midibox_ay_3_8912_volume
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
midibox_ay_3_8912_volume [2008/11/18 14:35] – lemonhorse | midibox_ay_3_8912_volume [2008/11/26 13:31] – lemonhorse | ||
Line 8: | Line 8: | ||
- | ^TONE^USER VALUE^CC7(A)/ | + | ^TONE^USER VALUE^CC7(A)/ |
| |priority 4|priority 3|priority 2|priority 1| | | |priority 4|priority 3|priority 2|priority 1| | ||
|VOLUME CH. A|0 to 15|0 to 127 => coversation to 0-15|ON/ | |VOLUME CH. A|0 to 15|0 to 127 => coversation to 0-15|ON/ | ||
Line 16: | Line 16: | ||
- | === VOLUME | + | === VOLUME |
- | Just adjust the USER VOLUME VALUE here. | + | Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. |
+ | See => [F7] Velocity Menu: Toggle Velocity to Volume Tone A, B and C or Noise Period ON/OFF | ||
+ | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, toggle Envelope Assignment to Tone A, B and C ON/ | ||
- | === CONTROL CHANGE 7,8 and 9 (MIDI CC EVENTS) === | + | === CONTROL CHANGE 7, 8 and 9 (MIDI CC EVENTS) === |
- | A CC7 (VOLUME A), CC8 (VOLUME B) and CC9 (VOLUME C) MIDI event overwrites the USER VOLUME VALUE (0-15) directly. | + | A CC7 (VOLUME |
But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off. | But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off. | ||
- | The MIDIBox AY 3 8912 CC LIST => [[MIDIBox_AY_3_8912_CC_LIST]] | + | See => MIDIBox AY 3 8912 CC LIST => [[MIDIBox_AY_3_8912_CC_LIST]] |
- | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON) === | + | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON/OFF) === |
- | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the volume value if the ENVELOPE MODE is activated. | + | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. |
If the ENVELOPE MODE is in force the Volume Value will be overwritten. | If the ENVELOPE MODE is in force the Volume Value will be overwritten. | ||
For more Information about the ENVELOPE MODE see => [[midibox_ay_3_8912_envelope| ENVELOPE (MENU)]] | For more Information about the ENVELOPE MODE see => [[midibox_ay_3_8912_envelope| ENVELOPE (MENU)]] | ||
Line 42: | Line 45: | ||
- | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON) === | + | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON/OFF) === |
If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | ||
Line 59: | Line 62: | ||
- | [18.11.2008] | + | [26.11.2008] |
midibox_ay_3_8912_volume.txt · Last modified: 2008/11/26 15:10 by lemonhorse
