mbhp_genesis
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
mbhp_genesis [2016/01/29 18:05] – [Links] sauraen | mbhp_genesis [2023/09/05 04:17] – [Component stuff chart] sauraen | ||
Line 1: | Line 1: | ||
- | {{http:// | + | {{http:// |
====== Summary ====== | ====== Summary ====== | ||
Line 16: | Line 16: | ||
* Smallest footprint (cheapest board) possible | * Smallest footprint (cheapest board) possible | ||
* Many components may be left unstuffed if certain features not desired | * Many components may be left unstuffed if certain features not desired | ||
+ | * **Available now for only $5 on the [[http:// | ||
Disadvantages: | Disadvantages: | ||
Line 27: | Line 28: | ||
===== Links ===== | ===== Links ===== | ||
- | * [[http:// | + | * [[http:// |
* [[http:// | * [[http:// | ||
Line 81: | Line 82: | ||
| 3 | -- | OPN2 Left channel summing node | | | 3 | -- | OPN2 Left channel summing node | | ||
+ | This means that if you're using two or more boards, stuff everything up to J7 on all boards, and connect each pin of J7 across all boards. Then, only stuff the parts downstream of J7 on one of the boards, and take the audio output from J8 on that board. (This is assuming you want everything mixed into one stereo pair.) | ||
==== R18, R19, R20 ==== | ==== R18, R19, R20 ==== | ||
These are three-pin headers to connect potentiometers to adjust the relative volume (and panning if desired) of the OPN2 and PSG. As is obvious from the schematic, R18 is for OPN2 Left, R19 is for OPN2 Right, and R20 is for PSG. The potentiometer is 10k nominal (will work fine with 5k or 2k), audio type (A) preferred but not required. It is intended that a dual-gang potentiometer would be used to adjust the OPN2 levels together, and a separate single one for the PSG. If panning is desired, after the level potentiometers, | These are three-pin headers to connect potentiometers to adjust the relative volume (and panning if desired) of the OPN2 and PSG. As is obvious from the schematic, R18 is for OPN2 Left, R19 is for OPN2 Right, and R20 is for PSG. The potentiometer is 10k nominal (will work fine with 5k or 2k), audio type (A) preferred but not required. It is intended that a dual-gang potentiometer would be used to adjust the OPN2 levels together, and a separate single one for the PSG. If panning is desired, after the level potentiometers, | ||
Line 93: | Line 95: | ||
==== J10: DATA ==== | ==== J10: DATA ==== | ||
- | Parallel address and data busses | + | Parallel address and data busses |
^ Pin ^ Label ^ Function ^ | ^ Pin ^ Label ^ Function ^ | ||
| 1 | GND | Ground | | | 1 | GND | Ground | | ||
Line 139: | Line 141: | ||
| 1 | Y2 or Y4 | 3.58 MHz (or 4 MHz) oscillator | 520-TCH357-X | Oscillator (either half-size/ | | 1 | Y2 or Y4 | 3.58 MHz (or 4 MHz) oscillator | 520-TCH357-X | Oscillator (either half-size/ | ||
| 3 | Q1, Q2, Q3 | 2N7000 or BS170 | 821-TSM2N7000KC821-T or 512-BS170 | Any small-signal N-channel MOSFET with the gate as the center pin; the board silkscreen is for 2N7000, if you use BS170 (as I did) mount them backwards to match the source and drain pins. | | | 3 | Q1, Q2, Q3 | 2N7000 or BS170 | 821-TSM2N7000KC821-T or 512-BS170 | Any small-signal N-channel MOSFET with the gate as the center pin; the board silkscreen is for 2N7000, if you use BS170 (as I did) mount them backwards to match the source and drain pins. | | ||
- | | - | J1, J2, J5, J6, J7, J8 | 0.1" pin headers | Buy in bulk | Headers; J1, J2, and J7 connect all boards together, so put sockets on one side of the boards and have the pins sticking | + | | - | J1, J2, J7, J10 | 0.1" |
- | | - | J10 | 0.1" | + | | - | J5, J6, J8 | 0.1" pin headers | Buy in bulk | Headers; |
