midibox_ay_3_8912_volume
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
midibox_ay_3_8912_volume [2008/11/18 14:04] – lemonhorse | midibox_ay_3_8912_volume [2008/11/26 15:10] (current) – lemonhorse | ||
Line 1: | Line 1: | ||
===== MIDIBox AY 3 8912 - VOLUME MENU ===== | ===== MIDIBox AY 3 8912 - VOLUME MENU ===== | ||
+ | **MIDIBox AY 8912 Volume Respectively Amplitude Control:** | ||
* Press **F4** (F3 + SHIFT) FOR THE **USER VOLUME** MENU | * Press **F4** (F3 + SHIFT) FOR THE **USER VOLUME** MENU | ||
Line 6: | Line 8: | ||
- | ^TONE^VALUE^VELOCITY^ENVELOPE MODE^ | + | ^TONE^USER VALUE^CC7(A)/ |
- | | |priority 3|priority 2|priority 1| | + | | |priority 4|priority 3|priority 2|priority 1| |
- | |VOLUME CH. A|0 to 15|ON/ | + | |VOLUME CH. A|0 to 15|0 to 127 => coversation to 0-15|ON/ |
- | |VOLUME CH. B|0 to 15|ON/ | + | |VOLUME CH. B|0 to 15|0 to 127 => coversation to 0-15|ON/ |
- | |VOLUME CH. C|0 to 15|ON/ | + | |VOLUME CH. C|0 to 15|0 to 127 => coversation to 0-15|ON/ |
- | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON) === | + | === VOLUME |
- | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the volume value if the ENVELOPE MODE is activated. | + | Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. |
+ | See => [F7] Velocity Menu: Toggle Velocity to Volume Tone A, B and C or Noise Period ON/OFF | ||
+ | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, toggle Envelope Assignment to Tone A, B and C ON/OFF | ||
+ | === CONTROL CHANGE 7, 8 and 9 (MIDI CC EVENTS) === | ||
+ | The CONTROL CHANGE7 (VOLUME Tone A), CC8 (VOLUME Tone B) and CC9 (VOLUME Tone C) MIDI event overwrites the USER VOLUME VALUE (0-15) directly. | ||
+ | But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off. | ||
+ | See => MIDIBox AY 3 8912 CC LIST => [[MIDIBox_AY_3_8912_CC_LIST]] | ||
+ | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON/OFF) === | ||
+ | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. | ||
If the ENVELOPE MODE is in force the Volume Value will be overwritten. | If the ENVELOPE MODE is in force the Volume Value will be overwritten. | ||
For more Information about the ENVELOPE MODE see => [[midibox_ay_3_8912_envelope| ENVELOPE (MENU)]] | For more Information about the ENVELOPE MODE see => [[midibox_ay_3_8912_envelope| ENVELOPE (MENU)]] | ||
- | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON) === | + | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON/OFF) === |
If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | ||
Line 27: | Line 51: | ||
Note: if VELOCITY + ENVELOPE Mode is activated the ENVELOPE MODE is in effect. | Note: if VELOCITY + ENVELOPE Mode is activated the ENVELOPE MODE is in effect. | ||
+ | Press [F7] for the Velocity Menu (toggle Velocity to Volume Tone A, B and C or Noise Period) | ||
=== MANUAL VOLUME CONTROL === | === MANUAL VOLUME CONTROL === | ||
Line 32: | Line 59: | ||
See => [[midibox_ay_3_8912_mixer]] | See => [[midibox_ay_3_8912_mixer]] | ||
- | [18.11.2008] | + | [26.11.2008] |
midibox_ay_3_8912_volume.txt · Last modified: 2008/11/26 15:10 by lemonhorse
