layout_improvements
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
layout_improvements [2008/01/21 19:12] – selfservice | layout_improvements [2011/11/18 16:04] (current) – lpdunwell | ||
Line 14: | Line 14: | ||
* try to let ca. 5 mm free at the borders, otherwise chances are high that tracks will be damaged during splitting the boards to smaller pieces | * try to let ca. 5 mm free at the borders, otherwise chances are high that tracks will be damaged during splitting the boards to smaller pieces | ||
* consider mounting holes at the edges | * consider mounting holes at the edges | ||
- | * single sided boards should be prevered | + | * single sided boards should be preferred |
+ | * Consider Kicad if you need a larger layout. It is open source and free to download from [[http:// | ||
+ | * Not that a larger layout is neccesarily an improvement! ;-) | ||
* **IMPORTANT**: | * **IMPORTANT**: | ||
Line 28: | Line 30: | ||
^ Bridgeless MBHP_AOUT Module | ^ Bridgeless MBHP_AOUT Module | ||
^ Bridgeless MBHP_BURNER Module | NorthernLightX | [[http:// | ^ Bridgeless MBHP_BURNER Module | NorthernLightX | [[http:// | ||
- | ^ Some Layouts (including core) | rdoursenaud | + | ^ Some Layouts (including core) | rdoursenaud |
- | ^ Improved MBHP_OPL3 Module | + | ^ Improved MBHP_OPL3 Module |
====== Ideas ====== | ====== Ideas ====== |
layout_improvements.txt · Last modified: 2011/11/18 16:04 by lpdunwell
