Next revision | Previous revision Next revision Both sides next revision | ||
midibox_uc [2007/11/16 17:37] 127.0.0.1 external edit |
midibox_uc [2010/03/20 12:35] ilmenator added more on-site documentation |
Line 4: | Line 4: | ||
This is the home of the **MIDIbox UC**. | This is the home of the **MIDIbox UC**. | ||
- | It was created during a one-semester university project, //and now// you can find the complete documentation, sourcecode, and Java Software for programming it here! | + | It was created during a one-semester university project. You can find the existing documentation, sourcecode, and Java Software for programming it here! |
+ | //Beware that this is work based on the old 8-bit core (PIC-based). Back then, the Core32 did not exist, on which the implementation would be FAR easier. E.g., there you can directly connect 2 LCDs (no need for chaining 2 cores as done here), you have the SD card as a virtually unlimited memory (no hassle with creating a single address space across banksticks), usage of a third PIC just to have a MIDI merger, and so on. Before trying to copy the design presented here, you might want to think about re-implementing this on a Core32.// :-P | ||
{{uc:box_scheme.jpg}} \\ | {{uc:box_scheme.jpg}} \\ | ||
Line 43: | Line 48: | ||
DEUTSCH:[[https://med26.rz.tu-ilmenau.de/~midibox/midibox_uc/controller/docu/html_dt/index.html|HTML]] | | DEUTSCH:[[https://med26.rz.tu-ilmenau.de/~midibox/midibox_uc/controller/docu/html_dt/index.html|HTML]] | | ||
- | [[https://med26.rz.tu-ilmenau.de/~midibox/midibox_uc/controller/docu/midiboxuc_hardware_dt.pdf|PDF]]\\ | + | {{:uc:midibox_uc_hardware_documentation.pdf|PDF}}\\ |
Sourcecode MIDIbox (PIC18F4620): | Sourcecode MIDIbox (PIC18F4620): | ||
Line 69: | Line 74: | ||
DEUTSCH: [[http://web42.xps9.microserver.de/midibox/software/html_en|HTML]] | | DEUTSCH: [[http://web42.xps9.microserver.de/midibox/software/html_en|HTML]] | | ||
- | [[https://med26.rz.tu-ilmenau.de/~midibox/midibox_uc/editor_software/docu/java_edit-software_dt.pdf|PDF]]\\ | + | {{:uc:medienprojekt-software-final.pdf|PDF}}\\ |
Sourcecode Java Software: | Sourcecode Java Software: |
