mbhp_genesis
Differences
mbhp_genesis [2017/08/18 21:11] – [Parts list] sauraen | mbhp_genesis [2023/09/05 04:16] – [Component stuff chart] sauraen | ||
Line 1: | Line 1: | ||
- | {{http:// | + | {{http:// |
====== Summary ====== | ====== Summary ====== | ||
Line 141: | Line 141: | ||
| 1 | Y2 or Y4 | 3.58 MHz (or 4 MHz) oscillator | 520-TCH357-X | Oscillator (either half-size/ | | 1 | Y2 or Y4 | 3.58 MHz (or 4 MHz) oscillator | 520-TCH357-X | Oscillator (either half-size/ | ||
| 3 | Q1, Q2, Q3 | 2N7000 or BS170 | 821-TSM2N7000KC821-T or 512-BS170 | Any small-signal N-channel MOSFET with the gate as the center pin; the board silkscreen is for 2N7000, if you use BS170 (as I did) mount them backwards to match the source and drain pins. | | | 3 | Q1, Q2, Q3 | 2N7000 or BS170 | 821-TSM2N7000KC821-T or 512-BS170 | Any small-signal N-channel MOSFET with the gate as the center pin; the board silkscreen is for 2N7000, if you use BS170 (as I did) mount them backwards to match the source and drain pins. | | ||
- | | - | J1, J2, J7, J10 | 0.1" stackable pin socket/ | + | | - | J1, J2, J7, J10 | 0.1" stackable pin socket/ |
| - | J5, J6, J8 | 0.1" pin headers | Buy in bulk | Headers; J5 and J6 are individual on each board if used, and J8 is only on the final board. | | | - | J5, J6, J8 | 0.1" pin headers | Buy in bulk | Headers; J5 and J6 are individual on each board if used, and J8 is only on the final board. | | ||
- | | - | J10 | 0.1" dual row pin headers | Buy in bulk | Headers; J10 connects all boards together, so put sockets on one side of the boards and have the pins sticking through on the other sides. | | ||
| 1 | L1 | 10 uH inductor | 434-SMCCN-100K-02 | For LC filter for analog power rail | | | 1 | L1 | 10 uH inductor | 434-SMCCN-100K-02 | For LC filter for analog power rail | | ||
| 2 | C12, C13 | 100 uF electrolytic | Buy in bulk | Power rail filter caps | | | 2 | C12, C13 | 100 uF electrolytic | Buy in bulk | Power rail filter caps | | ||
Line 198: | Line 197: | ||
^ Parts ^ A ^ B ^ C ^ D ^ E ^ F ^ G ^ H ^ I ^ J ^ K ^ L ^ M ^ N ^ O ^ P ^ | ^ Parts ^ A ^ B ^ C ^ D ^ E ^ F ^ G ^ H ^ I ^ J ^ K ^ L ^ M ^ N ^ O ^ P ^ | ||
- | | U1, C1, C14, C15, Y1 or Y3, C20, C21, R11, R12, R15, R16, C23, C24, R18, R19, R21, R22 | X | | + | | U1, C1, C14, C15, Y1 or Y3, C20, C21, R11, R12, | X | |
| R8, R9 | | X | | | R8, R9 | | X | | ||
| R33, R34 | | | R33, R34 | | ||
- | | U2, C2, Y2 or Y4, U10, C10, Q2, Q3, R4:6, R10, C22, R13, R17, C25, R20, R23, R24 | | + | | U2, C2, Y2 or Y4, U10, C10, Q2, Q3, R4:6, R10, C22, R13, | |
- | | J1, C12, L1, C13, C11, U4, C4, C16, R31, R32, C18, C19, U5, C5, C17, R25, R26, C29, C30, C31, C32, R27:30, J8 | X | | + | | J1, C12, L1, C13, C11 | X | |
| J6, R7 | | | J6, R7 | | ||
| U7, C7 | | | U7, C7 | | ||
| U8, C8 | | | U8, C8 | | ||
| U6, C6, Q1, R1 | | | U6, C6, Q1, R1 | | ||
- | | U9, C9, C26: | + | | U9, C9 | |
| J5 | | | J5 | | ||
| Short U3:5 to U3:15 | | | Short U3:5 to U3:15 | | ||
Line 213: | Line 212: | ||
| Short U8:3 to U8:6 | | | Short U8:3 to U8:6 | | ||
| U3, C3, J2 | | | U3, C3, J2 | | ||
+ | | U4, C4, U5, C5, C16:19, C23:32, R15:32, J8 | | ||
| Short U3:13 to J3:2, short U3:12 to J3:1 | | | Short U3:13 to J3:2, short U3:12 to J3:1 | | ||
| Short U3:11 to J3:2, short U3:10 to J3:1 | | | Short U3:11 to J3:2, short U3:10 to J3:1 | |
mbhp_genesis.txt · Last modified: 2023/09/05 04:19 by sauraen
