midiboxdmx
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
midiboxdmx [2009/02/21 09:34] – philetaylor | midiboxdmx [2013/09/25 12:29] (current) – forum link updated smashtv | ||
Line 3: | Line 3: | ||
Midibox DMX is a DMX512 compliant controller for Midibox created by Phil Taylor - phil@taylor.org.uk | Midibox DMX is a DMX512 compliant controller for Midibox created by Phil Taylor - phil@taylor.org.uk | ||
- | Originally Discussed [[http://www.midibox.org/ | + | Originally Discussed [[http:// |
- | Here is a picture of my test system, | + | Here is a picture of my test system, |
===== Concept ===== | ===== Concept ===== | ||
Line 64: | Line 64: | ||
After reading the RDM spec, I realise that a simple BIAS circuit will also be required, this is only 2 extra resistors (+ 120ohm terminator) so I will post a modified circuit soon. | After reading the RDM spec, I realise that a simple BIAS circuit will also be required, this is only 2 extra resistors (+ 120ohm terminator) so I will post a modified circuit soon. | ||
- | {{http://www.lansystems.co.uk/ | + | {{:midiboxdmx: |
Line 106: | Line 108: | ||
Pretty much everything at the moment, | Pretty much everything at the moment, | ||
midiboxdmx.txt · Last modified: 2013/09/25 12:29 by smashtv
