ju_control_roland_alpha_juno_control_panel_cs
Differences
ju_control_roland_alpha_juno_control_panel_cs [2012/09/05 10:15] – lemonhorse | ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:36] – lemonhorse | ||
Line 4: | Line 4: | ||
====== Project Description ====== | ====== Project Description ====== | ||
- | The MIDIBox JuCtrl is a Roland | + | The **MIDIBox JuCtrl** is a **Alpha Juno** MIDI Controller [[https:// |
====== Functions ====== | ====== Functions ====== | ||
* Control every Juno Tone Parameter with an encoder or button | * Control every Juno Tone Parameter with an encoder or button | ||
- | * Control one parameter (IPR) or send all parameter at once (APR) | + | * Control one parameter (Juno IPR Sysex) or send all parameter at once (Juno APR Sysex) |
- | * Store Juno patches (Tones) on Bankstick | + | * Store Juno patches (Tones) on Bankstick |
- | * Juno Tone parameter overview (via CS LCD & LED) | + | * Have a clearly arranged |
- | * MIDI processing: CC to sysex conversation | + | * MIDI processing: |
+ | * Use some extra Envelope functions (set all Envelope leve/time parameter to min or max & manipulate all time or level parameter at once with an encoder) | ||
Line 22: | Line 23: | ||
* 3x MBHP DINx4 | => ([[http:// | * 3x MBHP DINx4 | => ([[http:// | ||
* 1x MBHP IIC MIDI Module (extra MIDI IO for Juno Synth) IIC MIDI adr. = 0x10(J3 port) | => | * 1x MBHP IIC MIDI Module (extra MIDI IO for Juno Synth) IIC MIDI adr. = 0x10(J3 port) | => | ||
- | * 1-8x Bankstick | Store 128 Juno Tones [24256(32k)] => | + | * 1-8x Bankstick | Store 128-1024 Juno Tones [24256(32k)] => |
Line 29: | Line 30: | ||
* Ju Control CS (LED' | * Ju Control CS (LED' | ||
* Ju Control MBHP DIN & DOUT | => {{: | * Ju Control MBHP DIN & DOUT | => {{: | ||
- | * JuCtrl Juno MIDI IO Dataflow Overview | + | * JuCtrl Juno MIDI IO dataflow (overview) |
+ | ====== CC MIDI ====== | ||
+ | |MIDI CC 001 - MODULATION WHEEL | | ||
+ | |MIDI CC 002 - DCO ENV MODE | | ||
+ | |MIDI CC 003 - VCF ENV MODE | | ||
+ | |MIDI CC 004 - FOOD CONTROL | ||
+ | |MIDI CC 005 - PORTAMENTO TIME (REAL CC) | | ||
+ | |MIDI CC 006 - VCA ENV MODE | | ||
+ | |MIDI CC 007 - VOLUME (REAL CC) | | ||
+ | |MIDI CC 008 - DCO WAVEFORM Pulse (0..3) | ||
+ | |MIDI CC 009 - DCO WAVEFORM Saw (0..5) | ||
+ | |MIDI CC 010 - DCO SUB WAVEFORM | ||
+ | |MIDI CC 011 - DCO Range (0=4', 1=8', 2=16', 3=32' | ||
+ | |MIDI CC 012 - DCO Sub Osc Level (0..3) | ||
+ | |MIDI CC 013 - DCO Noise Level | ||
+ | |MIDI CC 014 - HPF Cutoff (0...3) | ||
+ | |MIDI CC 015 - Chorus Switch (0=Off, 1=On) | | ||
+ | |MIDI CC 016 - DCO LFO Modulation (0..7F) | ||
+ | |MIDI CC 017 - DCO Envelope Pitch Modulation Depth (0..7F) | ||
+ | |MIDI CC 018 - DCO Aftertouch Modulation Sensitivity (0..7F) | ||
+ | |MIDI CC 019 - DCO WAVE 3 PULSE WITH (0..7F) | ||
+ | |MIDI CC 020 - DCO WAV3 PWM Rate (0..7F) | ||
+ | |MIDI CC 021 - VCF Cutoff (0..7F) | ||
+ | |MIDI CC 022 - VCF Resonance (0..7F) | ||
