and stuff it in that. | + | ==== Test it in MIOS ==== |
- | PCB 3&4 are same as the second. | + | To make it work with MIOS .NGC File we need to know how the shift-registers are connected. |
- | {{:fadercore_8disp_connections.png?1000|}} | + | **Inputs:**\\ |
+ | 1# Encoder 1-4\\ | ||
+ | 2# Encoder 5-8\\ | ||
+ | 3# Encoder Button 1-8\\ | ||
- | ==== Prepare the Connection ==== | + | **Outputs:**\\ |
+ | 1# RED Shaft LED 1-8\\ | ||
+ | 2# GREEN shaft LED 1-8\\ | ||
+ | 3# BLUE shaft LED 1-8\\ | ||
+ | 4# LED Ring Row 1-8\\ | ||
+ | 5# LED Ring Selct 1-8\\ | ||
+ | 6# LED Ring Select 9-11\\ | ||
- | How to connect it to the Core | + | Assuming that the VLR-8Enc is the first device on the chain of J8/9 we need to configure it like this: |
- | {{:screenshot_2014-07-26_14.51.49.png?600|}} | ||
- | ==== Test it in MIOS ==== |
