Both sides previous revision Previous revision | Next revision Both sides next revision | ||
midibox_seq_quick_reference [2010/05/08 19:04] gjvti MB SEQ functions - quick reference part1+part2 |
midibox_seq_quick_reference [2010/05/09 15:42] gjvti MB SEQ functions - quick reference all three parts ready |
Line 8: | Line 8: | ||
^ **Dedicated button functions** //(theese can vary depending on panel design and MBSEQ_HW.V4 file)// ^^^ | ^ **Dedicated button functions** //(theese can vary depending on panel design and MBSEQ_HW.V4 file)// ^^^ | ||
- | | 1 \\ | Pattern\\ 1,2,3,4 | Select pattern/track group - G1, G2, G3, G4 \\ | | + | | 1 \\ | **Pattern**\\ 1,2,3,4 | Select pattern/track group - G1, G2, G3, G4 \\ | |
- | | 2 \\ | Track\\ 1,2,3,4 | Select track within track group - T1, T2, T3, T4. 16 tracks are available in total \\ | | + | | 2 \\ | **Track**\\ 1,2,3,4 | Select track within track group - T1, T2, T3, T4. 16 tracks are available in total \\ | |
- | | 3 \\ | Trigger layer\\ A,B,C | Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others\\ <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> \\ | | + | | 3 \\ | **Trigger layer**\\ A,B,C | Select trigger layer A or B or C. Holding C opens trigger layer selection menu and allows to select others\\ <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> \\ | |
- | | 4 \\ \\ | Parameter layer \\ A,B,C \\ | Select parameter layer A and B. C switches between C & D or with //Pressed&Hold// open parameter layer selection menu and allows to select others. \\ Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added via trigger selection menu //(?)// FIXME\\ <html> | Note | Vel | Length | Roll | </html>| | + | | 4 \\ \\ | **Parameter layer** \\ A,B,C \\ | Select parameter layer A and B. C switches between C & D or with //Pressed&Hold// open parameter layer selection menu and allows to select others. \\ Four parameter layers available by default, but CC, Pitch, Prob, Delay can be added __via trigger selection menu //(?)//__ FIXME\\ <html> | Note | Vel | Length | Roll | </html>| |
- | | 5 \\ | Step View \\ | View and select steps if more than 16 are used\\ <html> | 1..16 | 17..32 | ...etc</html> | | + | | 5 \\ | **Step View** \\ | View and select steps if more than 16 are used\\ <html> | 1..16 | 17..32 | ...etc</html> | |
- | | 6 \\ | Pattern \\ | Select/load pattern/track group G1, G2, G3, G4 from SD memory location \\ | | + | | 6 \\ | **Pattern** \\ | Select/load pattern/track group G1, G2, G3, G4 from SD memory location \\ | |
- | | 7 \\ | Song \\ | Select song parameters\\ <html> | Song # | Position | Action{Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes} || Select patterns: G1,G2,G3,G4 | </html> | | + | | 7 \\ | **Song** \\ | Select song parameters\\ <html> | Song # | Position | Action{Stop; x1..x16; Jump Pos; Jump Song; Mixer; Tempo; Mutes} || Select patterns: G1,G2,G3,G4 | </html> | |
- | | 8 \\ | Edit \\ | Enter edit mode to edit parameter layer step values and set trigger layer steps \\ | | + | | 8 \\ | **Edit** \\ | Enter edit mode to edit parameter layer step values and set trigger layer steps \\ | |
