mb-lre8x2cs_rev4.6
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
mb-lre8x2cs_rev4.6 [2014/02/24 17:09] – [Components] fairlightiii | mb-lre8x2cs_rev4.6 [2014/04/04 13:55] (current) – [Pictures] fairlightiii | ||
Line 28: | Line 28: | ||
====Pictures==== | ====Pictures==== | ||
+ | |Actual PCB| | ||
+ | |{{http:// | ||
+ | |{{http:// | ||
==Mix of the Rev2.5 and protoboard pictures (Note this is not the last versions but they have practically the same dimensions and LEDs/ | ==Mix of the Rev2.5 and protoboard pictures (Note this is not the last versions but they have practically the same dimensions and LEDs/ | ||
Line 76: | Line 81: | ||
====Schematic==== | ====Schematic==== | ||
- | |{{http:// | + | |{{http:// |
You can download a better definition version [[http:// | You can download a better definition version [[http:// | ||
Line 188: | Line 193: | ||
Be careful when sourcing SIL resistor networks because a 6 Pin SIL resistor network can be 5 commoned resistors (what you need here) or __3__ independant resistors. | Be careful when sourcing SIL resistor networks because a 6 Pin SIL resistor network can be 5 commoned resistors (what you need here) or __3__ independant resistors. | ||
- | A point on the silkcreen prevent to solder upside-down the resistor networks (a point is also indicated on the resistor network). | + | A dot on the silkcreen prevent to solder upside-down the resistor networks (a dot is also indicated on the resistor network). |
==Polarized Electrolytic Capacitor 100 uF== | ==Polarized Electrolytic Capacitor 100 uF== |
mb-lre8x2cs_rev4.6.txt · Last modified: 2014/04/04 13:55 by fairlightiii
