mididocs:seq:blm16x16_build_guide
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
mididocs:seq:blm16x16_build_guide [2016/03/28 21:24] – [General considerations: read before building] latigid_on | mididocs:seq:blm16x16_build_guide [2017/11/24 19:50] – [Tools needed] latigid_on | ||
Line 25: | Line 25: | ||
* Pull-down resistors on current sink transistor bases (important when bases are floating and should decrease power consumption). | * Pull-down resistors on current sink transistor bases (important when bases are floating and should decrease power consumption). | ||
* Schottky diodes from base to collector of current sink transistors. This helps to turn transistors " | * Schottky diodes from base to collector of current sink transistors. This helps to turn transistors " | ||
- | * Output enable (/OE) delay implemented on pin 6 of 74HC595 chips. At power up the capacitor will charge, holding all outputs in a high impedance state until the +5V rail is stable. At power down this capacitor discharges through a pull down resistor, aided by a diode. One delay circuit is provided for each SCALAR section. | + | * Output enable (/OE) delay implemented on pin 13 of 74HC595 chips. At power up the series |
For minimal external cabling, the BLM connects to a SEQ v4 via an 8-pin DIN connector. This combines MIDI in, MIDI out and power; the communications protocol sent and received by the BLM is standard MIDI. Most users will incorporate a Quad IIC board into their SEQ case, which is the simplest way to arrange the DIN8 connector, optocoupler and header pins. | For minimal external cabling, the BLM connects to a SEQ v4 via an 8-pin DIN connector. This combines MIDI in, MIDI out and power; the communications protocol sent and received by the BLM is standard MIDI. Most users will incorporate a Quad IIC board into their SEQ case, which is the simplest way to arrange the DIN8 connector, optocoupler and header pins. | ||
Line 44: | Line 44: | ||
==== Parts list ==== | ==== Parts list ==== | ||
- | The following parts are available from Mouser | + | The following parts are available from Mouser, you can try this shopping basket to save time. |
+ | [[http:// | ||
Quantity | Quantity | ||
- | **Resistors** | + | Resistors |
660-MF1/ | 660-MF1/ | ||
652-CR1206FX-1002ELF | 652-CR1206FX-1002ELF | ||
Line 54: | Line 56: | ||
652-PTL45-10G0-102B2 | 652-PTL45-10G0-102B2 | ||
- | **Resistor networks** | + | Resistor networks |
652-4816P-T2LF-10K | 652-4816P-T2LF-10K | ||
652-4816P-1LF-1K | 652-4816P-1LF-1K | ||
Line 60: | Line 62: | ||
652-4816P-1LF-56 | 652-4816P-1LF-56 | ||
- | **Capacitors** | + | Capacitors |
647-TVX1C471MAD | 647-TVX1C471MAD | ||
80-C1206C104K5R | 80-C1206C104K5R | ||
647-F931C106MAA | 647-F931C106MAA | ||
- | **Diodes** | + | Diodes |
512-BAT54 | 512-BAT54 | ||
512-1N4148TR | 512-1N4148TR | ||
78-LS4148-GS18 | 78-LS4148-GS18 | ||
- | **LEDs** | + | LEDs |
604-APTR3216ZGC | 604-APTR3216ZGC | ||
604-APTR3216QBC/ | 604-APTR3216QBC/ | ||
604-APTR3216SURCK | 604-APTR3216SURCK | ||
- | **Transistors** | + | Transistors |
512-BC81840MTF | 512-BC81840MTF | ||
- | **ICs** | + | ICs |
595-SN74LVC1G17DBVR | 595-SN74LVC1G17DBVR | ||
595-SN74HC165DR | 595-SN74HC165DR | ||
595-SN74HC595DR | 595-SN74HC595DR | ||
- | **Connectors** | + | Connectors |
523-T3507-000 | 523-T3507-000 | ||
523-T3504-001 | 523-T3504-001 | ||
Line 89: | Line 91: | ||
- | **Hardware** | + | Hardware |
Line 99: | Line 101: | ||
- | **Buttons** | + | Buttons |
- | **Spacer** | + | Spacer |
+ | ==== Parts notes ==== | ||
+ | * You can choose either Blue+Green LEDs (recommended) or Blue+Red. You could interchange some Green for Red. Green+Red is not recommended as the colour mixing is poor. | ||
+ | * Slider height: I specified 15mm shaft sliders, you could change these for 10mm. 15mm will protrude 13mm out of the case, which might be a bit long. 10mm will only protrude 8mm, so they would be less likely to break off and will probably be a bit more sturdy. TK. suggests 1k should work, the others are too high in resistance to get good jitter-free values (10k sliders with the shorter shaft aren't readily available). | ||
+ | * You should use the indicated panel mount DIN, but a cheaper pair of DIN8 plugs might work. | ||
+ | * M2 hardware is a bit difficult to find in normal stores, but Boltbase on eBay has good deals. | ||
+ | ==== Tools needed ==== | ||
+ | * Soldering iron, I managed with a normal tip but it’s a bit tricky with some components | ||
+ | * Solder, probably leaded. 0.5mm is strongly recommended for at least the ICs (1206 can be easily done with 1mm solder). | ||
+ | * Desoldering wick and/or solder pump. Useful when the pads get too much solder | ||
+ | * Tweezers to pick and place components | ||
+ | * Cutters for diodes and a few through hole components | ||
+ | * Good eyes or light and a loupe | ||
+ | * 2-3 small clamps | ||
+ | * Flat work surface | ||
+ | * Multimeter, test continuity between pads | ||
+ | ==== Dimensions ==== | ||
+ | Here are the dimensions for the button, hole and slider locations. Note that the unmarked mounting holes are M3 (3.2mm diameter) | ||
mididocs/seq/blm16x16_build_guide.txt · Last modified: 2017/11/24 19:52 by latigid_on