- | | 9 \\ | Mute \\ | Quickly mute/unmute tracks 1...16 \\ | | + | | 9 \\ | **Mute** \\ | Quickly mute/unmute tracks 1...16 \\ | |
- | | 10 \\ | Solo \\ | Solo current track \\ | | + | | 10 \\ | **Solo** \\ | Solo current track \\ | |
- | | 11 \\ | <-/-> \\ //(Left/Right)// | Move cursor position. //Left// has limited usage\\ | | + | | 11 \\ | **<-/->** \\ //(Left/Right)// | Move cursor position. //Left// has limited usage\\ | |
- | | 12 \\ | +/- \\ //(Inc/Dec)//| Same as //Jog Dial// encoder - increases/decreases the current value\\ | | + | | 12 \\ | **+/-** \\ //(Inc/Dec)//| Same as //Jog Dial// encoder - increases/decreases the current value\\ | |
- | | 13 \\ | Exit \\ | Quickly exit to top menu\\ | | + | | 13 \\ | **Exit** \\ | Quickly exit to top menu\\ | |
- | | 14 \\ | Select \\ | //(Press&Hold)// Select steps to be controlled by //All// function. Obviously has usage in other situations as well FIXME \\ | | + | | 14 \\ | **Select** \\ | //(Press&Hold)// Select steps to be controlled by //All// function. __Obviously has usage in other situations as well //(which?)//__ FIXME \\ | |
- | | 15 \\ | All \\ | Edit all selected steps set with //Select// function\\ | | + | | 15 \\ | **All** \\ | Edit all selected steps set with //Select// function\\ | |
- | | 16 \\ | Copy \\ | Copy steps from selected # to #. Selection can be edited by //Select// function\\ | | + | | 16 \\ | **Copy** \\ | Copy steps from selected # to #. Step # can be edited by //Select// function\\ | |
- | | 17 \\ | Paste \\ | Paste copied steps starting from # step. Selection can be edited by //Select// function\\ | | + | | 17 \\ | **Paste** \\ | Paste copied steps starting from # step. Step # can be edited by //Select// function\\ | |
- | | 18 \\ | F1\\ //(Clear)// | //(Press&Hold)// Wipe selected track. Other functions can be assigned in MBSEQ_HW.V4 file\\ | | + | | 18 \\ | **F1**\\ //(Clear)// | //(Press&Hold)// Wipe selected track. Other functions can be assigned in MBSEQ_HW.V4 file\\ | |
- | | 19 \\ | F2\\ //(Select track)// | //(Press&Hold)// Select track. Other functions can be assigned in MBSEQ_HW.V4 file\\ | | + | | 19 \\ | **F2**\\ //(Select track)// | //(Press&Hold)// Select track. Other functions can be assigned in MBSEQ_HW.V4 file\\ | |
- | | 20 \\ | F3\\ //(Select parameter layer)// | //(Press&Hold)// Select parameter layer A,B,C,D...etc. Other functions can be assigned in MBSEQ_HW.V4 file\\ | | + | | 20 \\ | **F3**\\ //(Select parameter layer)// | //(Press&Hold)// Select parameter layer A,B,C,D...etc. Other functions can be assigned in MBSEQ_HW.V4 file\\ | |
- | | 21 \\ | F4\\ //(Select trigger layer)// | //(Press&Hold)// Select/assign trigger layer 1..8. Other functions can be assigned in MBSEQ_HW.V4 file\\ | | + | | 21 \\ | **F4**\\ //(Select trigger layer)// | //(Press&Hold)// Select/assign trigger layer 1..8. Other functions can be assigned in MBSEQ_HW.V4 file\\ | |
