midibox_sid_faq
Differences
midibox_sid_faq [2006/05/10 21:12] – nebula | midibox_sid_faq [2008/03/03 13:22] – SLP | ||
Line 1: | Line 1: | ||
+ | **MIDIbox SID FAQ** | ||
+ | FIXME FAQ is outdated, many details are not matching anymore with the current [[http:// | ||
+ | ===== Do I need the most elaborate control surface to get some sound out of my SID? ===== | ||
+ | No. Although the dedicated control surface is the optimum solution to control the SID, you can control all sound parameters of your MIDIbox SID from a computer or from a common MIDI controller (although the MIDI controller option has some ergonomic limitations). | ||
+ | ===== Which PIC is required? ===== | ||
+ | MIDIbox SID 2.0 requires a PIC18F4685. | ||
+ | MIDIbox SID 1.x required a PIC18F452 for the master and control surface, while the " | ||
+ | ===== Where can I purchase a SID (6581 or 8580)? ===== | ||
+ | Unfortunately, | ||
+ | Other places you might find Commodore computers or SID chips: | ||
+ | * [[http:// | ||
+ | ===== How can I make a stereo SID synth? ===== | ||
+ | Since the SID is a mono device; to get stereo output, you need more than one SID module. | ||
+ | The MIDIbox SID V2 firmware allows you to control up to 4 cores, (with each core capable of controlling two SIDs), allowing you to have up to 8 SID audio channels. | ||
+ | ===== What is the purpose of the Audio Input? ===== | ||
+ | The Audio Input allows you to chain SID modules together. The signal from the Audio Input goes through the multistate filter. \\ | ||
+ | It's also possible to use the Audio Input for ' | ||
+ | Details are explained [[http:// | ||
+ | ===== How can I save my sound creations? ===== | ||
+ | If the control surface is enabled, you can save the patch into a [[BankStick]] from the SAV menu. | ||
+ | You can also request a dump of a patch with < | ||
+ | Update: TL has implemented a really useful "Patch Manager" | ||
+ | ===== How many patches can be saved in a BankStick? ===== | ||
+ | Up to 127 patches can be saved in a BankStick. They can be selected with the " | ||
+ | Up to 8 BankSticks can be connected to MIDIbox SID - makes 1016 patches in total. | ||
+ | Banks can be selected with CC #0 | ||
+ | Patch #1 of a bank is always the internal patch, regardless if a BankStick is connected or not. | ||
+ | ===== Do I need a BankStick to get the MIDIbox SID running? ===== | ||
+ | No, the BankStick is an optional feature. | ||
+ | If no stick is connected, one patch can be stored in the internal EEPROM, and all 128 patch positions are directed to the internal patch. | ||
+ | This is still useful if you manage the sound patches from the JSynthLib librarian and don't need quick access to your favourite sounds. | ||
+ | ===== How can I store patches into the slaves ===== | ||
+ | Due to the " | ||
+ | ===== How does MIDIbox SID cooperate with other MIDIboxes? ===== | ||
+ | A MIDIbox can send < | ||
+ | ===== How can I change the MIDI channel? ===== | ||
+ | If the " | ||
+ | If the control surface is not enabled (minimal version of MIDIbox SID), the channel can be changed with following SysEx command: | ||
+ | ===== How can I change the Device ID? ===== | ||
+ | So long the AUTO_DEVICE_ID switch is enabled (this is the default setting), the device ID will be derived from the MIOS Device ID. This is the most comfortable (and less confusing) solution. In this case, the ID cannot be changed from a menu, and also not via SysEx. | ||
+ | If the AUTO_DEVICE_ID switch is disabled, you can change the ID within the CFG menu, or via SysEx: | ||
+ | ===== How can I create Wavetables? ===== | ||
+ | Wavetables can be edited with the JSynthLib Editor or from the Control Surface. First you should check the example patches which can be downloaded below. The preset library includes some demonstrations of this powerfull feature (patch names begin with WT). You can define up to 32 table entries for 3 different CC parameters which are played with every note. Most common parameters are " | ||
+ | Four different directives can be selected for each entry: " | ||