+ | |MIDI CC 023 - VCF LFO Modulation Depth (0..7F) | ||
+ | |MIDI CC 024 - VCF ENV Modulation Depth (0..7F) | ||
+ | |MIDI CC 025 - VCF Key Follower (0..F) | ||
+ | |MIDI CC 026 - VCF Aftertouch (0..F) | ||
+ | |MIDI CC 027 - VCA Level (0..7F) | ||
+ | |MIDI CC 028 - VCA Aftertouch Sesitivity (00..0F) | ||
+ | |MIDI CC 029 - LFO Rate (0..7F) | ||
+ | |MIDI CC 030 - LFO Delay (0..7F) | ||
+ | |MIDI CC 031 - ENV T1 - Attack Time | ||
+ | |MIDI CC 032 - ENV L1 - Attack Level (0..7F) | ||
+ | |MIDI CC 033 - ENV T2 - Break Time (0..7F) | ||
+ | |MIDI CC 034 - ENV L2 - Break Level | ||
+ | |MIDI CC 035 - ENV T3 - Decay Time (0..7F) | ||
+ | |MIDI CC 036 - ENV L3 - Sustain Level (0..7F) | ||
+ | |MIDI CC 037 - ENV T4 - Release Time | | ||
+ | |MIDI CC 038 - ENV Key Follower (0..0F) | ||
+ | |MIDI CC 039 - Chorus Rate (0..7F) | ||
+ | |MIDI CC 040 - DCO Bender Range (0..C) | ||
+ | |MIDI CC 041 | | ||
+ | |MIDI CC 042 | | ||
+ | |MIDI CC 043 | | ||
+ | |MIDI CC 044 | | ||
+ | |MIDI CC 045 | | ||
+ | |MIDI CC 046 | | ||
+ | |MIDI CC 047 | | ||
+ | |MIDI CC 048 | | ||
+ | |MIDI CC 049 | | ||
+ | |MIDI CC 050 | | ||
+ | |MIDI CC 051 | | ||
+ | |MIDI CC 052 | | ||
+ | |MIDI CC 053 | | ||
+ | |MIDI CC 054 | | ||
+ | |MIDI CC 055 | | ||
+ | |MIDI CC 056 | | ||
+ | |MIDI CC 057 | | ||
+ | |MIDI CC 058 | | ||
+ | |MIDI CC 059 | | ||
+ | |MIDI CC 060 | | ||
+ | |MIDI CC 061 | | ||
+ | |MIDI CC 062 | | ||
+ | |MIDI CC 063 | | ||
+ | |MIDI CC 064 - Hold ON/OFF (REAL CC) | | ||
+ | |MIDI CC 065 - Portamento ON/OFF (REAL CC) | | ||
+ | |MIDI CC 066 | | ||
+ | |MIDI CC 067 | | ||
+ | |MIDI CC 068 | | ||
+ | |MIDI CC 069 | | ||
+ | |MIDI CC 070 | | ||
+ | |MIDI CC 071 | | ||
+ | |MIDI CC 072 | | ||
+ | |MIDI CC 073 | | ||
+ | |MIDI CC 074 | | ||
+ | |MIDI CC 075 | | ||
+ | |MIDI CC 076 | | ||
+ | |MIDI CC 077 | | ||
+ | |MIDI CC 078 | | ||
+ | |MIDI CC 079 | | ||
+ | |MIDI CC 080 | | ||
+ | |MIDI CC 081 | | ||
+ | |MIDI CC 082 | | ||
+ | |MIDI CC 083 | | ||
+ | |MIDI CC 084 | | ||
+ | |MIDI CC 085 | | ||
+ | |MIDI CC 086 | | ||
+ | |MIDI CC 087 | | ||
+ | |MIDI CC 088 | | ||
+ | |MIDI CC 089 | | ||
+ | |MIDI CC 090 | | ||
+ | |MIDI CC 091 | | ||
+ | |MIDI CC 092 | | ||
+ | |MIDI CC 093 | | ||
+ | |MIDI CC 094 | | ||
+ | |MIDI CC 095 | | ||
+ | |MIDI CC 096 | | ||
+ | |MIDI CC 097 | | ||
+ | |MIDI CC 098 | | ||
+ | |MIDI CC 099 | | ||
+ | |MIDI CC 100 | | ||
+ | |MIDI CC 101 | | ||
+ | |MIDI CC 102 | | ||
+ | |MIDI CC 103 | | ||
+ | |MIDI CC 104 | | ||
+ | |MIDI CC 105 | | ||
+ | |MIDI CC 106 | | ||
+ | |MIDI CC 107 | | ||
+ | |MIDI CC 108 | | ||
+ | |MIDI CC 109 | | ||
+ | |MIDI CC 110 | | ||
+ | |MIDI CC 111 | | ||
+ | |MIDI CC 112 | | ||
+ | |MIDI CC 113 | | ||
+ | |MIDI CC 114 | | ||
+ | |MIDI CC 115 | | ||
+ | |MIDI CC 116 | | ||
+ | |MIDI CC 117 | | ||
+ | |MIDI CC 118 | | ||
+ | |MIDI CC 119 | | ||
+ | |MIDI CC 120 | | ||
+ | |MIDI CC 121 | | ||
+ | |MIDI CC 122 - Local ON/OFF (REAL CC) | | ||
+ | |MIDI CC 123 - ALL NOTES OFF(REAL CC) | | ||
+ | |MIDI CC 124 - OMNI OFF (REAL CC) | | ||