- | | 22 \\ | Rec \\ | Open record menu\\ <html> | Track # | Record{Live; Step} | Mode{Mono; Poly} | AStart{on; off} | Step # | TglGate || Port # | Chn # | </html>| | + | | 22 \\ | **Rec** \\ | Open record menu\\ <html> | Track # | Record{Live; Step} | Mode{Mono; Poly} | AStart{on; off} | Step # | TglGate || Port # | Chn # | </html> | |
- | | 23 \\ | << \\ | Rewind. Active only in song mode\\ | | + | | 23 \\ | **<<** \\ | Rewind. Active only in song mode\\ | |
- | | 24 \\ | Stop \\ | Stop playback and reset position to beginning \\ | | + | | 24 \\ | **Stop** \\ | Stop playback and reset position to beginning \\ | |
- | | 25 \\ | Play \\ | Start playback of patterns/song \\ | | + | | 25 \\ | **Play** \\ | Start playback of patterns/song \\ | |
- | | 26 \\ | Pause \\ | Halt/resume playback \\ | | + | | 26 \\ | **Pause** \\ | Halt/resume playback \\ | |
- | | 27 \\ | >> \\ | Forward. Active only in song mode\\ | | + | | 27 \\ | **>>** \\ | Forward. Active only in song mode\\ | |
- | | 28 \\ | Metronome \\ | Toggle metronome on/off \\ | | + | | 28 \\ | **Metronome** \\ | Toggle metronome on/off \\ | |
- | | 29 \\ | Fast \\ | Activate //Fast// mode for quicker value selection with encoders. Speed options for //Fast// can be changed in MBSEQ_HW.V4 file\\ | | + | | 29 \\ | **Fast** \\ | Activate //Fast// mode for quicker value selection with encoders. Speed options for //Fast// can be changed in MBSEQ_HW.V4 file\\ | |
- | | 30 \\ | Scrub \\ | //(Press&Hold)// + //Jog Wheel// dynamically change actual position\\ | | + | | 30 \\ | **Scrub** \\ | //(Press&Hold)// + //Jog Wheel// dynamically change actual position\\ | |
^ **Menu functions** ^^^ | ^ **Menu functions** ^^^ | ||
- | | 31 \\ | Menu+Scrub \\ | Toggle loop mode on/off\\ | | + | | 31 \\ | **Menu+Scrub** \\ | Toggle loop mode on/off\\ | |
- | | 32 \\ | Menu+GP1\\ //(Mixer)// | Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with //Select// button FIXME \\ <html> | Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4 | </html> | | + | | 32 \\ | **Menu+GP1**\\ //(Mixer)// | Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with //Select// button __//More details?//__ FIXME \\ <html> | Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4 | </html> | |
- | | 33 \\ | Menu+GP2\\ //(Event)// | Open track setup editor\\ <html> | Track # | Type{Note; Chord; CC; Drum} | Step # | ParL # | TrgL # | Port # | Chn # | Edit Name | </html> | | + | | 33 \\ | **Menu+GP2**\\ //(Event)// | Open track setup editor\\ <html> | Track # | Type{Note; Chord; CC; Drum} | Step # | ParL # | TrgL # | Port # | Chn # | Edit Name | </html> | |
- | | 34 \\ \\ | Menu+GP3\\ //(Mode)//\\ | Open track mode editor\\ <html> | Track # | Track on/off | Normal, Transpose, Arpeggiator | </html>\\ <html> | | + | | 34 \\ \\ | **Menu+GP3**\\ //(Mode)// \\ | Open track mode editor\\ <html> | Track # | Track on/off | Normal, Transpose, Arpeggiator | </html>\\ <html> | |
Hold{on; off} | Sort{on; off} | Restart{on; off} | Scale{on; off} | Sustain{on; off} | </html> | | Hold{on; off} | Sort{on; off} | Restart{on; off} | Scale{on; off} | Sustain{on; off} | </html> | | ||
