loopa-eurorack-panel [2022/01/16 08:19] phatline [Building and BOM] |
loopa-eurorack-panel [2022/01/21 12:49] phatline [Frontpanel] |
Line 28: | Line 28: | ||
All necessery Information is printet on the PCB, but also check the Shematic...\\ | All necessery Information is printet on the PCB, but also check the Shematic...\\ | ||
- | 5x [[https://www.buerklin.com/de/Montageblock/p/17H917|"Leiterplatten Montageblock aka Standoffs]]\\ | + | 5x [[https://www.buerklin.com/de/Montageblock/p/17H917|Leiterplatten Montageblock aka Standoffs]]\\ |
3x [[https://www.mouser.at/ProductDetail/TE-Connectivity/1-215079-0?qs=sGAEpiMZZMu2UVWuvJ5cF0NzRP25WJYp|Micromatch Socket 2x5Pole 1,27mm]]\\ | 3x [[https://www.mouser.at/ProductDetail/TE-Connectivity/1-215079-0?qs=sGAEpiMZZMu2UVWuvJ5cF0NzRP25WJYp|Micromatch Socket 2x5Pole 1,27mm]]\\ | ||
6x [[https://www.mouser.at/ProductDetail/TE-Connectivity/1-2178712-0?qs=Xjc0wECptJBhQ3iBLfHBBw%3D%3D|Micromatch Crimp Connector]] you need only 3, the 3+ is for fails by crimping\\ | 6x [[https://www.mouser.at/ProductDetail/TE-Connectivity/1-2178712-0?qs=Xjc0wECptJBhQ3iBLfHBBw%3D%3D|Micromatch Crimp Connector]] you need only 3, the 3+ is for fails by crimping\\ | ||
Line 34: | Line 34: | ||
1x [[https://www.mouser.at/ProductDetail/Molex/67068-7041?qs=%2Fha2pyFadugeFcqiSbHe2F3FlkyTY7p9rg69fYk%252bS0tr8kIPu4fJmw%3D%3D|USB-Socket]]\\ | 1x [[https://www.mouser.at/ProductDetail/Molex/67068-7041?qs=%2Fha2pyFadugeFcqiSbHe2F3FlkyTY7p9rg69fYk%252bS0tr8kIPu4fJmw%3D%3D|USB-Socket]]\\ | ||
8x [[https://www.mouser.at/ProductDetail/CUI-Devices/SJ1-3535NG?qs=sGAEpiMZZMv0W4pxf2HiVz9SCMkER55fXrlpiF5mEoVt2p3Qc8GC6g%3D%3D|3,5 Audio Jack]]\\ | 8x [[https://www.mouser.at/ProductDetail/CUI-Devices/SJ1-3535NG?qs=sGAEpiMZZMv0W4pxf2HiVz9SCMkER55fXrlpiF5mEoVt2p3Qc8GC6g%3D%3D|3,5 Audio Jack]]\\ | ||
+ | 12x [[https://www.mouser.at/ProductDetail/Lumex/SSL-LX30FT4ID?qs=sGAEpiMZZMuCm2JlHBGefjo7mRik%2FjcaqjK5FJOZhDc%3D|Round 3mm Thruhole LEDs-RED-Flat]]\\ | ||
+ | 4x [[https://www.mouser.at/ProductDetail/Lumex/SSL-LX30FT4GD?qs=sGAEpiMZZMuCm2JlHBGefjo7mRik%2FjcaResH8h9wozw%3D|Round 3mm Thruhole LEDs-GREEN-Flat]] | ||
And there will be some additional Fasting Material, like bolts, Screws, Standoffs, that i dont know right now, because the first protoype has to be built first...\\ | And there will be some additional Fasting Material, like bolts, Screws, Standoffs, that i dont know right now, because the first protoype has to be built first...\\ | ||
====== Frontpanel====== | ====== Frontpanel====== | ||
- | {{:phatline:Frontpanel.jpg?700|}}\\ | + | {{:phatline:Euro-LoopA-Frontpanel-growing.jpg?900|}}\\ |
- | I made a DXF File which you can send to [[https://www.formulor.de/|Formulor in Germany]]\\ | + | **I made a DXF File which you can send to:** (once the prototypestate is gone)\\ |
- | + | [[https://www.formulor.de|Formulor in Germany]] - Acrylic ... 2Pieces incl shipping 42€\\ | |
- | i panalized it so there are 2 Plates in it\\ | + | [[https://shop.frontpanels.de/custom-panels|frontpanels.de in germany]] my choose\\ |
- | I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | + | [[https://thebeast.co.uk/2d/|The Beast - UK]]\\ |
- | {{:phatline:2xLRE-OLED-BAR-DXF.zip?700|}}\\ | + | [[https://www.schaeffer-ag.de/en/|Schaeffer-ag.de]] |
**Recommend Material**\\ | **Recommend Material**\\ | ||
- | 3mm x 128.5 x 188.58 Aluminium, anodised)\\ | + | 2mm x 128.5 x 188.58 Aluminium, anodised\\ |
+ | contact frontpanels: info@frontpanels.de\\ | ||
+ | {{:phatline:Frontpanels-Euroloopa.zip?900|}} - NOT TESTET - REVERSE ENGENEERING!!!!!!\\ | ||