+ | The three parameter columns are used to enter absolute or relative values for the three CC parameters. Normaly a wavetable begins with absolute values for a defined start when a new note is played (examples: 40 - don't transpose, 3F: minus one note, 41: plus one note. Values can also be entered in decimal form, but a real C64 hacker proscribes such a unusual number system, so both variants are available ;-). For the other values below the first row it's your choice. Pitches (Transpose values) are normaly entered as relative values (begin with a + or -), Waveforms as absolute values (examples: 01 - Triangle, 02 - Saw, 04 - Pulse, 08 - Noise, 12 - oscillator saw & off, 21 - synced triangle). Refer to the [[http:// | ||
+ | Here an example for a snare drum: | ||
+ | CC Parameter #1 assigned to Voice1 Waveform | ||
+ | CC Parameter #2 assigned to Voice1 Transpose | ||
+ | CC Parameter #3 not used here | ||
+ | Rate (Speed) set to 119 | ||
+ | 00 | ||
+ | 01 | ||
+ | 02 | ||
+ | 03 | ||
+ | 04 | ||
+ | 05 | ||
+ | 06 | ||
+ | The result can be heared at the beginning of [[http:// | ||
+ | Another example, a synth sound with loop point: | ||
+ | CC Parameter #1 assigned to Voice1/2/3 Transpose | ||
+ | CC Parameter #2 not used here | ||
+ | Rate (Speed) set to 88 | ||
+ | 00 | ||
+ | 01 | ||
+ | 02 | ||
+ | 03 | ||
+ | 04 | ||
+ | 05 | ||
+ | This result into a nice dropping sound, known from C64 games :) | ||
+ | However, this was just a short introduction, | ||
+ | *Update:* since v1.5 it is also possible to trigger notes and arpeggiator keys from the wavetable sequencer in order to realize more complex textures. The appr. CCs are #8-#11. Examples can be found in the preset patch library (patch #64 upwards). | ||
+ | ===== How do I start the JSynthLib editor? ===== | ||
+ | This is described in the JSynthLib guide [[http:// | ||
+ | ===== How do I supply power to the MIDIbox SID? ===== | ||
+ | The recommended power supply for MIDIbox SID is a Commodore 64 Power Supply. | ||
+ | Without the C64 PSU, it's better to use separate transformers: | ||
+ | Though a single power supply may work, the voltage needs to be high enough to supply the regulator on your SID board. Because of the higher input voltage, the 5V (7805) regulators on your CORE module(s) will get very hot, especially if you are powering a backlit LCD. | ||
+ | //(Note that 7800-series voltage regulators typically require an input voltage of 3V above their output voltage)// | ||
+ | ===== Will feature X be implemented? | ||
+ | There are several things to consider before a new feature is implemented: | ||
+ | * Will it be used by a lot of people? | ||
+ | * Is the hardware really able to do that? | ||
+ | * Will it use up too much memory? | ||
+ | Remember, we're only using a PIC here. | ||
+ | Keep in mind that the MIDIbox SID is built in such a way that each editable feature has to have a MIDI CC number. Since most of the MIDI CC numbers are already used, you'll need a //Really Good Reason< | ||
+ | In TK's words: | ||
+ | //Sounds strange? Here the reason why I'm always very carefully with new features: check the CC list of MIDIbox SID and you will notice that most CC parameters are allocated. Check the content of the SysEx dump (e.g. in the JSynthLib driver) and you will notice that also there most of the memory is allocated (and I already did a lot of tricks).// | ||
+ | //Oh, now you possibly come with the suggestion that NRPN should be used instead of CC --- no chance! One of my focus was always the capability to control all parameters via external sequencers/ | ||
+ | //Next suggestion from your side could be to remove some uninteresting parameters from the CC list to make some new place free for new ones. But this is also nearly impossible, since the internal parameter handling relies on CC parameters. A different implementation would consume much more memory (which means: some nice new functions would possibly never fit into memory anymore)// | ||
+ | Also, using another MIDI channel to make more CC numbers available (again, TK) // | ||
+ | ===== Can we get better envelopes? ATDTLDTSRTR ;)? ===== | ||
+ | This would use up more MIDI CC numbers and more memory. | ||
+ | See "// | ||
+ | ===== Can you connect multiple SIDs in parallel to one Core, to get a " | ||
+ | Yes, this feature is available starting with the MIDIbox SID 2.0. | ||
+ | FIXME Is this next piece still relevant? | ||
