layout_improvements
Differences
layout_improvements [2008/01/21 19:10] – selfservice | layout_improvements [2009/12/05 20:12] – selfservice | ||
Line 1: | Line 1: | ||
+ | ====== Important Notes about new PCB designs ====== | ||
The aim of this page is to give the community the possibility to publish improved layouts of MBHP modules. The original layouts by TK are mostly quick solutions with focus on " | The aim of this page is to give the community the possibility to publish improved layouts of MBHP modules. The original layouts by TK are mostly quick solutions with focus on " | ||
Line 13: | Line 15: | ||
* consider mounting holes at the edges | * consider mounting holes at the edges | ||
* single sided boards should be prevered before double sided boards | * single sided boards should be prevered before double sided boards | ||
+ | * Consider Kicad if you need a larger layout. It is open source and free to download from [[http:// | ||
+ | * Not that a larger layout is neccesarily an improvement! ;-) | ||
* **IMPORTANT**: | * **IMPORTANT**: | ||
Line 27: | Line 31: | ||
^ Bridgeless MBHP_BURNER Module | NorthernLightX | [[http:// | ^ Bridgeless MBHP_BURNER Module | NorthernLightX | [[http:// | ||
^ Some Layouts (including core) | rdoursenaud | ^ Some Layouts (including core) | rdoursenaud | ||
- | ^ Improved MBHP_OPL3 Module | + | ^ Improved MBHP_OPL3 Module |
====== Ideas ====== | ====== Ideas ====== |
layout_improvements.txt · Last modified: 2011/11/18 16:04 by lpdunwell
