midibox_sid_faq
Differences
Next revision | Previous revisionNext revisionBoth sides next revision | ||
midibox_sid_faq [2006/05/01 19:12] – created moebius | midibox_sid_faq [2008/03/03 13:22] – SLP | ||
Line 1: | Line 1: | ||
**MIDIbox SID FAQ** | **MIDIbox SID FAQ** | ||
- | ===== Do I need the big and expensive control surface to get some sound out of my SID? ===== | ||
- | No, you can control all sound parameters of your MIDIbox SID from a computer, with some ergonomic limitations also from a common MIDI controller. However, the dedicated control surface is the optimum solution to control the SID. | + | FIXME FAQ is outdated, many details are not matching anymore |
- | ===== Do I need a PIC18F452 for my SID or can I reuse my old PIC16F877? ===== | + | ===== Do I need the most elaborate control surface to get some sound out of my SID? ===== |
- | Both microcontrollers are supported, but the control surface | + | No. Although |
+ | ===== Which PIC is required? ===== | ||
- | ===== Where can I purchase a SID (6581 or 8580)? ===== | + | MIDIbox |
- | Unfortunately the SID has been discontinued, | + | MIDIbox |
- | *Addendum:* if you don't find a C64 or SID at EBay, try it [[http:// | + | ===== Where can I purchase |
+ | Unfortunately, | ||
- | ===== How can I realize a stereo | + | Other places you might find Commodore computers or SID chips: |
+ | * [[http:// | ||
- | Currently only with two CORE and two SID modules. \\ | + | ===== How can I make a stereo |
- | Note that [[http:// | + | |
+ | Since the SID is a mono device; to get stereo output, you need more than one SID module. | ||
+ | The MIDIbox SID V2 firmware allows you to control up to 4 cores, (with each core capable of controlling two SIDs), allowing you to have up to 8 SID audio channels. | ||
===== What is the purpose of the Audio Input? ===== | ===== What is the purpose of the Audio Input? ===== | ||
- | It allows you to chain SID modules. | + | The Audio Input allows you to chain SID modules |
+ | It's also possible to use the Audio Input for ' | ||
+ | Details are explained [[http:// | ||
===== How can I save my sound creations? ===== | ===== How can I save my sound creations? ===== | ||
- | If the control surface is enabled, you can save the patch into a BankStick from the SAV menu. | + | If the control surface is enabled, you can save the patch into a [[BankStick]] from the SAV menu. |
You can also request a dump of a patch with < | You can also request a dump of a patch with < | ||
Line 49: | Line 59: | ||
===== Do I need a BankStick to get the MIDIbox SID running? ===== | ===== Do I need a BankStick to get the MIDIbox SID running? ===== | ||
- | The BankStick is an optional feature. If no stick is connected, only one patch can be stored into the internal EEPROM. | + | No, the BankStick is an optional feature. |
- | All 128 patch positions are directed to the internal patch. | + | If no stick is connected, one patch can be stored in the internal EEPROM, and all 128 patch positions are directed to the internal patch. |
- | This is still usefull | + | This is still useful |
Line 63: | Line 73: | ||
===== How does MIDIbox SID cooperate with other MIDIboxes? ===== | ===== How does MIDIbox SID cooperate with other MIDIboxes? ===== | ||
- | A MIDIbox can send _F0 00 00 7E 46 < | + | A MIDIbox can send < |
Line 136: | Line 146: | ||
This is described in the JSynthLib guide [[http:// | This is described in the JSynthLib guide [[http:// | ||
+ | ===== How do I supply power to the MIDIbox SID? ===== | ||
- | ===== How to supply | + | The recommended |
- | Without the C64 PSU it's better to use seperate power supplies. One for the SID module (15V/100 mA should be ok), another for the digital modules (7V/500 mA are possibly enough) | + | Without the C64 PSU, it's better to use separate transformers: |
- | It can work with a single | + | Though |
+ | //(Note that 7800-series voltage regulators typically require an input voltage of 3V above their output voltage)// | ||
===== Will feature X be implemented? | ===== Will feature X be implemented? | ||
- | There are several things to consider before a new feature is implemented. Will it be used by a lot of people? Is the hardware really able to do that, will it use up too much memory? Remember, we're only using a PIC here. Also, the MB SID is built in such a way that each editable feature has to have a MIDI CC number. | + | There are several things to consider before a new feature is implemented: |
+ | * Will it be used by a lot of people? | ||
+ | * Is the hardware really able to do that? | ||
+ | * Will it use up too much memory? | ||
+ | Remember, we're only using a PIC here. | ||
+ | Keep in mind that the MIDIbox | ||
+ | In TK's words: | ||
//Sounds strange? Here the reason why I'm always very carefully with new features: check the CC list of MIDIbox SID and you will notice that most CC parameters are allocated. Check the content of the SysEx dump (e.g. in the JSynthLib driver) and you will notice that also there most of the memory is allocated (and I already did a lot of tricks).// | //Sounds strange? Here the reason why I'm always very carefully with new features: check the CC list of MIDIbox SID and you will notice that most CC parameters are allocated. Check the content of the SysEx dump (e.g. in the JSynthLib driver) and you will notice that also there most of the memory is allocated (and I already did a lot of tricks).// | ||
