midiboxmixer
Differences
Next revision | Previous revisionNext revisionBoth sides next revision | ||
midiboxmixer [2008/10/01 02:24] – external edit 127.0.0.1 | midiboxmixer [2011/08/18 22:31] – dougster | ||
Line 5: | Line 5: | ||
note: This page is an edit in progress. At this time the change to version 2 is near complete, but I may have missed a few details. | note: This page is an edit in progress. At this time the change to version 2 is near complete, but I may have missed a few details. | ||
- | Copyright (C) 2007, | + | Copyright (C) 2007, |
Licensed for personal non-commercial use only. All other rights reserved.\\ | Licensed for personal non-commercial use only. All other rights reserved.\\ | ||
Line 19: | Line 19: | ||
balance of attached audio sources. | balance of attached audio sources. | ||
(Ver 2) Now supports balanced or unbalanced inputs and outputs, optional effects | (Ver 2) Now supports balanced or unbalanced inputs and outputs, optional effects | ||
- | loops, and a wider set of MIDI commands. Circuit boards are available. | + | loops, and a wider set of MIDI commands. |
Line 36: | Line 36: | ||
Additional Hardware Info: [[MIDIboxMixerHardware]] | Additional Hardware Info: [[MIDIboxMixerHardware]] | ||
+ | The circuit board designs have been provided to SmashTV, and will be available in his | ||
+ | web shop. If you are interested, please let him know! | ||
midiboxmixer.txt · Last modified: 2011/11/29 14:27 by smashtv