+ | As TK says: //you can connect multiple SID modules to one core module, in this case they always listen to the same control data. But the audible effect isn't really so interesting. If you are having two identical SIDs, then the volume will just be doubled (the oscillators are digital and therefore always output exactly the same waveform). | ||
+ | This option can make sense if you want to switch between 6581 and 8580 because of the different filter characteristics. | ||
+ | But for really interesting (especially fat) sounds, seperate cores are the best option, so that the SID parameters are modulated independent from each other. The result is much more analog-like(especially when the LFOs are in freerunning mode and the finetune/ | ||
+ | ===== Can we get faster LFOs, WTs? ===== | ||
+ | The SID chip can only be updated at 1220 Hz. Because of that, an LFO starts to " | ||
+ | ===== Is Oscillator FM doable with the SID chips? ===== | ||
+ | As TK puts it: //no// | ||
+ | ===== Is it possible to add morphing between the patches of MB SID? ===== | ||
+ | It would require memory for a mirror of all parameters (old ones you're morphing from and new ones to morph to). And even more memory for the morphing itself. Conclusion: can't be done really. | ||
+ | ===== Can you implement modulation depth values in the modulation matrix? ===== | ||
+ | In words of TK: //typical question from somebody who thinks that if other synths have a depth pot for each modulation target, MBSID must have the same. Some technical background: I started MIDIbox SID ca. 3 years ago on a PIC16F877 which doesn' | ||
+ | The result is the same. | ||
+ | Not exactly, because common synths mostly don't provide 6 LFOs and two envelopes for a mono voice, they provide seperate depths instead just as a workaround for this limitation. This means also, that there is more live in the sound of MBSID when you just use the existing the modulation possibilities// | ||
+ | ===== Can you add more sources in the mod matrix (aftertouch, | ||
+ | modmatrix costs a lot of execution time, therefore Aftertouch/ | ||
+ | ===== Can you add filter resonance as a mod matrix destination? | ||
+ | Have you ever tried sweeping the SID's resonance? :) It's just a two-pole filter. You'll be much more successful with an external filter module. | ||
+ | ===== Can we have more SIDs in one MB SID? ===== | ||
+ | TK: //As always I have to define such specs before beginning with the implementation. First I thought that controlling two SIDs from one control surface is sufficient for stereo effects. Then I was possibly in such a volatile temper that I decided the incredible: controlling 4 SIDs from a single PIC, which is doing the sound engine of one SID in parallel! Hard to believe that this works without affecting the realtime capabilities too much. I'm really proud that it works without trouble.// | ||
+ | However, if you really want 8 SIDs, TK suggests: //you could build two 4*SID systems... this will possibly cost you 50 EUR more, but what are 50 EUR compared to my unpayable sparetime ;-)// | ||
+ | I'd go with that suggestion :) | ||
+ | ===== How do I make the MB SID sound more phat? ===== | ||
+ | Try external effects, filters. Connect them to the synth' | ||
+ | Try guitar effects. It's unbelievable what evil a simple fuzz can do to a lead or a nice " | ||
+ | You can also beef up the sound of SID's filters by routing the SID output back to its input. | ||
+ | ===== Does MIDIbox SID support graphical LCDs? ===== | ||
+ | Yes and *no* | ||
+ | MIOS itself supports graphical LCDs, which means that you could use such displays with the MIDIbox SID application. | ||
+ | But the application itself doesn' | ||
+ | Another problem is, that graphical LCD loads the CPU much more than dotmatrix LCDs, therefore such an option has never been taken into account, it would affect the realtime behaviour of the synth too much. | ||
+ | In theory it should be possible to use a second core just only for the graphical user interface. But no volunteer has been found so far who wants to implement this. | ||
+ | ===== Do I need an AIN module for the " | ||
+ | No, an AIN module is not required. | ||
+ | The analog signal sources can be directly connected to J5: | ||
+ | If you want to check the analog inputs, just select the " | ||
