home:project:midimon [2008/12/09 09:55] martinsomerville |
home:project:midimon [2008/12/09 10:10] martinsomerville |
Line 12: | Line 12: | ||
[[http://www.ucapps.de/midimon_changelog.html|Midimon change log on ucapps]] | [[http://www.ucapps.de/midimon_changelog.html|Midimon change log on ucapps]] | ||
- | Type midimon [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. \\ | + | Type midimon or midimon* or midi_mon* [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. \\ |
Line 19: | Line 19: | ||
**Add links to photos!** | **Add links to photos!** | ||
- | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies like me a lot. | + | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies a lot. |
* Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | * Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | ||