+ | |MIDI CC 125 - OMNI ON (REAL CC) | | ||
+ | |MIDI CC 126 - MONO ON (REAL CC) | | ||
+ | |MIDI CC 127 - POLY ON (REAL CC) | | ||
+ | ====== Notes ====== | ||
+ | * **Note:** Set **SYSEX ON** @AlphaJuno (JuCtrl will not work if SYSEX = off) | ||
+ | * **Note:** JuCtrl CS will pick up all the TONE (Sound) Parameters automatically - if you make changes @Alpha Juno | ||
+ | * **Note: HOW TO SET JUNO SYSEX ON** | ||
+ | - @Alpha Juno: Push the [MIDI] Button as many times until the MIDI SYSEX OPTION "MIDI EXCL" appears. | ||
+ | - Use the dial for changing. | ||
+ | - By writing the data of the MIDI Function setting into the back-up memory, it can be retained even when the Juno is turned off: | ||
+ | * set the Memory Protect Switch to OFF position. Push the MIDI Button. | ||
+ | * While holding the Write Button down, push the MIDI Button. The Juno Display will change to: "Write MIDI FUNC." | ||
+ | * When the MIDI Button is pushed: "Write Complete!" | ||
+ | * **Note: WRITE JUNO TONE DATA TO BANKSTICK** | ||
+ | - SELECT THE PREFERRED BANKSTICK (1-8) with [SELECT BANKSTICK] BUTTON and [VALUE] ENCODER | ||
+ | - SELECT YOUR PREFERRED BANKSTICK AREA with the [MIDI ProgChange] ENCODER | ||
+ | * MIDI ProgChange = 1-64 = You will WRITE Juno Tone Colours to BANKSTICK 1 -64 | ||
+ | * MIDI ProgChange = 65-128 = You will WRITE Juno Tone Colours TO BANKSTICK 65 -128 | ||
+ | - Set [PRESET] (64x PRESET TONE COLOURS) or [MEMORY] (64x MEMORY TONE COLOURS) @Alpha Juno | ||
+ | - PRESS: [DATA TRANFERE] + [WRITE] + [DUMP] @Alpha Juno | ||
+ | - Now JuCtrl will RECEIVE 64 TONE COLOURS via SYSEX-DATA and write 64x TONE PATCHES to your selected BANKSTICK. | ||
+ | * All Done. | ||
+ | * BROWNS THE STORED TONE COLOURS with the " | ||
+ | * THE TONE NAME WILL APPEAR ON THE JuCtrl LCD. LOAD A STORED TONE COLOUR WITH THE BUTTON "SEND TONE TO CS" | ||
+ | * NOW THE CS IS LOADED. | ||
+ | * PRESS [SEND TONE TO JUNO] BUTTON for WRITING THE CURRENT CS DATA BACK TO ALPHA JUNO | ||
+ | * **Note: ENVELOPE FUNCTIONS** | ||
+ | * There are some ENVELOPE FUNCTIONS: | ||
+ | - LEVEL MAX: set all ENVELOPE LEVEL to max value (127) | ||
+ | - LEVEL MIN: set all ENVELOPE LEVEL to min value (0) | ||
+ | - ENVELOPE TIME MAX: set all ENVELOPE TIME PARAMETER to max value (127) | ||
+ | - ENVELOPE TIME MIN: set all ENVELOPE TIME PARAMETER to min value (0) | ||
+ | - IF YOUR LAST ACTION (@CS) WAS AN ENVELOPE MANIPULATION, | ||
+ | ====== ProgChange ====== | ||
+ | * **Juno ProgChange & JuCtrl Bankstick TONE (overview)** | ||
+ | |JuCtrl | ||
+ | | LCD | ProgCh | BANK NUMBER| | ||
+ | | 1 | ||
+ | | 2 | ||
+ | | 3 | ||
+ | | 4 | ||
+ | | 5 | ||
+ | | 6 | ||
+ | | 7 | ||
+ | | 8 | ||
+ | | 9 | ||
+ | | 10 | ||
+ | | 11 | ||
+ | | 12 | ||
+ | | 13 | ||
+ | | 14 | ||
+ | | 15 | ||
+ | | 16 | ||
+ | | 17 | ||
+ | | 18 | ||
+ | | 19 | ||
+ | | 20 | ||
+ | | 21 | ||
+ | | 22 | ||
+ | | 23 | ||
+ | | 24 | ||
+ | | 25 | ||
+ | | 26 | ||
+ | | 27 | ||
+ | | 28 | ||
