mbqg_fp
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
mbqg_fp [2021/01/31 02:36] – [Things You Need to Tell the Person Printing Them] smithy | mbqg_fp [2024/02/02 15:01] (current) – [MIDIbox Quad Genesis: Front Panel] smithy | ||
Line 4: | Line 4: | ||
To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below): | To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below): | ||
- | * An aluminum front panel | + | * An aluminum front panel |
* A PCB to hold all the buttons, LEDs, encoders, etc., and of course all these electronic components themselves | * A PCB to hold all the buttons, LEDs, encoders, etc., and of course all these electronic components themselves | ||
* A bunch of 3D printed transparent button caps | * A bunch of 3D printed transparent button caps | ||
Line 16: | Line 16: | ||
=== Dimensions === | === Dimensions === | ||
- | The aluminum (or acrylic) front panel of MIDIbox Quad Genesis is 15" x 11" (38.1 x 27.9 cm), and the front panel PCB itself is 13.85" x 9.85" (35.18 x 25.02 cm), leaving a 0.57" (1.45 cm) border around the edge. The aluminum I used was 1/16" (0.062" | + | The aluminum (or acrylic) front panel of MIDIbox Quad Genesis is 15" x 11" (38.1 x 27.9 cm), and the front panel PCB itself is 13.85" x 9.85" (35.18 x 25.02 cm), leaving a 0.57" (1.45 cm) border around the edge. The aluminum I used was 1/16" (0.062" |
The spacing between the underside of the front panel and the upper side of the PCB is about 0.27" (7 mm), which is originally defined by the encoders and the 3D printed buttons are made to match this. I used 1/4" nylon spacers/ | The spacing between the underside of the front panel and the upper side of the PCB is about 0.27" (7 mm), which is originally defined by the encoders and the 3D printed buttons are made to match this. I used 1/4" nylon spacers/ | ||
Line 36: | Line 36: | ||
[[http:// | [[http:// | ||
+ | ===== 3D Printed Front Panel ===== | ||
+ | Smithy has provided an STL file for a 2mm 3D Printed Front Panel with 1mm Raised Lettering as a more budget friendly option. It will require a printer with a bed side size typically of 400 x 400mm or larger. | ||
+ | This is currently untested and unprinted, and may require a resolution / layer height setting of 0.1mm to be accurate. More info to come when I have designed and 3D printed and a Rear Panel. | ||
+ | Please see the following guide to achieve a dual colour panel with a different colour for the lettering and for the panel: | ||
+ | [[http:// | ||
+ | ==== Download ==== | ||
+ | [[http:// | ||
===== MBQG_FP PCB ===== | ===== MBQG_FP PCB ===== | ||
Line 439: | Line 449: | ||
* The total cost to have these items printed should be roughly $20-$30 plus shipping. If someone is trying to charge you more than that, either there' | * The total cost to have these items printed should be roughly $20-$30 plus shipping. If someone is trying to charge you more than that, either there' | ||
==== Things You Need to Tell the Person Printing Them ==== | ==== Things You Need to Tell the Person Printing Them ==== | ||
- | * The scale in the STL files is 1 INCH, not 1 mm. The buttons should be about 1/2" or 12mm wide. (This is not intended as an engineering dimension, just as a sanity check--use the actual dimensions in the file.) | + | * The scale in the STL files is 1 INCH, not 1 mm. The buttons should be about 1/2" or 12mm wide. (This is not intended as an engineering dimension, just as a sanity check--use the actual dimensions in the file.) |
- | Update: Smithy has added additional STL files in metric scale below. | + | * **Update:** Smithy has added additional STL files in metric scale below. |
* Either ABS or PLA transparent filament should work. I had the guy who made them for me do tests with both, and I liked the light-up appearance of the ABS better but the " | * Either ABS or PLA transparent filament should work. I had the guy who made them for me do tests with both, and I liked the light-up appearance of the ABS better but the " | ||
* I had the guy who made them for me do tests with different fill rates, and if I remember correctly around 10% fill worked best. 100% fill would be needlessly expensive and would dim the LEDs. | * I had the guy who made them for me do tests with different fill rates, and if I remember correctly around 10% fill worked best. 100% fill would be needlessly expensive and would dim the LEDs. |
mbqg_fp.txt · Last modified: 2024/02/02 15:01 by smithy