+ | ===== Why does the "play note" feature of CS Step C play multiple SIDs at once ===== | ||
+ | TK wrote: | ||
+ | Thats a known " | ||
+ | Sending a note instead of SysEx has also the advantage, that if SIDs are assigned to the same channel, they will be started at exactly the same time without a delay. Doing the same with SysEx would mean that I would have to implement something like a " | ||
+ | ===== Why must MIDIbox SID stop playing a note when a patch is changed ===== | ||
+ | Changing this behaviour would lead to many unwanted side effects and wouldn' | ||
+ | A proper patch change without reset would require that the whole patch is transfered to the SID as well as to the sound engine within one update cycle (0.8 mS), which is not possible with the PIC. It's especially not possible to send so much data to the slaves within this short timewindow, since the transfer takes about 260 ms. | ||
+ | ===== How is it possible to save CC changes which have been sent from external ===== | ||
+ | Short answer: enable the edit mode. In this mode, all CC changes which have been sent to the master will be regognized by the control surface. CC changes to the slaves won't be regognized. | ||
+ | Long answer - TK wrote: | ||
+ | Update of CCs to slaves: nearly impossible with the concept. At the time where I started with the implementation of the SID application on the PIC18F I had to decide how to store the data structures. I choosed a dual storage method: one compressed structure which reflects the SysEx dump and which is easy (and fast) to handle for the control surface when multiple SIDs have to be serviced, and another structure which is optimized for the sound engine. A third structure is given by the CC-> | ||
+ | This works fine in most cases, but it has disadvantages which must be accepted. E.g., since it is possible to change multiple parameters with a single CC (e.g. CC#16 which changes the transpose value of all three oscillators), | ||
+ | The current solution is to read back the data from the sound engine data storage and copy it into the SysEx storage when the CPU has some free time. This works fine, but only for the master SID, because the control surface has no access to the sound engine storage of the slave SIDs (unidirectional interface...) | ||
+ | Another solution could be to write a large function which decodes the incoming CCs and passes them to the appr. registers of the SysEx structure. This would work for the master and the slaves, but it would consume so much code memory, that other features would have to be removed. Therefore I prefered the " | ||
+ | There are two good points which I want to mention here: | ||
+ | 1) for the MIDIbox FM I solved such problems very early in the design phase - MBFM has a single data structure which is optimized for SysEx/CC and OPL3 accesses (it took some time to find out all relationships) - so, in MBFM the data is always consistent | ||
+ | 2) sometimes I'm thinking about a major redesign of the SID application which doesn' | ||
+ | However, just another remark: if the PIC18F4620 wouldn' | ||
+ | ===== What parts can be left out from the core modules when building a multi SID synth? ===== | ||
+ | Thanks wilba for the tip, you can remove everything to the left of the regulator including the regulator shown on the multi sid PDF. Remember to bridge the core PCB's where the regulators used to be. I have also heard of swapping the 2200uf cap, and not including the bridge on the cores too but I have not tested it (dcer10). Also remember when you are testing the multi sid that you need to press the link button to hear the extra sids! | ||
+ | ===== How do I connect the SID-module to the Core-module ===== | ||
+ | This question has been asked many times in the forum. | ||
+ | The pins don't all match name for name, that's the confusing bit! The pins to connect will be in the same position on those 2x5 headers. | ||
+ | It should be a 1:1 connection: | ||
+ | |Core: | ||
+ | |Vd| Vc| | ||
+ | |Vs| Vs| | ||
+ | |CLK| CLK| | ||
+ | |SC| --| | ||
+ | |MU| MU| | ||
+ | |RC| RC| | ||
+ | |MD| SC| | ||
+ | |SO| SO| | ||
+ | To avoid ground loops, it is recommended to use Vd and Vs from J2 of the Core module instead of J10. |
midibox_sid_faq.txt · Last modified: 2011/11/18 12:04 by lpdunwell
