midibox_ay_3_8912_volume [2008/11/26 12:48] lemonhorse |
midibox_ay_3_8912_volume [2008/11/26 12:58] lemonhorse |
Line 16: | Line 16: | ||
- | === VOLUME CH. ABC - USER VALUE === | + | === VOLUME TONE ABC - USER VALUE === |
Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. | Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. | ||
- | See => [F7] Velocity Menu (Switch Velocity to Volume Tone A, B and C or Noise Period) | + | See => [F7] Velocity Menu: Toggle Velocity to Volume Tone A, B and C or Noise Period ON/OFF |
- | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, Env. Assignment to Tone A, B and C | + | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, toggle Envelope Assignment to Tone A, B and C ON/OFF |
Line 32: | Line 32: | ||
But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off. | But the CC Value will only apply if the VELOCITY and the ENVELOPE mode is off. | ||
- | The MIDIBox AY 3 8912 CC LIST => [[MIDIBox_AY_3_8912_CC_LIST]] | + | See => MIDIBox AY 3 8912 CC LIST => [[MIDIBox_AY_3_8912_CC_LIST]] |
- | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON) === | + | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON/OFF) === |
There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. | ||
Line 45: | Line 45: | ||
- | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON) === | + | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON/OFF) === |
If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | ||
Line 62: | Line 62: | ||
- | [18.11.2008] | + | [26.11.2008] |