Line 154: | Line 175: | ||
Also, using another MIDI channel to make more CC numbers available (again, TK) // | Also, using another MIDI channel to make more CC numbers available (again, TK) // | ||
+ | ===== Can we get better envelopes? ATDTLDTSRTR ;)? ===== | ||
+ | This would use up more MIDI CC numbers and more memory. | ||
+ | See "// | ||
===== Can you connect multiple SIDs in parallel to one Core, to get a " | ===== Can you connect multiple SIDs in parallel to one Core, to get a " | ||
- | You can - but beware, the SID's oscilators are DCOs, which means they' | + | Yes, this feature is available starting with the MIDIbox |
+ | FIXME Is this next piece still relevant? | ||
As TK says: //you can connect multiple SID modules to one core module, in this case they always listen to the same control data. But the audible effect isn't really so interesting. If you are having two identical SIDs, then the volume will just be doubled (the oscillators are digital and therefore always output exactly the same waveform). | As TK says: //you can connect multiple SID modules to one core module, in this case they always listen to the same control data. But the audible effect isn't really so interesting. If you are having two identical SIDs, then the volume will just be doubled (the oscillators are digital and therefore always output exactly the same waveform). | ||
This option can make sense if you want to switch between 6581 and 8580 because of the different filter characteristics. | This option can make sense if you want to switch between 6581 and 8580 because of the different filter characteristics. | ||
But for really interesting (especially fat) sounds, seperate cores are the best option, so that the SID parameters are modulated independent from each other. The result is much more analog-like(especially when the LFOs are in freerunning mode and the finetune/ | But for really interesting (especially fat) sounds, seperate cores are the best option, so that the SID parameters are modulated independent from each other. The result is much more analog-like(especially when the LFOs are in freerunning mode and the finetune/ | ||
- | ===== Can we get better envelopes? ATDTLDTSRTR ;)? ===== | ||
- | This would use up more MIDI CC numbers, and memory. And you know you should take care with that! | ||
Line 209: | Line 232: | ||
I'd go with that suggestion :) | I'd go with that suggestion :) | ||
===== How do I make the MB SID sound more phat? ===== | ===== How do I make the MB SID sound more phat? ===== | ||
Line 216: | Line 238: | ||
Try guitar effects. It's unbelievable what evil a simple fuzz can do to a lead or a nice " | Try guitar effects. It's unbelievable what evil a simple fuzz can do to a lead or a nice " | ||
+ | You can also beef up the sound of SID's filters by routing the SID output back to its input. | ||
===== Does MIDIbox SID support graphical LCDs? ===== | ===== Does MIDIbox SID support graphical LCDs? ===== | ||
Line 247: | Line 270: | ||
- | ===== Why does MIDIbox SID stop playing a note when a patch is changed ===== | ||
- | this would lead to many unwanted side effects and wouldn' | + | ===== Why must MIDIbox |
- | A proper patch change without reset would also require that the whole patch data is transfered to the SID as well as to the sound engine within one update cycle (0.8 mS), this is not possible with the PIC. It's especially not possible to send so much data to the slaves within this short timewindow, since the transfer takes ca. 260 mS. | + | Changing this behaviour would lead to many unwanted side effects and wouldn' |
+ | A proper patch change without reset would require that the whole patch is transfered to the SID as well as to the sound engine within one update cycle (0.8 mS), which is not possible with the PIC. It's especially not possible to send so much data to the slaves within this short timewindow, since the transfer takes about 260 ms. | ||
Line 271: | Line 295: | ||
However, just another remark: if the PIC18F4620 wouldn' | However, just another remark: if the PIC18F4620 wouldn' | ||
+ | ===== What parts can be left out from the core modules when building a multi SID synth? ===== | ||
+ | Thanks wilba for the tip, you can remove everything to the left of the regulator including the regulator shown on the multi sid PDF. Remember to bridge the core PCB's where the regulators used to be. I have also heard of swapping the 2200uf cap, and not including the bridge on the cores too but I have not tested it (dcer10). Also remember when you are testing the multi sid that you need to press the link button to hear the extra sids! | ||
+ | ===== How do I connect the SID-module to the Core-module ===== | ||
+ | This question has been asked many times in the forum. | ||
+ | The pins don't all match name for name, that's the confusing bit! The pins to connect will be in the same position on those 2x5 headers. | ||
+ | It should be a 1:1 connection: | ||
+ | |Core: | ||
+ | |Vd| Vc| | ||
+ | |Vs| Vs| | ||
+ | |CLK| CLK| | ||
+ | |SC| --| | ||
+ | |MU| MU| | ||
+ | |RC| RC| | ||
+ | |MD| SC| | ||
+ | |SO| SO| | ||
+ | To avoid ground loops, it is recommended to use Vd and Vs from J2 of the Core module instead of J10. |
midibox_sid_faq.txt · Last modified: 2011/11/18 12:04 by lpdunwell
