home:skills:troubleshooting:firmware [2009/07/05 09:11] 87.194.188.147 |
home:skills:troubleshooting:firmware [2009/07/05 21:16] 87.194.188.147 |
Line 39: | Line 39: | ||
The current pin name selected will show on the LCD (if connected). | The current pin name selected will show on the LCD (if connected). | ||
- | The pins are identified by : ___?___ | + | The pins are identified on the MB SID schematic: [[http://www.ucapps.de/mbhp/mbhp_sid_v3.pdf]] |
+ | i.e. | ||
+ | * RES# is pin 5 (anti-clockwise from the top left) | ||
+ | * CS# is pin 8 | ||
+ | * A0 is pin 9 | ||
+ | * A4 is pin 13 | ||
+ | * D0 is pin 15 | ||
+ | * D7 is pin 22 | ||
To measure the voltage (and test the connection to that pin is good), connect your multimeter's red lead to ___?___ and the black lead to ___?___ and select the pin using the modulation wheel. | To measure the voltage (and test the connection to that pin is good), connect your multimeter's red lead to ___?___ and the black lead to ___?___ and select the pin using the modulation wheel. | ||
Line 45: | Line 55: | ||
===== mbsid_led_matrix_test ===== | ===== mbsid_led_matrix_test ===== | ||
===== mbsid_testtone ===== | ===== mbsid_testtone ===== | ||
+ | SID Testtone generator | ||
+ | This MIOS application generates a simple 1kHz triangle testtone on the SID. | ||
+ | There is no "MIDI Note On" event required to start the sound, you should hear it immediately after the MIOS bootphase | ||
+ | In addition, a 1 kHz pulse will be generated on the CS lines to the two SIDs. This feature allows you to test the output amplifier of the | ||
+ | SID module (unplug SID, connect socket pin #8 with #27) | ||
===== mf_calibration ===== | ===== mf_calibration ===== | ||
===== mf_direct_control ===== | ===== mf_direct_control ===== |
