midi_interface_blacklist
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
midi_interface_blacklist [2008/04/04 07:37] – ganchan | midi_interface_blacklist [2014/03/31 21:30] – Added ? to SL37 lis0r | ||
Line 1: | Line 1: | ||
+ | To find midi devices known to work check the [[midi_interface_whitelist]]. | ||
Problems with SysEx transfers have been noticed with following MIDI interfaces: | Problems with SysEx transfers have been noticed with following MIDI interfaces: | ||
- | **Soundblaster Audigy:** some older driver versions don' | + | ^ Vendor ^ Model ^ notes ^ |
+ | | Access | Virus TI Polar :?: | Works unreliable for SysEx transfers under OS X (10.5). Suspected SysEx filtering. Plain MIDI sending/ | ||
+ | | Akai | MPD24 :?: | | | ||
+ | | Behringer | BCA2000 :?: | Works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | ||
+ | | Behringer | FCA1616 :?: | No SysEx activity on Mac OS X and Windows 7. | | ||
+ | | ::: | BCR2000 :?: | Works unreliable for SysEx transfers under OS X (10.5) and Windows (e.g. Vista). Plain MIDI sending/ | ||
+ | | Cakewalk/ | ||
+ | | CME | VX 5 :?: | Works unreliable for SysEx transfers under OS X (10.5). Suspected SysEx filtering. Plain MIDI sending/ | ||
+ | | Conrad Electronic | UA0037 | Bytes get lost during SysEx transfer under OSX and WinXP | | ||
+ | | E-MU | Xmidi 1x1 Tab | Works unreliable for SysEx transfers under Windows 7 64. See [[http:// | ||
+ | | ::: | Xmidi 2x2 | Same as above for Windows XP-64 bit. [[http:// | ||
+ | | ESI | MIDIMATE :?: | Works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | ||
+ | | ::: | RoMI/O II | In opposite to the RoMI/O I model this device uses native OS drivers and will therefore not be recognised by MIOS Studio. | | ||
+ | | iConnectivity | mio | Midi Out will not work through an LPC17 unless R21 & R26 are changed to 47 Ohm. See updated schematic and BOM in the mbhp_core_lpc17 page. | | ||
+ | | JUstin | Midi USB | Unstable SysEx Transfers (checksum errors) | ||
+ | | M-Audio | Audiophile USB :?: | | | ||
+ | | ::: | Keystation Pro 88 :?: | Works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | ||
+ | | ::: | MIDIsport 2x2 | Unstable SysEx transfers under MacOS 10.6 with most recent driver (last update: 2011) - was working stable years before, still works stable under Windows and Linux | | ||
+ | | NI | Kore 1 :?: | Unstable SysEx transfers (sporadic checksum errors) under MacOS, probably also under Windows. | | ||
+ | | //noname// | MIDI USB Adapter | Sold at ebay for US$7.99, also available at Maplin for £29.99 (what a difference...!) - incomplete SysEx transfers under MacOS! | | ||
+ | | Novation | Remote SL :?: | Unstable SysEx transfers | | ||
+ | | Novation | Remote SL37 limited edition :?: | Unstable MIDI, manifests as core resets, on Mac OS X. | | ||
+ | | Swisssonic | MIDI-USB 1X1 :?: | Works unreliable for SysEx transfers under Windows (e.g. Buffer overrun messages during code upload) | | ||
+ | | Tascam | US-122 :?: | Bytes get lost during SysEx transfer, even with the most recent windows driver version 3.3; model __US-122L__ is OK! | | ||
+ | | Yamaha | UX256 |:?: Bytes get lost during SysEx transfer under WinXP and 2000 (earlier versions not tested), even with most recent MIDI drivers (Yamaha // | ||
- | **Tascam US-122:** bytes get lost during SysEx transfer, even with the most recent windows driver version 3.3 | + | Devices marked with a :?: should be confirmed to be not working by a second user. If you can confirm that a device isn't suited for MB-usage, edit this page and remove |
- | + | :!: When adding to this list, try to keep it sorted alphabetically, please. | |
- | **Yamaha UX256:** bytes get lost during SysEx transfer under WinXP and 2000 (earlier versions not tested), even with most recent MIDI drivers (Yamaha // | + | |
- | **ESI MIDIMATE:** works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | + | |
- | **ESI Rom I/O II:** this device it's driver free, as the USB audio support in the OS automatically supports | + | |
- | **Behringer BCA2000:** works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | + | |
- | **M-Audio Keystation Pro 88:** works unreliable for SysEx transfers under Windows XP. Plain MIDI sending/ | + |
midi_interface_blacklist.txt · Last modified: 2015/06/12 15:16 by latigid_on