- | | 35 \\ \\ | Menu+GP4\\ //(Direction)//\\ | Open track playback direction editor\\ <html> | Track # | Select playback mode: Forward, Backward, PingPong, Pendulum, Rand.Dir, Rand.Step, Rand.D+S | </html>\\ <html> | Fwd # | Back # | Replay # | Repeat # | Skip # | Itv # | SyncM{yes; no} | </html> | | + | | 35 \\ \\ | **Menu+GP4**\\ //(Direction)//\\ | Open track playback direction editor\\ <html> | Track # | Select playback mode: Forward, Backward, PingPong, Pendulum, Rand.Dir, Rand.Step, Rand.D+S | </html>\\ <html> | Fwd # | Back # | Replay # | Repeat # | Skip # | Itv # | SyncM{yes; no} | </html> | |
- | | 36 \\ | Menu+GP5\\ //(Divider)// | Open track clock divider setup editor\\ <html> | Track # | Clock # | Divider{normal; triplet} | Sync to Measure{on; off} || Timebase selector: 1, 2, 4, 8 ..etc | </html> | | + | | 36 \\ | **Menu+GP5**\\ //(Divider)// | Open track clock divider setup editor\\ <html> | Track # | Clock # | Divider{normal; triplet} | Sync to Measure{on; off} || Timebase selector: 1, 2, 4, 8 ..etc | </html> | |
- | | 37 \\ | Menu+GP6\\ //(Length)// | Open track length editor\\ <html> | Track # | Length # | Loop # || Quick length selection: 4, 8, 16 ..etc | </html> | | + | | 37 \\ | **Menu+GP6**\\ //(Length)// | Open track length editor\\ <html> | Track # | Length # | Loop # || Quick length selection: 4, 8, 16 ..etc | </html> | |
- | | 38 \\ | Menu+GP7\\ //(Transpose)// | Open track transpose editor\\ <html> | Track # | Transpose selector: -7 oct ... +7 oct | -7 sem ... +7 sem | </html> | | + | | 38 \\ | **Menu+GP7**\\ //(Transpose)// | Open track transpose editor\\ <html> | Track # | Transpose selector: -7 oct ... +7 oct | -7 sem ... +7 sem | </html> | |
- | | 39 \\ | Menu+GP8\\ //(Transpose)// | Open track groove editor\\ <html> | Track # | Groove style{off; shuffle ... etc} | Intensity # || Step # | Dly # | Len # | Vel # | Num Steps # | </html> | | + | | 39 \\ | **Menu+GP8**\\ //(Groove)// | Open track groove editor\\ <html> | Track # | Groove style{off; shuffle ... etc} | Intensity # || Step # | Dly # | Len # | Vel # | Num Steps # | </html> | |
- | | 40 \\ | Menu+GP9\\ //(Trigger)// | Open track trigger layer selection menu\\ <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> | | + | | 40 \\ | **Menu+GP9**\\ //(Trigger)// | Open track trigger layer selection menu\\ <html> | Gate | Acc | Roll | Glide | Skip | R.G(random gate) | R.V(random value) | No FX | </html> | |
- | | 41 \\ \\ \\ \\ \\ \\ \\ \\ | Menu+GP10\\ //(FX)//\\ \\ \\ \\ \\ \\ \\ | Open FX editor\\ <html> | Local{Echo; Hum; Limit; LFO} || Global{Loop; Scale} | </html> \\ <html> ·[Echo] | Track # | Repeats # | Delay # | Vel.Lev # || FB Velocity % | Note # | Gatelen % | Tcks % | </html> \\ <html> ·[Hum] | Track # | Intensity # | Note{on; off} | Vel/CC{on; off} | Length{on; off} | </html> \\ <html> ·[Limit] | Track # | Lower # | Upper # | </html> \\ <html> ·[LFO] | Track # | Wave{off; sine ..etc} | Amp # | Phs % | Steps # | Rst # | OneShot{on; off} |</html>\\ <html> | Note{on; off} | Vel{on; off} | Len{on; off} | CC{on; off} | ExtraCC # | Offs # | PPQN # </html> \\ <html> ·[Loop] | Mode{all