mb-digiroland [2016/08/14 22:40] phatline [Community users working on it] |
mb-digiroland [2016/11/12 17:01] psykhaze [General Design] |
Line 1: | Line 1: | ||
- | ====== MIDIbox EuRoland Project ====== | + | ====== MIDIbox DigiRoland Project ====== |
- | {{:neonking:euroland-logo.jpg?direct&600 |}} | + | |
- | The Midibox EuRoland project aims to be a **Eurorack Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. | + | The Midibox EuRoland project aims to be a **4U Re-Edit of Analog Drum Parts of Roland TR Drumachines** designed to fit in the Eurorack size Format, to be driven trought MIDI or CV. |
It's the Merging of these projects: | It's the Merging of these projects: | ||
Line 17: | Line 16: | ||
* **[[Phatline]]** | * **[[Phatline]]** | ||
* **[[Psykhaze]]** | * **[[Psykhaze]]** | ||
+ | * **[[Antichambre]]** | ||
- | **__Workshare:__**\\ | ||
- | **909**\\ | ||
- | BD, TOM, SAMPLER-Voices > Psykhaze\\ | ||
- | SD, RIM > PHATLINE\\ | ||
- | **808:**\\ | ||
- | BD, SD, TOM > Psykhaze\\ | ||
- | CY, HH, COWBELL > PHATLINE\\ | ||
- | **606**\\ | ||
- | BD+SD > Psykhaze\\ | ||
- | CY+HH > PHATLINE\\ | ||
===== Getting Involved ? ===== | ===== Getting Involved ? ===== | ||
Line 38: | Line 26: | ||
2 Cases of use :\\ | 2 Cases of use :\\ | ||
- | * **1. Midi:** Use the MB-Modulbox Standartmodules, for Digital UI and CV+Trig-Generation\\ | + | * **1. Midi-Interface:** Use the MB-Modulbox Standartmodules, for Digital UI and CV+Trig-Generation\\ |
- | * **2. CV+Trig:** Just Plug CV or Trig Jacks into the Analog Modules...without Midibox.\\ | + | * **2. Analog Interface:** Just Plug CV or Trig Jacks into the Analog Modules...without Midibox.\\ |
- | ==== Use with Midi ==== | + | ===== Workshare ===== |
+ | ====606==== | ||
+ | BD+SD > [[Psykhaze]]\\ | ||
+ | CY+HH > [[Phatline]]\\ | ||
+ | ====808==== | ||
+ | BD, SD, TOM > [[Psykhaze]]\\ | ||
+ | CY, HH, COWBELL > [[Phatline]]\\ | ||
+ | ====909==== | ||
+ | BD, TOM, SAMPLER-Voices > [[Psykhaze]]\\ | ||
+ | SD, RIM > [[Phatline]]\\ | ||
+ | ===== Configuration ===== | ||
+ | ==== MIDI Use ==== | ||
=== MB-Modulbox Main PCB UI === | === MB-Modulbox Main PCB UI === | ||
Line 67: | Line 68: | ||
Set CV + Trig Routing (some kind of trigger matrix), standard is 1:1 routing, so no need for this if you use a fixed setup. | Set CV + Trig Routing (some kind of trigger matrix), standard is 1:1 routing, so no need for this if you use a fixed setup. | ||
- | ==== Use with Midi or with Analog CV+Trig ==== | + | ==== Analog Use ==== |
Here are only the Analog-Drum-PCB discussed, since all other Digital UI is based on MB-Modulbox Standart Modules, the MB-Modulbox Main PCB2 is special Variant, described here. | Here are only the Analog-Drum-PCB discussed, since all other Digital UI is based on MB-Modulbox Standart Modules, the MB-Modulbox Main PCB2 is special Variant, described here. | ||
===== Software Tools used ===== | ===== Software Tools used ===== | ||
