led
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
led [2016/06/15 12:39] – [LED] psykhaze | led [2016/07/10 15:03] (current) – [White / Blue LEDs issue] psykhaze | ||
Line 5: | Line 5: | ||
- | LED is an industry acronym for **Light Emitting Diode**. These are usually small little " | + | LED is an industry acronym for **Light Emitting Diode**. These are usually small little " |
+ | //(most common colors are red, green, | ||
- | That's also a generic term used for the lighted display on calculators and other numeric displays; they are made up of 7 distinct straight line " | ||
- | LCDs emulate this pattern style, though they are NOT diodes. The first to use the style was the " | ||
===== RGB LEDs ===== | ===== RGB LEDs ===== | ||
Line 21: | Line 21: | ||
It has been proven recently that the use of **high brightness White and Blue LEDs are not good to human sight**. The output light spectrum for these LEDs is some harsh for the eye. You should prefer using other colors LEDs or not using them too much. | It has been proven recently that the use of **high brightness White and Blue LEDs are not good to human sight**. The output light spectrum for these LEDs is some harsh for the eye. You should prefer using other colors LEDs or not using them too much. | ||
+ | =====LED Matrix===== | ||
led.txt · Last modified: 2016/07/10 15:03 by psykhaze
