mb-lre8x2cs_rev4.6
Differences
mb-lre8x2cs_rev4.6 [2014/02/24 16:05] – [LED black list] fairlightiii | mb-lre8x2cs_rev4.6 [2014/02/25 04:46] – [Schematic] fairlightiii | ||
Line 76: | Line 76: | ||
====Schematic==== | ====Schematic==== | ||
- | |{{http:// | + | |{{http:// |
You can download a better definition version [[http:// | You can download a better definition version [[http:// | ||
Line 86: | Line 86: | ||
**//Note: Be very careful if you use vectorial software (to draw your front panel e.g.) because usually it takes as origin of each part the left corner of the part and not __the center of the part__ !!!//** | **//Note: Be very careful if you use vectorial software (to draw your front panel e.g.) because usually it takes as origin of each part the left corner of the part and not __the center of the part__ !!!//** | ||
- | Take a look at the [[http:// | + | You can take also a look at the [[http:// |
==LEDs/ | ==LEDs/ | ||
Line 130: | Line 130: | ||
Members are welcome to edit this page to add their LED feedback. | Members are welcome to edit this page to add their LED feedback. | ||
- | |Model|Type|Mcd|Link|Good|Not good|With ULNs|Author| | + | ^Model^Type^Mcd^Link^Good^Not good^With ULNs^Author^ |
- | |Kingbright WP103HD|2x5x7mm rectangular| | + | |Kingbright WP103HD|2x5x7mm rectangular| |
- | |LED 3MM RT|3mm round| | + | |LED 3MM RT|3mm round| |
- | |Kingbright L-934ID|3mm round| | + | |Kingbright L-934ID|3mm round| |
- | |Segor Electronics]]| | + | |
|Kingbright WP132XID|3mm round| | |Kingbright WP132XID|3mm round| | ||
|Kingbright WP113SRDT|2x5x7mm rectangular| | |Kingbright WP113SRDT|2x5x7mm rectangular| | ||
|smashTV is selling|3mm round| | |smashTV is selling|3mm round| | ||
- | |Tayda Electronics|3mm round| | + | |Tayda Electronics|3mm round| |
//Note: Regarding condition of each test (ambient luminosity, etc...) and sensibility of each person, this results should be taken with reserve.// | //Note: Regarding condition of each test (ambient luminosity, etc...) and sensibility of each person, this results should be taken with reserve.// | ||
Line 149: | Line 149: | ||
Each LEDring is composed of 16 LEDs: 15 on the LEDring itself and one on the lowest part of the LEDring. | Each LEDring is composed of 16 LEDs: 15 on the LEDring itself and one on the lowest part of the LEDring. | ||
Thorsten advised me about this type of implementation (odd number of LEDs) because it is an [[http:// | Thorsten advised me about this type of implementation (odd number of LEDs) because it is an [[http:// | ||
+ | Note that the lowest LED (LED1 in the drawing below) is not at the same distance (459 mils) of the center of the encoder than the other LEDs of the LEDring (610 mils). | ||
You can use 3mm LEDs or 2x5x7mm rectangular LEDs (because the different angles of the LEDs in the LEDring) or all other LED with 0.1 inch (2,54 mm) leads spacing.\\ | You can use 3mm LEDs or 2x5x7mm rectangular LEDs (because the different angles of the LEDs in the LEDring) or all other LED with 0.1 inch (2,54 mm) leads spacing.\\ |
mb-lre8x2cs_rev4.6.txt · Last modified: 2014/04/04 13:55 by fairlightiii
