lcd [2016/06/15 11:18] psykhaze [Where to buy ?] |
lcd [2016/06/27 11:05] psykhaze [Where to buy ?] |
Line 29: | Line 29: | ||
* [[https://en.wikipedia.org/wiki/Hitachi_HD44780_LCD_controller|Wikipedia page on HD44780 ]] | * [[https://en.wikipedia.org/wiki/Hitachi_HD44780_LCD_controller|Wikipedia page on HD44780 ]] | ||
- | * [[https://www.sparkfun.com/datasheets/LCD/HD44780.pdf|HD44780 Specification]] | + | * [[https://www.sparkfun.com/datasheets/LCD/HD44780.pdf|HD44780 Specification PDF]] |
- | Here is a list of compatible CLCD Controllers: Have a look to the datasheet of the dispaly you want to plug, you will get this info. If your LCD has one of these chips, there are good changes to get it work. These chips have similar instruction set, data bus and timings are like original HD44780 (or faster, which shouldn't matter). But this only means controller chip is compatible with the driver designed for HD44780. It may not be exactly what you need, forexample it may require a negative backlight voltage, which is independent of the driver IC. It's strongly recommended to get a display, that has a datasheet available.: | + | Here is a list of compatible CLCD Controllers: Have a look to the datasheet of the display you want to plug, you will get this info. If your LCD has one of these chips, there are good changes to get it work. |
+ | These chips have similar instruction set, data bus and timings are like original HD44780 (or faster, which shouldn't matter). But this only means controller chip is compatible with the driver designed for HD44780. | ||
+ | It may not be exactly what you need, forexample it may require a negative backlight voltage, which is independent of the driver IC. It's strongly recommended to get a display, that has a datasheet available.: | ||
* **Hitachi HD44780** | * **Hitachi HD44780** | ||
Line 65: | Line 69: | ||
=====Where to buy ?===== | =====Where to buy ?===== | ||
- | * [[http://www.buydisplay.com/|Buydisplay]] | + | Have a look [[where_to_order_components#displays|Here]] |
- | * [[https://www.crystalfontz.com/|CrytalFontz]] | + | |
- | * [[http://www.texim-europe.com/display-and-touch-solutions|Texim Eu]] | + | |
- | Reichelt Order numbers : (eg: LCD 162C LED / LCD 164A LED / LCD 204A LED ) | + | |
===== LCD Connection ===== | ===== LCD Connection ===== | ||
[[http://ucapps.de/mbhp_lcd.html|TK's LCD page]] contains general info on connecting an LCD. | [[http://ucapps.de/mbhp_lcd.html|TK's LCD page]] contains general info on connecting an LCD. | ||
- | {{ :neonking:midibox_lcd_cable.jpg?direct&700 |}} | + | Here is a summary: |
+ | * [[http://ucapps.de/mbhp/mbhp_lcd_mios32.pdf|LCD]] | ||
+ | * [[http://ucapps.de/mbhp/mbhp_lcd_2x20_mios32.pdf|2x20LCD Standard]] | ||
+ | * [[http://ucapps.de/mbhp/mbhp_lcd_sed1520_mios32.pdf|SED1520]] | ||
+ | * [[http://ucapps.de/mbhp/mbhp_lcd_ks0108_mios32.pdf|KS108]] | ||
+ | * [[http://ucapps.de/mbhp/mbhp_lcd_dogm128_mios32.pdf|DOGM128]] | ||
+ | {{ :neonking:midibox_lcd_cable.jpg?direct&700 |}} | ||
====Connectivity==== | ====Connectivity==== | ||
