Next revision | Previous revision Next revision Both sides next revision | ||
mbqg_tb_case [2017/12/20 21:16] smithy created |
mbqg_tb_case [2017/12/21 01:31] smithy |
Line 1: | Line 1: | ||
===== MIDIbox Quad Genesis Case designed by Technobreath ===== | ===== MIDIbox Quad Genesis Case designed by Technobreath ===== | ||
+ | The case is designed by Technobreath to be easily replicated by the community without requiring much skills or tools. | ||
Here you will find a pdf with dimensions and building instructions for a wooden case designed for the MIDIbox Quad Genesis by user Technobreath: | Here you will find a pdf with dimensions and building instructions for a wooden case designed for the MIDIbox Quad Genesis by user Technobreath: | ||
Line 6: | Line 7: | ||
{{:building-instructions3.pdf|}} | {{:building-instructions3.pdf|}} | ||
- | Huge thanks goes to Technobreath for taking the time to design this case! | + | Please see this forum post in the Quad Genesis Build Guide Thread for further step by step instructions on how to build the case: |
+ | http://midibox.org/forums/topic/20619-build-guide-midibox-quad-genesis/?do=findComment&comment=180084 | ||
+ | Huge thanks to Technobreath for taking the time to design this case! |
