midibox_ay_3_8912_volume [2008/11/26 12:50] lemonhorse |
midibox_ay_3_8912_volume [2008/11/26 13:31] lemonhorse |
Line 8: | Line 8: | ||
- | ^TONE^USER VALUE^CC7(A)/CC8(B)/CC9(C) MIDI VALUE^VELOCITY^ENVELOPE MODE^ | + | ^TONE^USER VALUE^CC7(A)/CC8(B)/CC9(C) MIDI VALUE^VELOCITY MODE^ENVELOPE MODE^ |
| |priority 4|priority 3|priority 2|priority 1| | | |priority 4|priority 3|priority 2|priority 1| | ||
|VOLUME CH. A|0 to 15|0 to 127 => coversation to 0-15|ON/OFF|ON/OFF| | |VOLUME CH. A|0 to 15|0 to 127 => coversation to 0-15|ON/OFF|ON/OFF| | ||
Line 16: | Line 16: | ||
- | === VOLUME CH. ABC - USER VALUE === | + | === VOLUME TONE ABC - USER VALUE === |
Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. | Just adjust the USER VOLUME VALUE here. You'll see no USER VOLUME VALUE if the [VELOCITY] or the [ENVELOPE] mode is activated. | ||
- | See => [F7] Velocity Menu (Switch Velocity to Volume Tone A, B and C or Noise Period) | + | See => [F7] Velocity Menu: Toggle Velocity to Volume Tone A, B and C or Noise Period ON/OFF |
- | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, Env. Assignment to Tone A, B and C | + | See => [F5] Envelope Control: Envelope Coarse, Env. Fine, Env. Shape, toggle Envelope Assignment to Tone A, B and C ON/OFF |
Line 37: | Line 37: | ||
- | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON) === | + | === ENVELOPE TO TONE ABC ON/OFF (ENVELOPE MODE ON/OFF) === |
There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. | There will be a [ENV.ON] @ Tone A or B or C on the User **Volume Control Menu** instead of the user volume value if the ENVELOPE MODE is activated. | ||
Line 45: | Line 45: | ||
- | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON) === | + | === VELOCITY TO TONE ABC ON/OFF (VELOCITY MODE ON/OFF) === |
If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. | If the VELOCITY MODE is activated there will be a [VELOCITY] @ Tone A, B or C on the **User Volume Control Menu** instead of the volume value. |