+ | | 29 | ||
+ | | 30 | ||
+ | | 31 | ||
+ | | 32 | ||
+ | | 33 | ||
+ | | 34 | ||
+ | | 35 | ||
+ | | 36 | ||
+ | | 37 | ||
+ | | 38 | ||
+ | | 39 | ||
+ | | 40 | ||
+ | | 41 | ||
+ | | 42 | ||
+ | | 43 | ||
+ | | 44 | ||
+ | | 45 | ||
+ | | 46 | ||
+ | | 47 | ||
+ | | 48 | ||
+ | | 49 | ||
+ | | 50 | ||
+ | | 51 | ||
+ | | 52 | ||
+ | | 53 | ||
+ | | 54 | ||
+ | | 55 | ||
+ | | 56 | ||
+ | | 57 | ||
+ | | 58 | ||
+ | | 59 | ||
+ | | 60 | ||
+ | | 61 | ||
+ | | 62 | ||
+ | | 63 | ||
+ | | 64 | ||
+ | | 65 | ||
+ | | 66 | ||
+ | | 67 | ||
+ | | 68 | ||
+ | | 69 | ||
+ | | 70 | ||
+ | | 71 | ||
+ | | 72 | ||
+ | | 73 | ||
+ | | 74 | ||
+ | | 75 | ||
+ | | 76 | ||
+ | | 77 | ||
+ | | 78 | ||
+ | | 79 | ||
+ | | 80 | ||
+ | | 81 | ||
+ | | 82 | ||
+ | | 83 | ||
+ | | 84 | ||
+ | | 85 | ||
+ | | 86 | ||
+ | | 87 | ||
+ | | 88 | ||
+ | | 89 | ||
+ | | 90 | ||
+ | | 91 | ||
+ | | 92 | ||
+ | | 93 | ||
+ | | 94 | ||
+ | | 95 | ||
+ | | 96 | ||
+ | | 97 | ||
+ | | 98 | ||
+ | | 99 | ||
+ | |100 | ||
+ | |101 | 100 | 5 5 | ||
+ | |102 | 101 | 5 6 | ||
+ | |103 | 102 | 5 7 | ||
+ | |104 | 103 | 5 8 | ||
+ | |105 | 104 | 6 1 | ||
+ | |106 | 105 | 6 2 | ||
+ | |107 | 106 | 6 3 | ||
+ | |108 | 107 | 6 4 | ||
+ | |109 | 108 | 6 5 | ||
+ | |110 | 109 | 6 6 | ||
+ | |111 | 110 | 6 7 | ||
+ | |112 | 111 | 6 8 | ||
+ | |113 | 112 | 7 1 | ||
+ | |114 | 113 | 7 2 | ||
+ | |115 | 114 | 7 3 | ||
+ | |116 | 115 | 7 4 | ||
+ | |117 | 116 | 7 5 | ||
+ | |118 | 117 | 7 6 | ||
+ | |119 | 118 | 7 7 | ||
+ | |120 | 119 | 7 8 | ||
+ | |121 | 120 | 8 1 | ||
+ | |122 | 121 | 8 2 | ||
+ | |123 | 122 | 8 3 | ||
+ | |124 | 123 | 8 4 | ||
+ | |125 | 124 | 8 5 | ||
+ | |126 | 125 | 8 6 | ||
+ | |127 | 126 | 8 7 | ||
+ | |128 | 127 | 8 8 | ||
====== Project Status ====== | ====== Project Status ====== | ||
- | 30.08.2012 | + | 12/2012 |
Line 47: | Line 352: | ||
|| --- 100% HW: Update Core8 >> PIC18F4620 (Need more Program Memory and SRAM for BLD-Mode Sysex Data) | || --- 100% HW: Update Core8 >> PIC18F4620 (Need more Program Memory and SRAM for BLD-Mode Sysex Data) | ||
|| --- 100% Bankstick (BS 1-8 = 8*128 Tone Patches) | || --- 100% Bankstick (BS 1-8 = 8*128 Tone Patches) | ||
- | || --- 75% ENVELOPE functions (BTN F1-F4) | + | || --- 100% ENVELOPE functions (BTN F1-F4) |
- | || --- 13% Send Bankstick sysex-dump (Tone Backup) | + | || --- 100% Send Bankstick sysex-dump (Tone Backup) |
+ | || --- V1.000 (09/2012) | ||
+ | || --- V1.001 (12/2012) | ||
+ | || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | ||
+ | || Note: Juno Keyboard do NOT have Aftertouch. But with another Keyboard or Sequencer | ||
+ | || You can use all the nice Aftertouch Effects of the Alpha Juno. | ||
Line 55: | Line 365: | ||
====== Software ====== | ====== Software ====== | ||
- | * Not Released yet | + | * [[http:// |
+ | * [[http:// | ||
====== Links ====== | ====== Links ====== |
ju_control_roland_alpha_juno_control_panel_cs.txt · Last modified: 2017/09/19 12:14 by lemonhorse
