linux_mios32_toolchain_core
Differences
linux_mios32_toolchain_core [2024/04/05 15:20] – [Setup MIOS32 Environment] phatline | linux_mios32_toolchain_core [2024/04/05 15:30] – [Setup MIOS32 Environment] phatline | ||
Line 88: | Line 88: | ||
__ | __ | ||
- | **If you know what you are Doing in Linux: | + | **If you know what you are Doing in Linux-you can do this systemwide:**__\\ |
open your filebrowser with sudo rights, for example type in terminal:\\ | open your filebrowser with sudo rights, for example type in terminal:\\ | ||
*** Linux Mint:** //sudo nemo// \\ | *** Linux Mint:** //sudo nemo// \\ | ||
- | **Linux Arch:** //sudo thunar//\\ | + | *** Linux Arch:** //sudo thunar//\\ |
the filebrowser now opens with root rights, navigate to the folder " | the filebrowser now opens with root rights, navigate to the folder " | ||
Depending on the path where your toolchain is situated, the Example Content off this file is:\\ | Depending on the path where your toolchain is situated, the Example Content off this file is:\\ | ||
- | //PATH="/ | + | * PATH="/ |
+ | * MIOS32_PATH=/ | ||
+ | * MIOS32_BIN_PATH=/ | ||
+ | * MIOS32_BOARD=MBHP_CORE_STM32F4\\ | ||
+ | * MIOS32_FAMILY=STM32F4xx\\ | ||
+ | * MIOS32_GCC_PREFIX=arm-none-eabi\\ | ||
+ | * MIOS32_PROCESSOR=STM32F407VG\\ | ||
+ | * MIOS32_LCD=universal\\ | ||
- | MIOS32_PATH=/ | + | if you cant log after reboot, then mostly you messed up your " |
- | MIOS32_BIN_PATH=/ | + | |
- | MIOS32_BOARD=MBHP_CORE_STM32F4 | + | **you can also add more folders to the PATH, they are separeted with a ":", |
- | MIOS32_FAMILY=STM32F4xx | + | * PATH="/ |
- | MIOS32_GCC_PREFIX=arm-none-eabi | + | here we also have a folder named " |
- | MIOS32_PROCESSOR=STM32F407VG | + | |
- | MIOS32_LCD=universal// | + | |
linux_mios32_toolchain_core.txt · Last modified: 2024/05/23 19:46 by phatline