| 1 | L1 | 10 uH inductor | 434-SMCCN-100K-02 | For LC filter for analog power rail | | | 1 | L1 | 10 uH inductor | 434-SMCCN-100K-02 | For LC filter for analog power rail | | ||
| 2 | C12, C13 | 100 uF electrolytic | Buy in bulk | Power rail filter caps | | | 2 | C12, C13 | 100 uF electrolytic | Buy in bulk | Power rail filter caps | | ||
Line 156: | Line 158: | ||
| 2 | R8, R9 | 2.2k resistor or DNP | Buy in bulk | Load for YM2612 (omit for YM3438) | | | 2 | R8, R9 | 2.2k resistor or DNP | Buy in bulk | Load for YM2612 (omit for YM3438) | | ||
| 1 | R10 | 1.5k resistor | Buy in bulk | Load for PSG | | | 1 | R10 | 1.5k resistor | Buy in bulk | Load for PSG | | ||
- | | 2 | R11, R12 | ??? | Buy in bulk | Mixing resistors for OPN2 (see below) | | + | | 2 | R11, R12 | 22k or 47k | Buy in bulk | Mixing resistors for OPN2: 22k for YM2612, 47k for YM3438 |
- | | 1 | R13 | ??? | Buy in bulk | Mixing resistor | + | | 2 | R15, R16 | 47k or 10k | Buy in bulk | Mixing |
- | | 2 | R33, R34 | ??? | Buy in bulk | Attenuating | + | | 3 | R14, R33, R34 | --- | --- | Do not populate |
- | | 1 | R14 | ??? | Buy in bulk | Attenuating resistor for PSG (see below) | + | | 7 | R13, R17, R21, R22, R25, R26 | 47k resistor | Buy in bulk | Mixing and filtering resistors | |
- | | 7 | R15, R16, R17, R21, R22, R25, R26 | 47k resistor | Buy in bulk | Mixing and filtering resistors | | + | |
| 1 | R18/R19 | 10k potentiometer(s) | Front panel specific | OPN2 volume control; single dual-gang 10k audio (or linear) potentiometer, | | 1 | R18/R19 | 10k potentiometer(s) | Front panel specific | OPN2 volume control; single dual-gang 10k audio (or linear) potentiometer, | ||
| 1 | R20 | 10k potentiometer | Front panel specific | PSG volume control; regular 10k audio (or linear) potentiometer, | | 1 | R20 | 10k potentiometer | Front panel specific | PSG volume control; regular 10k audio (or linear) potentiometer, | ||
- | | 2 | R23, R24 | 200k resistors | Buy in bulk | 220k will also work fine; if you want a louder PSG, reduce the value | | + | | 2 | R23, R24 | 220k resistors | Buy in bulk | If you want a louder PSG, reduce the value | |
| 2 | R27, R28 | 100k resistors | Buy in bulk | High-pass filter resistors | | | 2 | R27, R28 | 100k resistors | Buy in bulk | High-pass filter resistors | | ||
| 2 | R29, R30 | 220 ohm resistors | Buy in bulk | Audio output short-circuit protection resistors | | | 2 | R29, R30 | 220 ohm resistors | Buy in bulk | Audio output short-circuit protection resistors | | ||
+ | | 2 | R31, R32 | 10k 1% resistors | Buy in bulk | For voltage divider to set the virtual ground | | ||
==== Mixing resistors ==== | ==== Mixing resistors ==== | ||
- | Since the MBHP_Genesis board supports multiple | + | Previously I had a section here about the different |
- | For the test MBHP_Genesis board I populated and tweaked--a single board with one YM2612 and one SN76489--these are the values I used, after some optimization. These are also the values written | + | The values I used for my quad builds |
- | ^ Ref. Deg. ^ Value ^ | + | |
- | | R11, R12 | 22k | | + | |
- | | R13 | 47k | | + | |
- | | R33, R34 | 200k | | + | |
- | | R14 | 22k | | + | |
- | I chose the above values | + | |
- | I did install a YM3438 in the MBHP_Genesis circuit I built on prototyping board (before I had the boards produced), and in that one I had: | + | |
- | | R11, R12 | 47k | | + | |
- | | R33, R34 | DNP | | + | |
- | | R14 | 47k | | + | |
- | However, | + | |
- | Feel free to experiment--maybe leave these resistors socketed. You won't break anything as long as all the resistors | + | |