tracks / step view ..etc} | Offset # | Steps # | Loop{on; off]} </html> \\ <html> ·[Scale] | Control{global, G1, G2 ..etc} | Root{Keyb, C ...etc} | Selected scale{major; minor ...etc} </html> \\ | | + | | 41 \\ \\ \\ \\ \\ \\ \\ \\ | **Menu+GP10**\\ //(FX)//\\ \\ \\ \\ \\ \\ \\ | Open FX editor\\ <html> | Local{Echo; Hum; Limit; LFO} || Global{Loop; Scale} | </html> \\ <html> ·[Echo] | Track # | Repeats # | Delay # | Vel.Lev # || FB Velocity % | Note # | Gatelen % | Tcks % | </html> \\ <html> ·[Hum] | Track # | Intensity # | Note{on; off} | Vel/CC{on; off} | Length{on; off} | </html> \\ <html> ·[Limit] | Track # | Lower # | Upper # | </html> \\ <html> ·[LFO] | Track # | Wave{off; sine ..etc} | Amp # | Phs % | Steps # | Rst # | OneShot{on; off} |</html>\\ <html> | Note{on; off} | Vel{on; off} | Len{on; off} | CC{on; off} | ExtraCC # | Offs # | PPQN # </html> \\ <html> ·[Loop] | Mode{all tracks / step view ..etc} | Offset # | Steps # | Loop{on; off]} </html> \\ <html> ·[Scale] | Control{global, G1, G2 ..etc} | Root{Keyb, C ...etc} | Selected scale{major; minor ...etc} </html> \\ | |
- | | 42 \\ | Menu+GP11\\ //(Manual trigger)// | Manualy trigger steps, //(Press&Hold)+Select// for sync to measure\\ <html> | | </html> FIXME | | + | | 42 \\ | **Menu+GP11**\\ //(Manual trigger)// | Manualy trigger steps, //(Press&Hold)+Select// for sync to measure\\ <html> | | </html> __//options?//__ FIXME | |
- | | 43 \\ | Menu+GP12\\ //(Morph)// | Open track morphing setup\\ <html> | Track # | Mode{on; off} | Dst.Range # | Value # || Morphing control (also by CC1) | </html> | | + | | 43 \\ | **Menu+GP12**\\ //(Morph)// | Open track morphing setup\\ <html> | Track # | Mode{on; off} | Dst.Range # | Value # || Morphing control (also by CC1) | </html> | |
- | | 44 \\ \\ | Menu+GP13\\ //(BPM)//\\ | Open BPM settings editor FIXME \\ <html> | Mode{Auto; Slave; Master} | Preset # | Tempo # | Ramp sec. | Fire Preset | Preset Page |</html>\\ <html>| | + | | 44 \\ \\ | **Menu+GP13**\\ //(BPM)//\\ | Open BPM settings editor __//Options for In and Out?//__ FIXME \\ <html> | Mode{Auto; Slave; Master} | Preset # | Tempo # | Ramp sec. | Fire Preset | Preset Page |</html>\\ <html> | MClk{USB1 ..etc} | In (?) | Out (?) | Din PPQN # | Ext.Restart | Tap Tempo | </html> | |
- | MClk{USB1 ..etc} | In (?) | Out (?) | Din PPQN # | Ext.Restart | Tap Tempo | </html> | | + | | 45 \\ | **Menu+GP14**\\ //(Save)// | Open save menu\\ <html> | Group # | Location # | Target # | Save || Category | Label | </html> | |
- | | 45 \\ | Menu+GP14\\ //(Save)// | Open save menu\\ <html> | Group # | Location # | Target # | Save || Category | Label | </html> | | + | | 46 \\ \\ \\ \\ | **Menu+GP15**\\ //(MIDI)//\\ \\ \\ | Opens midi setup editor \\ <html> ·[Transpose and arp] Port # | Chn # | T/A Split{on; off} | Midd.Note # | Reset Stcks</html>\\ <html> ·[Section Control] Port # | Chn # | G1 # | G2 # | G3 # | G4 # | Fwd port | Reset Stcks</html>\\ <html> ·[Midi Router] Node # | In port | Chn # | Out port | Chn # | Default Port</html>\\ <html> ·[Misc] BLM_Scalar port{on; off} | Midi Monitor </html> | |
