Both sides previous revision Previous revision | Next revision Both sides next revision | ||
home:skills:troubleshooting:firmware [2009/07/05 09:11] 87.194.188.147 |
home:skills:troubleshooting:firmware [2009/07/05 09:13] 87.194.188.147 |
Line 45: | Line 45: | ||
===== mbsid_led_matrix_test ===== | ===== mbsid_led_matrix_test ===== | ||
===== mbsid_testtone ===== | ===== mbsid_testtone ===== | ||
+ | SID Testtone generator | ||
+ | This MIOS application generates a simple 1kHz triangle testtone on the SID. | ||
+ | There is no "MIDI Note On" event required to start the sound, you should hear it immediately after the MIOS bootphase | ||
+ | In addition, a 1 kHz pulse will be generated on the CS lines to the two SIDs. This feature allows you to test the output amplifier of the | ||
+ | SID module (unplug SID, connect socket pin #8 with #27) | ||
===== mf_calibration ===== | ===== mf_calibration ===== | ||
===== mf_direct_control ===== | ===== mf_direct_control ===== |
