gm5x5x5_errata [2009/03/02 23:40] fossi.bs |
gm5x5x5_errata [2010/02/07 11:44] nils |
Line 1: | Line 1: | ||
This page lists the know errors on the gm5x5x5 PCBs. | This page lists the know errors on the gm5x5x5 PCBs. | ||
There are no known issues with the bulk order run (white pcbs), the following information is valid **only** for the prototype run (green pcbs). | There are no known issues with the bulk order run (white pcbs), the following information is valid **only** for the prototype run (green pcbs). | ||
+ | ==== Bulk Order #1 (white pcb, rev 1.0) ==== | ||
+ | === #1 Silkscreen error (reported by dioioib) === | ||
+ | **Problem**: The silkscreen has the EEPROM the wrong way around - Pin 1 should be facing IC5. | ||
+ | **Solution**: Stick the EEPROM in the other way around, with the "notch" facing IC5. | ||
==== Prototype Run ==== | ==== Prototype Run ==== | ||
Line 17: | Line 25: | ||
**Solution**: Bridge the pins. | **Solution**: Bridge the pins. | ||