===== Component stuff chart ===== | ===== Component stuff chart ===== | ||
- | Here is a chart of what components should be stuffed on each build configuration I could think of. In most cases, several of these build configurations will be active at the same time (e.g. in a typical four-board setup, the top board is A, B or C, D, (E), F, G, H, I, M). | + | Here is a chart of what components should be stuffed on each build configuration I could think of. In most cases, several of these build configurations will be active at the same time (e.g. in a typical four-board setup, the top board is A, B or C, D, (E), F, G, H, I, M. Note that MIDIbox Quad Genesis requires F, G, H, I). |
^ Label ^ Description ^ | ^ Label ^ Description ^ | ||
Line 212: | Line 197: | ||
^ Parts ^ A ^ B ^ C ^ D ^ E ^ F ^ G ^ H ^ I ^ J ^ K ^ L ^ M ^ N ^ O ^ P ^ | ^ Parts ^ A ^ B ^ C ^ D ^ E ^ F ^ G ^ H ^ I ^ J ^ K ^ L ^ M ^ N ^ O ^ P ^ | ||
- | | U1, C1, C14, C15, Y1 or Y3, C20, C21, R11, R12, R15, R16, C23, C24, R18, R19, R21, R22 | X | | + | | U1, C1, C14, C15, Y1 or Y3, C20, C21, R11, R12 | X | |
| R8, R9 | | X | | | R8, R9 | | X | | ||
| R33, R34 | | | R33, R34 | | ||
- | | U2, C2, Y2 or Y4, U10, C10, Q2, Q3, R4:6, R10, C22, R13, R14, R17, C25, R20, R23, R24 | | + | | U2, C2, Y2 or Y4, U10, C10, Q2, Q3, R4:6, R10, C22, R13 | |
- | | J1, C12, L1, C13, C11, U4, C4, C16, R31, R32, C18, C19, U5, C5, C17, R25, R26, C29, C30, C31, C32, R27:30, J8 | | + | | J1, C12, L1, C13, C11 | X | |
| J6, R7 | | | J6, R7 | | ||
| U7, C7 | | | U7, C7 | | ||
| U8, C8 | | | U8, C8 | | ||
| U6, C6, Q1, R1 | | | U6, C6, Q1, R1 | | ||
- | | U9, C9, C26: | + | | U9, C9 | |
| J5 | | | J5 | | ||
| Short U3:5 to U3:15 | | | Short U3:5 to U3:15 | | ||
Line 227: | Line 212: | ||
| Short U8:3 to U8:6 | | | Short U8:3 to U8:6 | | ||
| U3, C3, J2 | | | U3, C3, J2 | | ||
+ | | U4, C4, U5, C5, C16:19, C23:32, R15:32, J8 | | ||
| Short U3:13 to J3:2, short U3:12 to J3:1 | | | Short U3:13 to J3:2, short U3:12 to J3:1 | | ||
| Short U3:11 to J3:2, short U3:10 to J3:1 | | | Short U3:11 to J3:2, short U3:10 to J3:1 | | ||
Line 249: | Line 235: | ||
For the OPN2 chips, the YM3438 is a complete reimplementation of the YM2612 in CMOS instead of NMOS. They also changed the output stage to get rid of some analog error in the YM2612' | For the OPN2 chips, the YM3438 is a complete reimplementation of the YM2612 in CMOS instead of NMOS. They also changed the output stage to get rid of some analog error in the YM2612' | ||
+ | (Note about the next two paragraphs: the resistor values given in the parts list are the ones I used and tested for each of YM2612 and YM3438, there' | ||
The differences for this module are relatively simple. For a YM2612, the audio outputs require a known load to perform to spec--these are R8 and R9. The value of 2.2k was taken from the [[http:// | The differences for this module are relatively simple. For a YM2612, the audio outputs require a known load to perform to spec--these are R8 and R9. The value of 2.2k was taken from the [[http:// | ||
Line 303: | Line 291: | ||
===== Notes about the YM2612' | ===== Notes about the YM2612' | ||
From [[http:// | From [[http:// | ||
+ | When appropriately configured as such via bits in the test registers discovered by Sauraen, the Test pin outputs a SYNC signal--a pulse for one of the 24 operators in the cycle. Using this pulse to know when to start and putting the OPN2 in a particular test mode, MIDIbox Quad Genesis periodically reads out the state of all 24 operators, and measures the average volume of the operator for the VU meter display on the front panel. |
mbhp_genesis.txt · Last modified: 2023/09/05 04:19 by sauraen