- | | 46 \\ \\ \\ \\ | Menu+GP15\\ //(MIDI)//\\ \\ \\ | Opens midi setup editor \\ <html> ·[Transpose and arp] Port # | Chn # | T/A Split{on; off} | Midd.Note # | Reset Stcks</html>\\ <html> ·[Section Control] Port # | Chn # | G1 # | G2 # | G3 # | G4 # | Fwd port | Reset Stcks</html>\\ <html> ·[Midi Router] Node # | In port | Chn # | Out port | Chn # | Default Port</html>\\ <html> ·[Misc] BLM_Scalar port{on; off} | Midi Monitor </html> | | + | | 47 \\ | **Menu+GP16**\\ //(SysEx)// | SysEx operations __//Options?//__ FIXME\\ | |
- | | 47 \\ | Menu+GP16\\ //(SysEx)// | SysEx operations FIXME\\ | | + | |
^ **Utility functions** ^^^ | ^ **Utility functions** ^^^ | ||
- | | will be continued :) ||| | + | | 48 \\ | **Utility+GP1**\\ //(Track Select)// | Select active track \\ | |
+ | | 49 \\ | **Utility+GP2**\\ //(Copy)// | Copy steps from selected # to #. Step # can be edited by //Select// function\\ | | ||
+ | | 50 \\ | **Utility+GP3**\\ //(Paste)// | Paste copied steps starting from # step. Step # can be edited by //Select// function\\ | | ||
+ | | 51 \\ | **Utility+GP4**\\ //(Clear)// | Wipe the track. **No options - Wipes the track instantly!!!**\\ | | ||
+ | | 52 \\ | **Utility+GP5**\\ //(Move)// | Move selected steps (like copy and paste together)\\ | | ||
+ | | 53 \\ | **Utility+GP6**\\ //(Scroll)// | Scroll the steps across\\ | | ||
+ | | 54 \\ | **Utility+GP7**\\ //(Random)// | Generates random events\\ <html> | Track # | Generate | Clr | Util | Undo || LayerA # | LayerB # | LayerC # | TrgA # | Trg B # | Trg C # | </html>\\ | | ||
+ | | 55 \\ | **Utility+GP8**\\ //(Undo)// | Undo last //Paste, Clear, Move, Scroll, Random// operation\\ | | ||
+ | | 56 \\ | **Utility+GP9**\\ //(Save)// | Open save menu\\ <html> | Group # | Location # | Target # | Save || Category | Label | </html>\\ | | ||
+ | | 57 \\ | **Utility+GP10**\\ //(Record)// | Open record menu\\ <html> | Track # | Record{Live; Step} | Mode{Mono; Poly} | AStart{on; off} | Step # | TglGate || Port # | Chn # | </html> | | ||
+ | | 58 \\ | **Utility+GP11**\\ //(Mixer)// | Open mixer view for 16 tracks. 12 pages can be switched with +/-. An additional options available with //Select// button __//More details?//__ FIXME \\ <html> | Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4 | </html> | | ||
+ | | 59 \\ \\ | **Utility+GP12**\\ //(Options)// \\ | Open options menu\\ <html> | Measure # | Pattern # | SyncChange (on, off) | Paste/Clr steps | </html>\\ <html> | Remote{auto;client;server} | ID # | Port # | Request connection{no} | </html> | | ||
+ | | 60 \\ | **Utility+GP13**\\ //(Port Mute)// | Access output port muting menu\\ <html> | Def | USB1 | USB2 ...etc... AOUT | Bus1 | Bus2 | </html> | | ||
+ | | 61 \\ | **Utility+GP14**\\ //(Disk)// | Open disk menu\\ <html> MSD USB{disabled; enabled/Pres&Hold/} | Midi files{import; export; play} </html> | | ||
+ | | 62 \\ | **Utility+GP15**\\ //(Mute)// | Quick mute of all tracks/channels \\ | | ||
+ | | 63 \\ | **Utility+GP16**\\ //(Unmute)// | Quick unmute of all tracks/channels \\ | | ||
